Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Licensing woes
  • Locked Locked
  • Replies 12 replies
  • Answers 2 answers
  • Subscribers 93 subscribers
  • Views 3023 views
  • frontpage
Licensing woes
tony_tero
tony_tero over 6 years ago
Hi All,
We purchased a license for Circuit Studio at the beginning of January. Unfortunately, the license was issued to the person who purchased it, not the engineer who will be using it (me).
I've sent a few emails to software@element14.com with zero response. The purchasing person has also tried calling the support phone line with no luck.
Can anyone advise the best way to get this rectified?
Thanks...
  • tony_tero
    tony_tero over 6 years ago in reply to tony_tero +1
    I think my situation is more like this one: How to transfer a license to a new engineer The problem is that I haven't been able to get any response from Altium or Element14 about the license.
  • mc6800
    mc6800 over 6 years ago in reply to shabaz +1 suggested
    I would add the following: once you have downloaded/installed/licensed it, email farnell for the *full* download link. This will be a file about 1.4GB in size, rather than the stub installer normally offered…
  • tony_tero
    tony_tero over 6 years ago +1 verified
    Hi Everyone, Thanks for all your answers. I ended up just using the incorrect email address to load the license. After a few days, there doesn't seem to be any downside to having done so. I will still…
  • clem57
    0 clem57 over 6 years ago
    Have you read this? How to transfer a license to a new computer
    It explains the details better than I can.
    Clem
  • tony_tero
    0 tony_tero over 6 years ago in reply to clem57
    Thanks, Clem.
    I had seen that, but I'm not sure that it is exactly my situation. I've never installed the license because the information associated with the license is incorrect. I'm trying to find out who to contact to correct the license info before I install it and potentially lock it into an incorrect email address.
  • tony_tero
    0 tony_tero over 6 years ago in reply to tony_tero
    0 shabaz over 6 years ago in reply to tony_tero
    Hi Tony,
    I don't use CircuitStudio, so I may have the wrong end of the stick, and maybe you've already tried this suggestion, but if you bought it in the UK, maybe it is possible to call the normal Farnell support line (which is responsive) and return the item, and then re-order, and then expense it? In other words, treat it like a return, and re-purchase on a different account, rather than deal as a licensing issue. Not ideal maybe, but perhaps it is a workaround unless someone comes up with a better solution.
  • mc6800
    0 mc6800 over 6 years ago in reply to shabaz
    I would add the following: once you have downloaded/installed/licensed it, email farnell for the *full* download link. This will be a file about 1.4GB in size, rather than the stub installer normally offered. At the same time, go into your account in CS, and download the .alf license file, so that future use can be done entirely without Altium/Farnell's involvement.
    Unfortunately, you will need to repeat the email/download process for any future versions you obtain (although that seems an unlikely problem at present). The alf file should work though.
  • tony_tero
    Hi Everyone,
    I will still try to move the license eventually and will post any useful information that I encounter here.
    -- Tony T
  • a.stepanov
    0 a.stepanov over 6 years ago in reply to mc6800
    Hi!
    Could you share link to offline installer ?
    I asked twice through software@element14.com email and didn't received any answer.
    https://www.element14.com/community/docs/DOC-88352/l/is-there-an-offline-installer-available-for-circuitstudio#comment-2…
  • tarribred61
    0 tarribred61 over 6 years ago in reply to a.stepanov
    Isn't it here>
    Access to older versions of CircuitStudio
    V1.5.2 should be there. This is in the right side of the web page for the discussions as recent documents.
    Nevermind; I guess this just has the installer setup files and not the off-line installer versions.
  • a.stepanov
    0 a.stepanov over 6 years ago in reply to tarribred61
    Yep, these links just for online-installer downloads.
  • tony_tero
    0 tony_tero over 6 years ago in reply to a.stepanov
    Has anyone ever actually received a reply from software@element14.com
    All signs point toward no...
