EAGLE User Support (English) Renaming a component error
  • Replies 11 replies
  • Subscribers 179 subscribers
  • Views 953 views
pavanbabut
pavanbabut over 10 years ago
I have a schematic and board that I am going through the names of components. The problem I am having is whenever I try to delete a component in my case a cap (ex: C21) and then replace it with a different type cap, it changes its name to C00021 rather than C21 and when I try to rename it to C21 it gives me error that the component already exists, but when I try 'Show' command it doesn't show it and when I try to Show it on board, it says 'doesn't exist'. Very frustrating, I have few components that I want to replace with different type and its doing for all those.
Any ideas or suggestions?
thanks
  • clem57
    0 clem57 over 10 years ago
    Take a look at How to create a new schematic symbol in the Eagle editor
  • pavanbabut
    0 pavanbabut over 10 years ago in reply to clem57
    Not sure if that tutorial has anything that answer's my question. I tried to read it word by word and all it shows you is how to create a device from scratch. I already did that when creating my devices and it worked fine all these years, but suddenly whenever I add a component after deleting it, it keeps adding 000 before the number as I mentioned earlier. If I create a whole new schematic form my current one and delete/add a component, it works fine, but if I copy my board into and then delete/add it does weirdly as I mentioned. I don't want to do my layout again from scratch, too much of a work.
    Any suggestions?
    thanks
    0 autodeskguest over 10 years ago in reply to pavanbabut
    Any suggestions?
    Is your Schematic /Board pair currently consistent?
    Which version of Eagle?
    What operating system?
    Running ERC may give you a clue to what's going on.
    Can you upload your schem/Board?
    Warren
  • pavanbabut
    0 pavanbabut over 10 years ago in reply to autodeskguest
    When I ran ERC on schematic, it shows 'Board and Schematic are consistent'.
    I am using Eagle 6.5 on Windows 8.1
  • pavanbabut
    0 pavanbabut over 10 years ago in reply to pavanbabut
    Not sure why this is happening, but I got around this problem by renaming the component to a number that's not on the board and then changing it back to the number that I want. For example C00021 -> C150 (not in my schematic) -> C21. This worked fine for my purpose.
    What version and locale are you using?
    Did you try 'show @ C21" in both sch and brd?
  • pavanbabut
    Eagle 6.5.0 standard and when I use Show command, it just pops up a dialog with C21 in there in schematic and it does nothing when I click it and when I use the same command in Board, it gives me error that C21 is no found.
    is no found.
    Sounds like C21 is a funny cap with no footprint, but then again, it
    should be visible...
    Did you try to type "delete c21" from sch? Then "show c21" again? If its
    gone, do ERC to make sure you have consistancy.
  • pavanbabut
    Actually I used C21 as an example, it does the same on any component. Yes I did delete command and then tried show command with same results.
    I think we can conclude that your files are corrupt, and that Eagle is
    not able to repair it. Im sure someone at cadsoft could fix it for you
    if its important.
