EAGLE User Support (English) Air wire problems
  • Replies 9 replies
  • Subscribers 187 subscribers
  • Views 3523 views
Air wire problems
1.  When I run ratsnest it says I still have 11 air wires, but I can't see
them.  Is there any way to highlight them?  I assume they're little stubs
left over from my lame routing.
2.  In the attached image, what are those gray hatched circles at the top?
I assume they're related to vias I placed and later ripped up (they're in
the middle of a trace I've turned off to make them visible), but I can't
get them to go away, either with ripup or delete (which generates an
error).  How can I get rid of them?  I was going to ask about the odd air
wire going off to the right, but I fixed it.
    autodeskguest over 10 years ago in reply to dukepro
    Thanks, Chuck.  I don't have that option, though I'm on v4.16, so maybe it
    came out later.  I keep thinking about upgrading, but this version seems to
    do everything I need, so it gets pushed off.  Anyway, I was able to solve
    my problem by turning off all layers except airwires.  I could find even
    tiny ones that way.
  • dukepro
    dukepro over 10 years ago
    Karl,
    Rob, Morten, and Lorenz all had some very good ideas on how to find such
    air wires.
    There is a different method, however, that seems to work best for me.
    Perhaps it will suit you as well.
    From the board editor, click Options -> Set -> Misc.  Set the catch
    factor to 0.
    This allows you to start a route from anywhere on (or off) the board.
    The nearest air wire will be picked up.  Moving the cursor around some
    will allow one to identify the closest end of the nearest air wire.
    Morten is correct in how to get rid of the DRC markers.  Getting rid of
    the air wires, though, can only be done by routing each.
    HTH,
        - Chuck
    autodeskguest over 10 years ago in reply to autodeskguest
    Thanks, Lorenz, but I solved the problem by turning off every layer except
    airwires, then zooming in on the stubs.
    try this ULP:
    #usage " 0) {
          string cmd;
          sprintf(cmd, "window (%.1fmic %.1fmic) (%.1fmic %.1fmic);",
                                u2mic(X1[sel]), u2mic(Y1[sel]),
                                                  u2mic(X2[sel]),
    u2mic(Y2[sel])
          switch (ret) {
            case 1:
            case 3:
              sprintf(s, "run listUnrouted %d;", sel + 1);
              cmd += s;
              break;
            case 2:
              cmd += "show @ " + Name[sel];
              break;
          exit(cmd);
      else
        dlgMessageBox("no unrouted segments found!");
    } // if board
    Lorenz
    Next, turn off the visibility of the routed layers
    Yup, that's what I ended up doing.  Works great for finding the little
    stubs of airwires, but actually eliminating them, as you point out, can be
    infuriating.
    On Sun, 02 Oct 2016 20:35:12 -0400, Karl Lautman <karl@lautman.com>
    First thing I do is set the airwire color to bright magenta.  That
    seems to be the most visible color against Eagle's background.
    Next, turn off the visibility of the routed layers and look for little
    pink dashes and lines on your screen.  Turn the layers back on, one at
    a time to find the affected area.
    Realize that Eagle's routing and airwire detection is really
    stoooopid.  For example, if I lay down some copper and then put 4 vias
    in the square touching each other and obviously connected, Eagle has
    no clue.  It flags air wires until I route (invisible) wires between
    the vias, give the copper the desired signal name and optionally
    connect it to where it needs to go.
    I use this technique to say, connect 4 current shunts in parallel.
    Easily drawn.  Difficult to satisfy Eagle.
    John DeArmond
    http://www.neon-john.com
    http://www.tnduction.com
    Tellico Plains, Occupied TN
    See website for email address
    On 03.10.2016 08:24, Karl Lautman wrote:
    Could they be left-over DRC error markers?
    Possibly. Any idea how to get rid of them?
    re-run DRC, or type "errors clear"
    You could try temporarily turning off all layers
    Great idea.  Thanks.
    Sounds like they're little stubs within a pad or between two tracks that
    already overlap. You could try temporarily turning off all layers apart
    from the airwires, note positions (or mark them on an unused Doc layer)
    before turning useful layers back on.
    Could they be left-over DRC error markers? The shape looks like the
    overlap of two not-quite-concentric vias.
