Raspberry Pi Forum Raspberry Pi Model B Cases?
  • Locked Locked
  • Replies 180 replies
  • Subscribers 727 subscribers
  • Views 20340 views
  • raspberry
  • help
  • pi
  • b
  • 3d_printing
  • model
  • case
Wwessex
Wwessex over 14 years ago
I was wondering if anyone knows of a case for the Model B?
    e14 Contributor over 14 years ago in reply to recantha
    Michael,
    http://elinux.org/RPi_Cases - you should contribute this.
  • recantha
    recantha over 14 years ago in reply to e14 Contributor
    Roland, yes, of course, you're right!
    Last time I was on that page they had next-to-nothing on there.
    Thank you for the pointer!
  • davesl
    davesl over 14 years ago in reply to e14 Contributor
    The price I was figuring was....Zero.  I was planning to upload the STL file when I received my PIs and made some final adjustments.  If people want, I will upload the STL file as it is now.
    The price is whatever you spend on getting the case made.
  • davesl
    The holes in the case for venting the heat was in the future plans.  Chuck has told me that heating is not an issue so far.  Holes underneath would probably do no good as the PI sits in a groove on the inner perimeter of the sides.  The air flow from bottom to top is pretty well blocked.  As far as putting them in the top cover, that is the plan.
    The top and bottom covers snap off and are easily replaceable and engraveable in case you want to do something like a "Chuck's PI" design.  You could have a different cover design as your mood suits.
  • jobrook
    jobrook over 14 years ago
    Raspberry Pi enclosures available from Farnell Element14:
    Order Codes
    White - 2113797
    Black -  2113798
    Clear -  2113799
    Jo
  • morgaine
    morgaine over 14 years ago in reply to jobrook
    Well spotted Jo!
    Here are the direct links, UK site:
    • White - http://uk.farnell.com/multicomp/mc-rp001-wht/enclosure-raspberry-pi-white/dp/2113797?Ntt=2113797
    • Black - http://uk.farnell.com/multicomp/mc-rp001-blk/enclosure-raspberry-pi-black/dp/2113798?Ntt=2113798
    • Clear - http://uk.farnell.com/multicomp/mc-rp001-clr/enclosure-raspberry-pi-clear/dp/2113799?Ntt=2113799
    And the datasheet link is http://www.farnell.com/datasheets/1640958.pdf .
    Morgaine.
  • recantha
    recantha over 14 years ago in reply to morgaine
    Hmmm.... Dull, but cheap. I like them!
  • fustini
    fustini over 14 years ago in reply to morgaine
    Very interesting... Newark element14 links for North Ameria:
    http://www.newark.com/multicomp/mc-rp001-clr/enclosure-raspberry-pi-clear/dp/07W8936?Ntt=2113799
    http://www.newark.com/multicomp/mc-rp001-blk/enclosure-raspberry-pi-black/dp/07W8934?Ntt=2113798
    http://www.newark.com/multicomp/mc-rp001-wht/enclosure-raspberry-pi-white/dp/07W8932?Ntt=2113797
  • Montala
    Montala over 14 years ago in reply to morgaine
    All three models are showing "Out of Stock" on the UK website at the moment... although I would think that they are only cheap if you are ordering them at the same time as a Raspberry Pi, and not on their own at a later date.
  • jhaas
    jhaas over 14 years ago in reply to Montala
    Looks like its out of stock in the US too.  Per Newark, they will have available late October.
