Raspberry Pi
Raspberry Pi
Blog PID based DC motor controller Project
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: vsp
  • Date Created: 6 Feb 2019 1:52 PM Date Created
  • Views 10566 views
  • Likes 10 likes
  • pid controller
  • motor drive module
  • raspbery pi
  • industrial automation
  • motor1
  • dcmotor
vsp
vsp
6 Feb 2019
This project demonstrates how to implement a PID based DC motor controller using Raspberry Pi. DC motor controller program is developed using Python. It consists of a GUI, RPM measuring, error detector, PID controller functions, and PWM generation function. The PID based closed-loop DC motor control system is one that determines a difference in the required speed and actual motor speed and creates a correction control signal to remove the error. To learn more about PID controller and DC Motor, go through PID based DC motor controller using Raspberry Pi and Motor Control 1 articles.
Required hardware:
Raspberry Pi
Raspberry Pi Display:
  • Farnell code: 2473872
  • Newark code: 49Y1712
RPM sensors:
   Slotted sensor:
  • Farnell code: 1386613
  • Newark code: 21M5159
Or
  PNP type proximity sensor: PR12-4DP
  • Farnell code: 1736862
  • Newark code: 10R6734
Procedure:
  • RPi.GPIO.22 is configured to get the feedback signal from the RPM sensor (voltage should less than 3.3V).
  • RPi.GPIO.23 is configured as an output. It provides PWM pulses for DC motor driver.
  • Connect the Raspberry Pi display and Input-Output pins.
  • Connect the Power adapter and power up the raspberry pi
  • Downloaded and install the GUIZERO library.
  • Download and run the DC motor controller code
  • GUI will open
  • If you are not connected feedback sensor to RPI, you can’t be able to set the PID gain values while running.
  • Adjust the required RPM using the sliders, now click the Start button.
  • Increase the P gain value.
  • The motor speed gradually increases, it will take some time to reach set RPM.
  • Increase the I-gain and D-gain values and see the system performance.
  • The speed of response depends on the PID gain values.
  • Load the motor using mechanical loading arrangement, and observe the set-RPM and run-RPM values, note load values to calculate the speed-torque characteristics of the motor.
  • Change the inputs (RPM and PID gain values) and observe the response of the motor.
  • After completion of your work press Stop button and close the project.
DC motor controller code:
        thisproject is designed to control the DC motor at a constant speed
        Connect  one PPR(Pulse Per Rotation sensor to RPi.GPIO 22
        GPIO.23 providees PWM pulses to drive DC motor (DC motor drive between motor and RPi)
import threading
import RPi.GPIO as GPIO
import time
from guizero import App, Box, Text, TextBox, PushButton, Slider
""" Input Output  configaration """
GPIO.setmode(GPIO.BCM)
GPIO.setup(22, GPIO.IN, GPIO.PUD_DOWN)
GPIO.setup(23, GPIO.OUT)                  # PWM pulse for MOSFET/IGBT
GPIO.output(23, 0)
""" Global variabels  """
Set_RPM =500                              # SET RPM value
feedback=0.0
previous_time =0.0
previous_error=0.0
Integral=0.0
D_cycal=10
Kp=0                                       # Proportional controller Gain (0 to 100)
Ki=0                                       # Integral controller Gain (0 to 100)
Kd=0                                       # Derivative controller Gain (0 to 100)
RunRPM=0
Loop_value=0
a=0
avr=0
i=0
GatePulse = GPIO.PWM(23, 100)
""" PID control function """
def PID_function():
    global previous_time
    global previous_error
    global Integral
    global D_cycal
    global Kp
    global Ki
    global Kd
    error = int(Set_RPM) -feedback                    # Differnce between expected RPM and run RPM
    if (previous_time== 0):
         previous_time =time.time()
    current_time = time.time()
    delta_time = current_time - previous_time
    delta_error = error - previous_error
    Pout = (Kp/10 * error)
    Integral += (error * delta_time)
    if Integral>10:
        Integral=10
    if Integral<-10:
        Integral=-10
    Iout=((Ki/10) * Integral)
    Derivative = (delta_error/delta_time)         #de/dt
    previous_time = current_time
    previous_error = error
    Dout=((Kd/1000 )* Derivative)
    output = Pout + Iout + Dout                  # PID controller output
    if ((output>D_cycal)&(D_cycal<90)):
        D_cycal+=1
    if ((output<D_cycal)&(D_cycal>10)):
        D_cycal-=1
    return ()
"""   RPM calculation function   """
def RPM_function():
    global feedback
    tc=time.time()
    while (GPIO.input(22)==False):
        v=0
        ts=time.time()
        time_count=ts-tc
        if (time_count>7):
            print("Feedback failed, Please make proper feedback connection")
            feedback=0
            return ()
    while (GPIO.input(22)==True):
        i=0
        ts=time.time()
        time_count=ts-tc
        if (time_count>7):
            feedback=0
            return ()
    v = time.time()                              # Stores the first pulse time
        s=0
        h=0
    h=time.time()                                # Stores the next pulse time
    w=(60/(h-v))                                 # MOTOR speed in RPM
    feedback = w
    return ()
def main_function():
    global D_cycal
    if Loop_value==1:
        t1 = threading.Thread(target=RPM_function)
        t1.start()
        t1.join()
        t2 = threading.Thread(target=PID_function)
        t2.start()
        t2.join()
        GatePulse.ChangeDutyCycle(D_cycal)
    else:
        GatePulse.ChangeDutyCycle(0)
print("Welcome To The Element14 Community!")
