Raspberry Pi Forum RPi with 512mb Memory?
  • Replies 144 replies
  • Subscribers 715 subscribers
  • Views 23497 views
wallarug
wallarug over 13 years ago
I just found this: http://au.element14.com/raspberry-pi/raspbrry-modb-512m/sbc-raspberry-pi-model-b-512mb/dp/2191863
Is this a raspberry pi with 512Mb RAM or is this a joke.
  • wallarug
    wallarug over 13 years ago in reply to e14 Contributor
    Mike Buffham wrote:
    Hi Pete
    Looking at your post I would also think you should have received a 512MB unit
    You may have doen this but can you run the following command and check the code number that the board returnsd
    cat/proc/cpuinfo
    If you’re running revision 1.0 you will see code numbers 2 or 3
    If you're running revision 2.0, 256MB you will see code numbers 4 or 6.
    If you are running the Raspberry new Pi Model B (512MB) Revision 2.0 you will see code numbers 13 or 14
    Mike
    Will there be a 256 rev2 with code 5?  or has this been abandoned?
    Its just more crap like the first time around. This time, they can do without me. There are alternatives available that have the same or better capabilites. This whole register and wait nonsense just stupid.
  • jamodio
    jamodio over 13 years ago in reply to e14 Contributor
    The Rev 2.0 board just arrived, Samsung part number is K4P4G324EB-AGC1, board says made in UK, no indication on the box about version or memory size. FPC connectors look cheaper than the ones on previous boards.
    Good thing, the LDOs are from ON Semi and not from cheap-o-china.
  • wallarug
    wallarug over 13 years ago in reply to jamodio
    I guess you know that is a 512mb version.
  • jamodio
    jamodio over 13 years ago in reply to wallarug
    Obviously I do.
  • wallarug
    Just noticed on my Rev2 512mb that if you touch the USB controller chip, it shorts out the USB circuit. Is this a flaw? Or is it just it should not be touched?
  • GreenYamo
    GreenYamo over 13 years ago in reply to wallarug
    My 512Mb Pi arrived yesterday, will only have a chance to play at the weekend. Will try touching the usb controller and see what happens.
    Heck, I like to live dangerously, might touch it with my tongue and see what happens !
  • jamodio
    jamodio over 13 years ago in reply to GreenYamo
    The should start producing the boards with raspberry scent on the silk screen ink
  • johnbeetem
    johnbeetem over 13 years ago in reply to wallarug
    Sounds like a flaw.  As long as you've touched ground somewhere on the board (e.g., the USB or Ethernet shell) before lightly touching a chip package, it shouldn't have any effect other than perhaps a burned finger-tip.  If the USB chip fails if you touch it, IMO the most likely cause is a hair-line break in a PCB trace so that if the board flexes the trace opens.  It could also be an iffy solder joint, though those are more likely to open when you're not pressing down on the chip.
    You could have an effect if you touch the LAN9512 crystal oscillator pins.  Also check the solder joints on crystal X1 which is on the back side of the PCB near the LAN9512.  Crystals are sensitive to being touched, especially if not well soldered.
    Can you be more specific about "shorts out the USB circuit"?  What's shorting to what, or are you just saying USB stops working, and if so, for how long?
    Oh, and what's under the RasPi?  If it's on a mildly conductive surface pressing down could cause mischief.
    e14 Contributor over 13 years ago in reply to jamodio
    Mine was waiting for me when I got home last night. I haven't had time to do anything with it yet. What OS are you going to put on yours??
    Fun stuff. . . learned about it, bought it, and got it - - all within a week!  Just have to wait a couple of days to really get in to it.
    Best
    Peg
