Forum Suggestion for EAGLE
  • Subscribers 189 subscribers
  • Views 915 views
  • board
  • eagle
  • layout
  • library
  • farnell
  • pcb_layout
  • pcb
  • Design
  • schematic
  • cadsoft
  • software
EAGLE is the best PCB software package I've used so far, as It's easy to use, simple, and has a wide range of existing libraries. However, one thing that I'd really like to see included in it is some sort of 3D view. This is available on other packages like DIPtrace and Altium designer, but not (that I'm aware of) on EAGLE! Please consider adding this, as it's a really useful feature to visualise your board before production, and it helps in spotting any errors before you send it off!
  • Eriond
    Eriond over 11 years ago
    I have just had the opportunity to give the new IPROCircuit from Italian software company Fronema, a test drive.
    And boy, am I impressed! In this new release, targeted at the recently available IronCAD 2015, there is native Eagle support:
    A custom ULP does all the work that previously required going through SketchUp/EagleUp, and with a few mouse clicks I can now import my Eagle creations into the 3D realm of IronCAD.
    There are a bunch of easy-to-use features to help me handle component librarys, what to import (or to avoid), replace individual components (in case a package is missing, and I have a similar replacement), and much more.
    Of course, this requires that You already have and are using IronCAD, but if you don't, it might be worth the switch :-)
    The current information about IPROCircuit at Fronemas web doesn't yet mention this new version (v17), and the screenshots and videos are from a previous version, but I expect that to change soon.
    If you are serious about working in 3D with your Eagle boards, you should definitely have a look at IPROCircuit.
    /M
    Hi Rahul,
    check out EAGLE-to-3D and IDF-to-3D:
    http://www.pcb-pool.com/ppuk/info_idfto3d.html
    get a 3D PDF, a STEP file for your MCAD guys and a OBJ+MTL file for rendering:
    e14 Contributor over 13 years ago in reply to Richard_H
    Oh, I had no idea about these! I'll definitely take a look, thanks image
  • Richard_H
    Richard_H over 13 years ago
    Hi Rahul,
    there are User Language Programs that allow to generate 3D data.
    This are projects initated by EAGLE customers. Please take a look
    at the download area of www.cadsoft.de. In the ULP direcotry
    search for
    acis-sat.ulp
    ACIS-SAT exports an ACIS model of the PCB as a Standard ACIS Text (SAT)
    file in units of inches. The ACIS model includes a 1/16" thick cuboid
    (rectangular slab) with holes. Importing this type of model into a CAD
    package is useful for enclosure design. The vector-based nature of the
    file enables importing CAD packages to support snapping to PCB features
    including hole centers. Many 3D CAD packages support SAT files
    including AutoCAD, Inventor, CADKEY, Solid Edge, SolidWorks, IronCAD
    and more.
    Uploaded by Ed Slatt <ed.slatt at pcbsingles.com> from PCB Singles
    generate_3d_data.ulp and generate_3d_data_eng.pdf
    ULP for generating 3d data for 3D-MCAD systems and the help file
    of Generate 3D Data translated to English. File format:
    IDF3.0 (IDB:board, IDL:libary)
    Uploaded by Neubacher Andreas <a.neubacher at commend.com> from
    Commend International GmbH
    3d_ulp.zip
    Making PRO Engineer 3D assembly files from EAGLE files using IDF and DXF.
    Documentation and example are included.
    Works with EAGLE 5.11 and ProEngineer WF5
    There are two further projects available in the internet:
    3D data for PovRay (rendering program)
    ==> http://www.matwei.de
    EAGLE meets SketchUp -- turn your Eagle layouts into 3D models
    ==> http://eagleup.wordpress.com/
    Please check.
    Richard
