Raspberry Pi Forum Raspberry Pi just assembled
  • Replies 33 replies
  • Subscribers 710 subscribers
  • Views 3536 views
I have just assembled the Pi and on connection only the red indicator is lighting up. The green has not flashed. The card I purchased had the OS already burnt on which came from the UK..Have taken it OUT  and started again several times but still not working.Be grateful for any suggestions especially as this is the first one in our area in Qld. Aust
    Some older cardreaders can't handle sd(hc) cards. Usually everything with a size bigger than 2Gig is SDHC. There are exceptions, but you hardly find them on the market.
    There exist a program for pc called winhex that is able to access an usb drive on a very low level (sector based)
    You can download a free version of it. If that program is unable to access the sd(hc) card, it's either a bad card or your cardreader is not up to the job. Most computer shops sell low cost sd(hc) cardreaders.
    The message from windows that the card needs formatting means that windows can't locate a valid partition on the card. I hope this helps.
  • GreenYamo
    GreenYamo over 14 years ago in reply to e14 Contributor
    Hello John,
    That sounds a lot to me like a corrupt image on the card - as Luc says above, you should be able to see a small partition on your Pc on the card, and the fact you are not getting the green light makes me think the Pi can't see the card either. I'd be tempted to either 1) Borrow an SD card from a friend, download an image from the Raspi.org's web site and try that http://www.raspberrypi.org/downloads or use 2) the card you have already got and re-image that. Thing is, you have paid a premium to get the card with the image on it, and if re-imaging works, you have just performed the very job you paid the premium for :-( (And it will be difficult to say it doesn't work, when it does, if you see what I mean.
    Borrowing a new card and seeing if that works with a fresh image is probably the way I would go, if that is OK is proves that the card is corrupt (and the other components are OK)
    Steve
    Thanks Luc, Have to go and get the voltage of the charger checked so will have a look for a card reader. A friend has just received his Pi and card but is away for a few weeks. The suppliers are kindly sending me a new card and power supply.
    Cheers   John
    e14 Contributor over 14 years ago in reply to GreenYamo
    G'day Steve,
    Thanks for the comments and please see the reply to Luc. Will wait for the new card to arrive and or my friend returns from holidays!!!! A bit longer wait but there it is!!!!! Hopefully the power supply will be sorted out too
    Kind regards
    Steve & Luc,
    Thought you may be interested to know that today had the power supply checked and is on 5v but no output figure  available! but could not get that myself later!!!! Purchased a card reader ( despite one already in the computer) and received the same answer as before in Windows. As I have a separate partition in Windows for Mandriva tried it out there. The device was accepted but inserting the card nothing happened. So appears must be the card. So decided to try writing one myself . I already have  the .img file of Debian. Tried to download the Win32 DiskImanager but was advised it would not download but try again later!!!! This went on most of the day and now given up for the time being!!! I also have the Oracle Virtual  Box in Windows with Debian but no joy there either.You may wonder why I bother with this but I joined a computer club here earlier this year to learn Linux ( to keep the brain active!!) and this cropped up in our group and followed it through hoping to learn more on elementary programming.Guess it will sort itself out in time!!!
    Cheers to you both and appreciate your comments........John
    Sad to hear.
    And I thought I was having problems with my Pi....
    I would suggest to try to format the sd card under windows. If it doesn't work, the sd card is really fubarred, and you will need another sd(hc) card. If it works, you should be able to copy files to it afterwards. (Not usefull for the Pi, just to know if the card is fine)
    There are also instructions to write the debian image to the card under linux. Maybe that's an option if the download of diskimanager isn't working.
    You can use your mandriva or your debian. Virtualbox has an option to forward usb devices to the client os.
    I can also upload diskimanager on mediafire, so you can get it from there. Just let me know if you want to try that road.
    The Pi sure keeps your brain active, but be aware it can cause hart rithm disturbance, due to all it's issues.
    G'day Luc,
    Good to hear from you.Still no success in downloading the filemanager.So now decided to wait on the new card from the supplier and also when this friend comes back from leave as understand he may have written a few Cards or has the facility to do so.However intend to get another blank sdhc card today just in case!!!!! Would you care to drop me an email at my home address as to get to this page was quite a feat!!!
    Will watch the heart rythm...sure moves it along!!
    Cheers......John
  • GreenYamo
    Hello John, If you've not had any success by the weekend leave a message here and i'll upload my copy of the win32diskimager to dropbox and you can download from there.
    Steve
    http://www.mediafire.com/download.php?3nr88hap9wbl7ru
    Previous link should get you the win32diskimager.
    If you copy an image to the card, you should see the 75MB fat32 boot partition and it's files. It requires to remove the card and insert it again. You can only mount the second ext4 partition on a linux system.