"""     GUI Functions     """
app = App(title="Welcome To The Element14 Community", height=700, width=500)
def change_Kp_value(slider_value):
    global Kp
    Proportional.value = slider_value
    Kp=int(slider_value)
def change_Ki_value(slider_value):
    global Ki
    Intregral.value = slider_value
    Ki= int(slider_value)
def change_Kd_value(slider_value):
    global Kd
    Deravative.value = slider_value
    Kd=int(slider_value)
def change_SetRPM_value(slider_value):
    global Set_RPM
    SetRPM.value = slider_value
    Set_RPM=int(slider_value)
def update_rpm():
    global avr
    global i
    global a
    global feedback
    if(Loop_value==1):
        if i<6:
            a+=feedback
            i+=1
        else:
            Run_RPM.value = int(a/6)
            a=0
            i=0
    else:
        Run_RPM.value = 0
def start_funcdtion():
    global Loop_value
    print("MOTOR controller is ON ")
    GatePulse.start(25)
    Loop_value=1
    Startbutton.toggle()
    Startbutton.repeat(1, main_function)
def Stop_function():
    global Loop_value
    Loop_value=0
    Startbutton.cancel(main_function)
    Run_RPM.value=00
    D_cycal=0
    Stopbutton.toggle()
    Stopbutton.toggle()
    print("Motor controller is Off")
def close_window():
    Stop_function()
    app.hide()
message = Text(app, text="PID based DC motor controller", color="saddle brown", size= 20)
Startbutton = PushButton(app, command = start_funcdtion, text="Start")
Startbutton.text_color="dark green"
Startbutton.text_size=15
Spase = Text(app, text= "  ")
SetRPM = Text(app, text= "Set_RPM")
SetRPM.text_color="blue"
SetRPM = Text(app, text= Set_RPM)
text_value = Slider(app, command=change_SetRPM_value, start=500, end=2000)
Proportional = Text(app, text= "Kp")
Proportional.text_color="DarkOliveGreen4"
Proportional = Text(app, text= Kp)
text_value = Slider(app, command=change_Kp_value, start=0, end=100)
Intregral = Text(app, text= "Ki")
Intregral.text_color="DarkOliveGreen4"
Intregral = Text(app, text= Ki)
text_value = Slider(app, command=change_Ki_value, start=0, end=100)
Deravative = Text(app, text= "Kd")
Deravative.text_color="DarkOliveGreen4"
Deravative = Text(app, text= Kd)
text_value = Slider(app, command=change_Kd_value, start=0, end=100)
Run_RPM = Text(app, text= "RunRPM")
Run_RPM.text_color="tomato"
Run_RPM = Text(app, text= RunRPM)
Run_RPM.repeat(1, update_rpm)
Stopbutton = PushButton(app, command = Stop_function, text="Stop")
Stopbutton.text_color="red"
Stopbutton.text_size=15
close_button = PushButton(app, text="Close Project", command=close_window)
#close_button.text_coller="yellow"
close_button.text_size=20
app.display()
  • rscasny
    rscasny over 7 years ago +3
    Thanks for this project. I was sure that the Pi could be used for a PID controller, but you showed it can. It would be interesting to see if anyone is using the PI is this mode. I appreciate your participation…
  • enesss
    enesss over 6 years ago +1
    Can you send the electronic diagram of the circuit please?
  • three-phase
    three-phase over 6 years ago
    Very neat project. Thanks for posting.
    Kind regards.
  • enesss
  • rscasny
    I appreciate your participation in the element14 community.
    Randall
