EAGLE User Support (English) Cannot get pad names to display in package editor
  • Replies 8 replies
  • Subscribers 180 subscribers
  • Views 1204 views
I'm having a problem with a copy of EAGLE V4.16 that I've used for the last
couple of years without problems.
In the last few days I've found that I can't get the pad names to display on
packages in the library editor! Both the SET PAD_NAMES ON command or the
Options -> Set->Misc->Display Pad Names menu pick check box have no effect.
If I transfer the library to another system in our office the pad names
display correctly, so I reckon it can't be the data in the library file
itself. Re-installing the EAGLE package doesn't help.
Is there a hidden layer I need to turn on, an .epf file or an registry entry
that's got corrupted somewhere?
Any help would be gratefully appreciated.
Malcolm Sharp
    Malcolm Sharp
    If you change the Options -> Set->Misc->Display Pad Names, the changes
    are not visible immediately. You must REDRAW the screen to get the new
    results. Maybe it is just that.
    Gruß / regards
    Jörn
    Jörn
    Thanks for your reply. Unfortunately, using REDRAW command (or button) or
    any other command that causes the image to refresh still doesn't cause the
    pad names to be displayed.
    I don't think it is anything to do with the library files themselves as the
    pad names don't display on packages in the libraries that are part of the
    EAGLE distribution. The same libraries also work perfectly on another EAGLE
    system  we have in the office. Uninstalling and reinstalling the EAGLE
    package doesn't help either. Is there a registry entry or something that is
    retained when EAGLE is reinstalled that may have become corrupted?
    Malcolm
    "Joern Paschedag" <jpaschedag@t-online.de> wrote in message
    news:go0mmc$vav$1@cheetah.cadsoft.de...
    last
    display on
    effect.
    entry
    Malcolm Sharp
    Gruß / regards
    Jörn
  • Richard_H
    Richard_H over 16 years ago
    Jörn
    Malcolm
    Don't you see the pads names if you zoom further into the drawing?
    Provided "Display pad names" is active in Options/Set/Misc and the
    Pads layer or Top/Bottom layer for SMDs is displayed.
    Richard Hammerl
    Problem solved!
    The problem is with the use of background colours and the order in which
    colours written to the screen.
    If you issue SET PALETTE WHITE in the package editor (which I like to do)
    then the pad names are written in grey first and then the pad or smd is
    written on TOP of the name. If the name is smaller than the pad then you
    don't see it! That was the problem. You can check this if you change the
    name of the pad to make it bigger than the smd pad as you can see the large
    name extending out from under the smd pad.
    The behaviour when you SET PALETTE BLACK or SET PALETTE COLORED is
    different. The smd pad is displayed first and then the pad name is written
    in grey over the top.
    So the workaround is don't develop packages using SET PALETTE WHITE mode if
    you want to see the pad names.
    The solution is when you SET PAD_NAMES ON the pad name should always be
    written on top of the pad or smd irrespective of the PALETTE employed.
    Hopefully this is the case with later versions of EAGLE.
    Malcolm
    "Richard Hammerl" <ric@cadsoft.de> wrote in message
    news:go5rqt$b76$1@cheetah.cadsoft.de...
    Jörn
    or
    the
    the
    the
    EAGLE
    is
    Malcolm
    Richard Hammerl
  • kcadsoft
    kcadsoft over 16 years ago
    On 02/26/09 12:57, Malcolm Sharp wrote:
    Problem solved!
    The attached screenshot shows what I see here with white background
    and SET PAD_NAMES ON. The names are visible.
    Can you post a screenshot of what you are seeing?
    Klaus Schmidinger
    Hofmark 2                               Email:   kls@cadsoft.de
    Klaus,
    Your screen shot isn't what I am seeing. See enclosed screen dump. This is
    of three smd pads with SET PALETTE WHITE and SET PAD_NAMES_ON. The pad names
    are P$1, P$2 and P$3 as you would expect, but you can't see them. Before the
    screen shot was taken I renamed the top pad to a long name so you can see
    that it is actually dispayed under the pad. Weird. EAGLE 4.16 behaves the
    same way on both systems here at the office.
    I hope this helps explain and help diagnose the problem.
    Malcolm
    "Klaus Schmidinger" <Klaus.Schmidinger@cadsoft.de> wrote in message
    news:go8bpb$hda$1@cheetah.cadsoft.de...
    Problem solved!
    large
    written
    if
    Klaus Schmidinger
  • kcadsoft
    On 02/27/09 21:07, Malcolm wrote:
    Klaus,
    I'm sorry, I totally missed that you are using EAGLE 4.16 (although
    you mentioned that in the first line of your message).
    EAGLE 4.16 uses "subtractive" color mixing on white background, which
    means that the default color #7 (dark gray) mixed with color #4 (red)
    doesn't result in a new color.
    You could set the color #7 in the "white background" palette to some
    other value that better mixes with the basic colors.
    Klaus Schmidinger
    Klaus,
    Thanks for the explanation and workaround. I'll use it (or SET PALETTE
    BLACK!) in future!
    Malcolm
    news:gogln9$d7i$1@cheetah.cadsoft.de...
    Klaus,
    is
    names
    the
    Klaus Schmidinger
