EAGLE User Support (English) EAGLE v8 Update Policy
  • Replies 10 replies
  • Subscribers 189 subscribers
  • Views 1501 views
Hello Autodesk Support,
Can you explain the nuances around updating policy?  If I'm using EAGLE
v8.0 and v8.1 comes out, am I forced to upgrade?  Can I use v8.0
indefinitely?
I absolutely don't want to be forced into an upgrade in the middle of a
design project.  I may choose to do so if the benefits outweigh the risks.
But no professional takes on CAD updates without a lot of thought and
testing to make sure there aren't unintended consequences of the upgrade.
I want to make sure I will maintain that control, even if that means never
upgrading to a particular version ever.
Cheers,
James.
http://www.stratforddigital.ca
http://www.eaglecentral.ca :: The original and best browser access to CadSoft EAGLE support forums.  Supported by EAGLE licenses purchased through us :: http://www.eaglelicenses.com
    On Thu, 19 Jan 2017 13:57:32 -0500, Jorge Garcia
    indefinitely?
    Cheers,
    James.
    Hi James,
    Whenever a new update comes out, you will see a button in the control
    panel to Update your EAGLE. If you don't click on that button you will
    continue to use the same version of EAGLE until you click on the Update
    button.
    If you never hit that button, then you will never update. As long as you
    keep paying the subscription you can continue to use that same version
    of EAGLE and upgrade when you feel ready.
    Hope that clarifies things.
    Best Regards,
    Jorge Garcia
    I See Autodesk updated the website again, you will have access to
    older versions that you paid for.
    <http://www.autodesk.com/subscription>
    You can also find your previous product key.
    Cheers
    Glenn Jones wrote on Sat, 21 January 2017 04:19
    EAGLE
    indefinitely?
    of a
    the risks.
    and
    upgrade.
    means never
    Cheers,
    James.
    Hi James, I did my last Eagle upgrade through your company. Emails
    detailing upgrade information for V8 were supposed to have gone out.
    Will I get one as I bought through you vs Cadsoft directly?
    Glenn
    Hello Glenn,
    You'll have to contact Autodesk.  They I received an email on Jan 10, and a
    subsequent letter by courier, that terminated my distribution agreement on
    Jan 13--the day they stopped processing v7 licenses.
    Sorry for any inconvenience but right now you I don't know any more about
    this process than anyone else outside of Autodesk.  If they had asked I
    could have predicted this backlash on the licensing scheme.  I did predict
    it on v7.0 when Farnell tried a similar move though no one at Farnell
    listened at the time until it was released and it was too late.
    Cheers,
    James
    EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
  • rachaelp
    rachaelp over 9 years ago in reply to omega-5
    Friedrich Bleikamp wrote:
    Am 19.01.2017 um 17:59 schrieb James Morrison:
    Cheers,
    James.
    I am absolutely with you.
    Another problem - In large companies there is usually an IT
    which only releases a software after extensive examinations for
    the users. Updates by the user are prevented or not allowed.
    Freundliche Grüße / Kind regards
    Friedrich
    ... use NNTP://news.cadsoft.de and a
    functional news reader like Thunderbird!
    ... or http://www.eaglecentral.ca
    I'm not sure where this concern has arisen from. It looks to me that so long as you keep paying your subscription your currently installed version will continue to work. I don't see anything that compels you to upgrade to a newer version when it comes out.
  • omega-5
    omega-5 over 9 years ago
    Cheers,
    James.
    Friedrich
    Hi Jorge,
    I apologize if you've already said, but it's just to be sure once again.
    That means I'll never own my licensed EAGLE v8, won't I? If I don't
    renew the subscription I cannot use the program anymore, even without
    any further update? Too bad...
    I'm stuck with v6, because v7 doesn't justify the upgrade costs. v8
    sounds interesting but I think your new policy doesn't help old users to
    "buy" the new version (actually we don't buy anything, but we rent some
    time to use your software).
    I can afford the cost if it is one shot - not every year! And what about
    if you raise the price? We don't own anything, so we must pay again and
    again.
    I'm going to stay with v6 as long as possible then look for alternatives.
    Hi Jorge, I saw in another thread your reply about the license text that
    talks about having to remove old versions.
    As long as were not using the licenses on more machines then originally
    allowed and we are not expecting support for those older versions, I am
    not sure I understand the rational for having to remove them.
    I don't plan on migrating all my designs to V8. I also have copies of
    eagle installed going all the way back to when I first started using
    your product and still have some designs not migrated.
    I think it needs to made clear in the license text that removal of old
    versions only pertains to the versions offered for subscription. Even if
    we obtain V8 through an "upgrade"
    If I can't keep my paid for license of 7.7 around for perpetuity then I
    can't see myself upgrading to or licensing a V8+ subscription.
    Glenn
    indefinitely?
    risks.
    never
    Cheers,
    James.
    Hi James,
    button.
    Best Regards,
    Jorge Garcia
    indefinitely?
    Cheers,
    James.
    Glenn
    Jorge Garcia wrote on Thu, 19 January 2017 18:57
    EAGLE
    indefinitely?
    of a
    the risks.
    and
    upgrade.
    means never
    Cheers,
    James.
    Hi James,
    button.
    you
    Best Regards,
    Jorge Garcia
    Thanks Jorge,
    Now the next level questions:
    As a design house my customers come to me and tell me what version of EAGLE
    they are on.  So I currently have the following versions all installed at
    once:  6.5, 6.6, 7.5, 7.7.  Will I be able to have multiple versions of V8
    installed on the same machine?
    Also, in the past, buying a v7 license would also unlock older versions
    before v7 (ignoring the *** child that v7.0 was).  If I'm a design
    house and I have a customer who requires me to use v7, then how do I get
    that when I buy a v8 license?
    As a design house I can't force my customers to upgrade their EAGLE license
    so I have to use what they tell me they want since that decision has other
    implications to their workflow.
    Cheers,
    James.
    indefinitely?
    Cheers,
    James.
    Hi James,
    button.
    Best Regards,
    Jorge Garcia
    On Thu, 19 Jan 2017 16:59:01 +0000, James Morrison
    indefinitely?
    Cheers,
    James.
    I just looked at the Autocad page, Subscription pricing, and they
    include older versions there. Perhaps someone can clarify on the Eagle
    side.
    I still have my DOS version, and Just upgraded to 7.7 from 4.5,  I
    still use the Older versions for maintenance.
    FYI, I am not happy with the Subscription offering.
    Cheers
