Raspberry Pi
Raspberry Pi
Blog Stepper Motor Control with Raspberry Pico PIO and DRV8711 driver- Part 6: autonomous PIO with speed control
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Date Created: 8 Apr 2025 8:09 PM Date Created
  • Views 3133 views
  • Comments 7 comments
  • raspberry
  • pico
  • pico_eurocard
  • PIO
  • stepper-motor
  • c++
8 Apr 2025
The Pico has a set of PIO co-processors. They are real-time controllers that can execute logic with deterministic timing. Ideal to run strict-timed sequences and state machines. And to implement extra peripherals.
In this series, I'm trying to use the PIO to control a TI DRV8711 stepper motor controller.
Follow up of  Stepper Motor Control with Raspberry Pico PIO and DRV8711 driver- Part 5: a more autonomous PIO .
In the previous post, I wrote my own PIO program that can independently do up to 2147483647 steps. And the PIO handles the DIR pin.
In this post I add speed control.
PIO code
.program stepper
.side_set 1
.define public DELAY 0
.wrap_target
start:
    pull block                  side 0 ; Pull from FIFO to OSR
    out pins, 1                 side 0 ; shift direction out of OSR and output to dir
    mov x, osr                  side 0 ; Copy rest of OSR to scratch X
    jmp !x start                side 0
    jmp x-- tocks_h             side 0
tocks_h:
    mov y, isr                  side 1 ; ISR contains number of tocks to hold level
count_high:
    jmp y-- count_high          side 1 [DELAY] ; keep high for tocks
   ; removed because we don't need a symmetrical pulse for a stepper
   ;  nop                         side 1 ; same size as low
tocks_l:
    mov y, isr                  side 0 ; ISR contains number of tocks to hold level
count_low:
    jmp y-- count_low           side 0 [DELAY] ; keep high for tocks
    jmp x-- tocks_h             side 0 ; not done, keep loopins
.wrap
The code is somewhat extended since the version of the previous blog. I added an additional counter y, that holds the amount of ticks to stretch each half of the pulses.
It receives the value from the input shift register at the start of each half of the pulse, then keeps the step pin looping in that state until the y is 0.
Once that happens, it moves to the other half of the period, and does the same. Repeat until the pulse train is completed.
Here is how the pulse stretching works. The top trace is with no delay. Each half cycle takes 3 clock ticks. 6 clock ticks per full pulse period.
In the second trace, the delay was set to 1. The two half pulses now take an extra clock tick: 4 each, 8 ticks per full period. This effectively lowers the pulse train frequency, and thus slows the stepper motor down.
This is the tail of a command. The PIO has generated the amount of steps that were requested. X register has counted down to 0, and the flow stops, until a new command is sent by the ARM controller:
In later versions of this project I removed the nop instruction. It was there to have a nice symmetrical pulse train with 50% duty cycle.
But a stepper driver doesn't need that. It's removed, and that's one more code position that's available for other code in the same PIO.
In total, it now uses 11 lines (even if you use 4 motors on the same PIO). That leaves 21 instructions free for other designs.
The impact of removing this line is that a full pulse now takes 1 PIO clock tick less. But with typical delay settings in the mid to high 4000 range (and each delay eating 2 clock ticks), this is neglectable. In the end, we'll have 50.0xx% duty cycle instead of 50.00000%.
If you want exact 50%, you could add a delay of 1 to this line - making the amount of clock ticks for both halves of a pulse exactly the same:
mov y, isr side 1 [1]
If you want to learn how these graphs were generated:  emulate Raspberry PICO PIO programs .
The main program
Here's the function that sets the speed:
void pio_pwm_set_delay(PIO pio, uint sm, uint32_t delay) {
    pio_sm_set_enabled(pio, sm, false);
    pio_sm_put_blocking(pio, sm, delay);
    pio_sm_exec(pio, sm, pio_encode_pull(false, false));
    pio_sm_exec(pio, sm, pio_encode_out(pio_isr, 32));
    pio_sm_set_enabled(pio, sm, true);
It stops the PIO, so don't use it (note to self) while the PIO is handling commands.
in main(), I  just added a loop to slow down from requested speed in 4 steps
   std::array<command, 6> cmd{{
        {200 * microstep_multiplier, true},
        {200 * microstep_multiplier, false},
        {400 * microstep_multiplier, false},
        {250 * microstep_multiplier, true},
        {350 * microstep_multiplier, true}}
    uint32_t sleep_time = 0U;
        wakeup_drv8711 w; // wake up the stepper driver
        sleep_ms(1); // see datasheet
        for (auto i = 0; i < 5; i++) {
            pio_pwm_set_delay(piostep, sm, i);
            for(auto c : cmd) {
                pio_stepper_set_steps(piostep, sm, c.steps, c.reverse);
                sleep_time += step_time(c.steps, i);
            sleep_ms(sleep_time + 500); // give enough time to complete the action
The granularity is still rough. With these slow signals (850 Hz as fastest that my motor can handle in full-step mode), each delay adds 2 extra ticks. One tick is added to each half of the pulse. It's a lot. Making it more granular is something for a next exercise ...
Here is a full sequence, where I set the direction to 1, 2 steps, and a delay of 1. First 5 instructions are fetching the command, dir and delay. Then it's a loop, executed twice.
The last instruction wraps up after we're done, and lets the state machine fetch the next command.
GitHub drv8711 project repository.
GitHub PIO stepper lib repository.
Next:  Stepper Motor Control with Raspberry Pico PIO and DRV8711 driver- Part 7: autonomous PIO with interrupt when done
Thank you for reading. I'll attach the project to the end of this post ...
  • ahsrabrifat
    ahsrabrifat over 1 year ago
    This is the first time I have come across PIO codes. Are these based on assembly language?
    Jan Cumps over 1 year ago
    I have a solution for this. A compromise for the developer, but works well. No changes to the PIO state machine.
    In my first approach, I brough down the clock to a reasonable speed for a stepper motor. By default, it churns out pulses at several MHz.
    By dividing the clock, it dropped to a range that makes sense for steppers.
    But that has as side effect, that each extra clock tick I steal to make the motor go slower, is rather big.
    What I've done now, is make the clock divider programmable by the end user. That way they can choose how fine the delay mechanism acts.
    At the cost of having to set a delay that's in the 1000s. Each delay step will add 2 clockticks of the frequency the PIO runs at to each pulse's period.
    So if you set a high clock (say: keep PICO clock, or divide it by 2), you have to set high delays, but they are very fine and give precise control.
    If you set that divider to a higher value, you may not have to use delay at all, or lower values of delay. But the granularity at each delay step becomes rough.
    In the end, there is no efficiency gain for one vs the other. It's a choice.
    Here is an example function that steps with delay:
    void demo_with_delay(const std::span<command> & cmd, uint32_t delay) {
        pio_pwm_set_delay(piostep, sm, delay);
        for(auto c : cmd) {
            // printf("Steps = %d\n", c.steps);
    and code that uses it:
            demo_with_delay(cmd, 4300);
            sleep_ms(2000); // give enough time to complete the action
            demo_with_delay(cmd, 7000);
            sleep_ms(3000); // give enough time to complete the action
            demo_with_delay(cmd, 9000);
            sleep_ms(4500); // give enough time to complete the action
    I divided the PIO clock by 2 for this example:
    const float clock_divider = 2.0; // works well for 8 microsteps
        uint offset = pio_add_program(piostep, &stepper_program);
        stepper_program_init(piostep, sm, offset, dir, clock_divider);
        pio_sm_set_enabled(piostep, sm, true);
