Raspberry Pi Forum Can I connect a pcb card edge connector to a raspberry pi?
  • Replies 11 replies
  • Subscribers 677 subscribers
  • Views 1642 views
  • raspberry
  • help
  • pi
  • raspberrypi
  • linux
I am looking to make a Gameboy type device and would like to add a cartridge function to it so I was wondering if I could use a pcb card edge connector for this?
If not is there anything else I could use?
  • gadget.iom
    0 gadget.iom over 10 years ago
    Can you be little more specific?
    0 Former Member over 10 years ago in reply to gadget.iom
    What do you mean by more specific?
  • gadget.iom
    0 gadget.iom over 10 years ago in reply to Former Member
    Well, is the raspberry pi the host (console)? and if so, what is the cartridge likely to contain?
    yes the raspberry pi would be the host, I was thinking the cartridge could contain a retro game or something like mame
  • gadget.iom
    Well if that's what you're aiming to achieve, you might want to read this article
    http://www.cnet.com/au/how-to/create-a-retro-game-console-with-the-raspberry-pi/
    They use USB sticks to transfer the ROMs, though you could experiment with taking the pins from a USB stick to the pins of a card edge connector, or even putting some EEPROM onto a board with an edge connector. The card edge receptacles are commonly available. e.g.. http://uk.farnell.com/te-connectivity-amp/5-5530843-0/connector-card-edge-rcpt-20pos/dp/2396188
  • Problemchild
    0 Problemchild over 10 years ago in reply to gadget.iom
    It's interesting as an Idea but a bit useless unless you specifically need to use an old style cart for some reason.
    Otherwise you would get a much simpler and reliable connector using the USB and say a memory stick and have 1000's of games on it for a few bucks
  • gadget.iom
    0 gadget.iom over 10 years ago in reply to Problemchild
    I would've thought the same, but the question related to card-edge connectors so I thought I'd personalise my answer around this approach.
  • Problemchild
    Tristan as a good part of this will be the physical build why not build a small USB hub into your design then have your carts still look like carts but in fact just have a USB connector on them..Basically just dress up a USB in bulky cart clothing (£D printer time maybe??)
    0 Former Member over 10 years ago in reply to Problemchild
    Thanks. I think I will do this
