EAGLE User Support (English) Is there anyway to exclude parts from the PCB
  • Replies 29 replies
  • Subscribers 181 subscribers
  • Views 4487 views
In Eagle Cad, is there anyway to exclude components on the schematic from the board view? I have several parts that will be wired to screw terminals. They still need to be shown in the schematic, but I do not need or want them on the board. I can't leave them outside the board area, so what's a guy to do? Thanks...
    autodeskguest over 11 years ago +1
    On 3/26/2015 4:38 AM, Derek Tombrello wrote: In Eagle Cad, is there anyway to exclude components on the schematic from the board view? I have several parts that will be wired to screw terminals. They still…
    autodeskguest over 9 years ago in reply to Former Member +1
    Mark Winters wrote: Hello Jorge. I wonder if you could point me to some documentation that helps me to remove the package as explained. I have made a copy of the component in my own library but return…
    0 Former Member over 11 years ago in reply to autodeskguest
    "TROLL"?! Excuse me for not being an expert in Eagle. And if you meant that Eagle itself wasn't up to date... I'm one revision behind. So sue me.
    @Jorge -> I just now saw your reply and I will try that tonight. I do think that that may be step-intensive... but if it works...
    @CadSoft Guest -> I have seen kicad in the repositories, but I've never tried playing with it. I may try that this weekend as well.
    To those of you who actually had something constructive to add, I truly appreciate your help!
    0 autodeskguest over 11 years ago in reply to Former Member
    me.
    No, you're not the troll. "Poll-was Poll-was" is a persistent troll who
    hasn't kept up to date. See Jorge's reply (which you now have). I don't
    think it's overly intensive and it's the right way to handle the
    specific issue you began with. This half of the discussion got
    side-tracked onto a different issue.
    Ah... my bad. Thank you image and sorry...
    0 autodeskguest over 11 years ago in reply to autodeskguest
    Rob Pearce wrote on Fri, 27 March 2015 01:51
    It may not be ideal for that case, but that's a case where nothing's
    ideal. Frankly, I find the KiCad / gEDA method utterly unusable.
    KiCad and gEDA remind me of the old days when I was using command line
    tools like vi and make along with eqn, tbl and troff instead of integrated
    environments like Visual Studio or Eclipse and modern publishing tools.
    LOL!  (It's great that they're open source and such, but as we say,
    "they're only free if your time isn't worth anything!")
    Funny thing is, I LOVE that EAGLE has a command line and that I can write
    a script or ULP to do just about anything!  That's what makes EAGLE so
    powerful and keeps it my favorite tool.
    0 Former Member over 10 years ago in reply to autodeskguest
    OK... I'm sorry, call me stupid, but I am not following this. I appreciate the replies, but the two most useful (I think) on editing properties seem to assume that I already know how to do what I am asking. I figured out how to open a Library (the LED library for starters). That brought me up to a blank slate. From there, I figured out how to load the SFH482 component - which gave me the drawing of it. That's were I veered off the road. I cannot figure out how to add an attribute for External.
    --edit--
    I did add the EXTERNAL attribute to the component from the schematic view, but since there is still a package....
    0 autodeskguest over 10 years ago in reply to Former Member
    I've created a sample library showing the desired result using the
    SFH482 as an example.
    The library contains a copy of the original part from the eagle
    library and a 'no package' derivative thereoff.
    Let's see, if that gets you going (perhapse with the help of the eagle
    manual and some tutorials on part creation 8-)
    If not, I'll try to find the time to write up the required steps.
    Lorenz
    I think this might get me on the right track, but.. .um... how do I access the sample library you made? image
    http://www.element14.com/community/message/145751
    Hi Derek,
    Download the library to your computer and make sure you know where it
    is. From there go into the EAGLE Control Panel and click File> Open >
    Library. Select the Library you downloaded and you should be good.
    Reach out if there's anything else you need.
    hth,
    Jorge Garcia
    I'm sorry... I didn't see that link in your previous reply. I'll check that out when I get home. Thanks!
    0 Former Member over 10 years ago in reply to Former Member
    Still not seeing any attachment to download.... sorry.
