EAGLE User Support (English) Is this group still active?
  • Replies 28 replies
  • Subscribers 185 subscribers
  • Views 2939 views
Oppie
Oppie over 9 years ago
I have not seen any new messages lately. Is my reader broken?
Do messages here mirror the element-14 discussions?
    I saw this reply on the Element14 forums that appears to not have propagated
    the nntp (Usenet) side.
    Oppie
    Re: Is this group still active?
    Christy-Admin Level 6: Lovelace
    Christy-Admin Apr 13, 2016 5:45 PM (in response to CadSoft Guest)
    I wish I had a better answer for you. It was working absolutely fine after
    the migration/upgrade and we did do extensive testing in a "sandbox" - so
    that is not what broke it. Something was changed on our network about a
    month ago that broke the link to CadSoft's forums and we've been scrambling
    to try to work out how to get it working properly again. We thought it was
    resolved the other day. However, as we can only do limited testing on the
    live environment in a 'test' forum to check the syncing before we run it
    live, we then were informed it updated a bunch of old posts in addition to
    bringing in new posts that had been queued up in the backlog since the sync
    was broken which it had never done previously - and nothing in the code that
    processes the interface has changed. Only the connection restored. We are
    working with our global IT and networking departments to try to restore the
    link back to the way it was working previously and apologize for any
    inconvenience this has caused to you on the forums.
    Sincerely,
    element14 Development Team
    My bad. Set up newsreader on a different computer and somehow listed my name
    as Cadsoft rather than Oppie.
    "Cadsoft"  wrote in message news:nempie$3lu$1@baboon.cadsoft.de...
    Oppie
  • rachaelp
    rachaelp over 9 years ago in reply to ChristyZ
    Thanks for getting in touch with a more detailed explanation of what's been going on, it helps to know the issue is being dealt with properly. It seems that a few things have started syncing across over night so fingers crossed it's all working correctly now! :-)
    Many thanks,
    Rachael
  • ChristyZ
    ChristyZ over 9 years ago
    Thanks for posting my reply over to the forums Oppie, and your comment, Rachel. It looks like posts from the forums are coming IN to the Community, but posts from the Community are not going OUT. So I think something on our network is still blocked but only in one direction. We're going to keep on this until we get it right. Apologies again for the delay and inconvenience.
    Sincerely,
    Christy - element14
  • rachaelp
    Hi Christy,
    Actually posts seem to have been going both ways today so fingers crossed I think it may now be working properly.
    Thanks for getting this sorted.
    Rachael
  • Oppie
    Oppie over 9 years ago in reply to ChristyZ
    Christy- does it make any difference that when I access the nntp Cadsoft NG through a newsreader, no login credentials need be entered. In order to use the Element14 forum, afik, one has to login to post? Was wondering if this might be an issue?
  • ChristyZ
    ChristyZ over 9 years ago in reply to Oppie
    It shouldn't be an issue for the sync to work. It might be an issue in terms of having your posts appear on element14 using your correct username here. Is there something else you were referring to about it "being an issue"?
    It does look like posts from the Community are starting to export again now, so we'll keep monitoring and hopefully that's got it.
    Thanks for your assistance and patience.
    Christy - element14
  • Dudley
    Dudley over 9 years ago in reply to ChristyZ
    We found that there was a problem with the linkage. The community website runs with four separate servers, and one of those four had a connectivity problem with the news group. If a user posted a reply on community and that reply was handled by the server with issues, the link failed, and that meant the user thought they had made a reply, could see their reply on community, but that reply never made it out to the newsgroup.
    That meant that discussions were occasionally being orphaned, ironically including Christy's reply here to the newsgroup!
    We've now fixed that linkage error, so we should (hopefully) now have no problems and everything should be working fine.
    If there are any problems, either reply here, or poke me on the link below image
    Dudley
    Dudley
  • Oppie
    Oppie over 9 years ago in reply to Dudley
    "Dudley Nelson" <dnelson@premierfarnell.com> wrote in message > We found
    Dudley
    Much appreciated Dudley
  • rachaelp
    rachaelp over 9 years ago in reply to Dudley
    Hi Dudley,
    It seems there is still a problem with the link unfortunately. Any posts made over in Eagle Central appear multiple times over in this Element14 forum it seems.
    Best Regards,
    Rachael
