Raspberry Pi Forum Questions about the Raspberry Pi
  • Subscribers 704 subscribers
  • Views 334 views
  • raspberry
  • pi
  • connector
  • hdmi
  • quesion
  • about
  • raspberry_pi_getting_started
freddruppel
freddruppel over 12 years ago
Hello everyone !!!
I have a question about the raspberry pi : Is it possible to desolder the HDMI connector from the Raspberry Pi and extend it with wires ?
My Pi model is "Raspberry Pi model B rev 2.0".
Thank you for your answers !!!
Regards, Frédéric Druppel
P.S.: Feel free to correct my English if needed !!! image
    Hello sir,
    From looking at the HDMI port on the board it looks like it would be difficult because the ground shielding is soldered into the board with lead solder and the pins are very small. It may be possible though if you had a high temperature soldering iron that could melt the lead free solder and a very small soldering tip so you could re-solder the pins properly. Also it will work better if you do not use lead free solder to solder  your wires and after the wires are soldered to the port and the board cover the connections with hot glue to prevent shorts.image
