Raspberry Pi Forum Raspberry Pi just assembled
  • Replies 33 replies
  • Subscribers 710 subscribers
  • Views 3524 views
I have just assembled the Pi and on connection only the red indicator is lighting up. The green has not flashed. The card I purchased had the OS already burnt on which came from the UK..Have taken it OUT  and started again several times but still not working.Be grateful for any suggestions especially as this is the first one in our area in Qld. Aust
  • bodgy
    bodgy over 14 years ago
    The green LED flash could be faint.  What type of power supply are you using, and what is its  nominal voltage/current specifications?
    Is your Pi one of the latest batch or an earlier one and it is just the card you've recently received?
    If you have it attached to a monitor does the screen show any activity at all?
    Are you attached to a wired LAN or trying WiFi?
    If you have an SD cardreader, do you see in Winda FAT32 partition and then one that Windows ignores or if in Linux a number of partitions?
    I live in SE Qld, so might be able to personally help you if you need it. My Pi works OK and I've 4 different SD cards that are Pi working at the moment.
    Colin
    e14 Contributor over 14 years ago in reply to bodgy
    Thanks for the comment Colin.Everything came from the U.K. No green light at all. Received the Pi 3 weeks ago(ordered in June). The power supply  is 2000ma output 5v.. The card Samsung 8gb with the OS already written to it. Received both today. The screen ( new 15.6" TV with HDMI) shows 'No Signal'. All connections checked many times!!!!! I do not have a card reader.. Would really appreciate assistance on this one.We live at Little Mountain..Caloundra...email being johnjuliaw@gmail.com Cheers John
  • GreenYamo
    GreenYamo over 14 years ago
    John,
    Have you seen this link ? http://elinux.org/R-Pi_Troubleshooting#Red_power_LED_is_on.2C_green_LED_does_not_flash.2C_nothing_on_display
    Sounds like the iamge could be corrupt, or the power supply isn't up to the job (many aren't)
    Steve
  • wallarug
    wallarug over 14 years ago in reply to GreenYamo
    Check that your power supply can provide 5v@1A.  That is the problem with most people.
    e14 Contributor over 14 years ago in reply to GreenYamo
    Thanks for the comment Steve, Will now follow that site up.Also will check out the power supply again .Have been in touch with the supplier in UK who is sending out another card and power supply.Good service!!!!
    Will post outcome in due course. Cheers John
    e14 Contributor over 14 years ago in reply to wallarug
    Thanks for the comment Fergus. Checking that out again and kindly see my reply to Steve.So hope all may soon be well after all this wait!!!!
  • johnbeetem
    johnbeetem over 14 years ago in reply to GreenYamo
    Steve Read wrote:
    John,
    Sounds like the image could be corrupt, or the power supply isn't up to the job (many aren't)
    John W: Do check the Troubleshooting guide Steve links to.  Lots of RasPi problems are due to iffy power supply and/or iffy Micro USB cable.  Some Micro USB cables have thin conductors which cause too much voltage drop.  Best way to check it out is to measure TP1-TP2 as described in the Troubleshooting guide.
    Also, take a look at the SD Card contacts carefully with a magnifier.  We have had reports of bent SD Card contacts.
    Also, be sure you have pushed the SD Card all the way in.  It may require some force, so look at how the SD Card socket is designed and make sure your card is all the way in.
    e14 Contributor over 14 years ago in reply to johnbeetem
    Many thanks for your comments John. I have printed out that link Steve suggested.The SD card appears to be inserted ok & the wire acting as a spring works well.However when I inserted the card into my Windows machine the computer suggested to format the card first!!!!! Upon cacellation it then stated unknown.So unable to check what is on the card.Also tried with no cables connected etc. but no difference.Am awaiting a friend to arrive with a meter to check the power supply...mine is us!!Thanks again      John
    The card with the pi image contains a small fat partition with the kernel and the bootfiles. That should be visible when you check the card on a windows system. So, you have a drive letter with some files in it. The partition is only 70 - 80 MB in size. The green led is comparable with the harddisk activity indicator of a pc. It should flash when the pi is accessing the sd card.
    G'day Luc,
    When I place the card in a Windows system I get the following:
    'you need to format the disk in drive I: before you can use it'
    Then upon cancelling that the following message appears;
    ' The volume does not contain a recognised file system. Please make sure that all required file system drivers are loaded and that the volume is not corrupted'
    Thus I am unable to see what is on the card.
    No green light whatsoever appears in any shape or form!!!
    Thanks for your comment.
