Raspberry Pi Forum How to enable hotspot in raspberry pi zero 2w with network manager(nmcli).
  • Subscribers 696 subscribers
  • Views 5242 views
  • raspberry pi zero 2w
  • nat
  • pi
  • hotspot
  • robotics
  • raspberry pi zero
  • ssh
  • dns
  • nmcli
  • raspberry pi
  • network manager
  • rpi
  • networking
  • raspeberry_pi_accessories
  • iptables
  • ip-forwarding
  • linux
  • raspberry_pi_getting_started
pooja_14
pooja_14 over 2 years ago
i found this command in official raspberry pi website.
sudo nmcli device wifi hotspot ssid <example-network-name> password <example-password>
but when i connect other devices with this ssid and password it does get connected but no internet. and somehow it disconnects my SSH session.
I enabled IP forwarding, checked Network manager status, made sure hostapd and dnsmasq is not enabled(not even installed) and verified DNS configuration.
This is my NAT(nftables)
#!/usr/sbin/nft -f
flush ruleset
table ip filter {
chain input
type filter hook input priority 0; policy accept;
chain forward
type filter hook forward priority 0; policy accept;
iifname "wlan0" oifname "wlan0" accept
chain output
type filter hook output priority 0; policy accept;
table ip nat {
chain prerouting {
type nat hook prerouting priority 0; policy accept;
chain postrouting {
type nat hook postrouting priority 100; policy accept;
oifname "wlan0" masquerade
I have connected raspberrypi with headless setup, configuring the device using SSH.
I coudn't figure out the problem.
  • feiticeir0
    0 feiticeir0 over 2 years ago
    Hi !
    How does the other devices get their IP address ? Is it manual ? If not, you need a DHCP server to give IP addresses.
    Despite they connect to the wifi network, they still need an IP address.
    One quick way is to manually configure the IP address - if you're going to connect few devices (maybe two or three),manual IP address will work.
    If not, a DHCP server - on the same network - probably configured in the RPI Zero 2 W (where the hotspot is) is the best option.
    THE DHCP server will get you an IP address, the DNS and the Gateway - the important thing for the internet - the computer knows how to get out.
    You can use DNSMasq for that . Check this sites:
    https://raspberrytips.com/dhcp-server-on-raspberry-pi/
    https://forums.raspberrypi.com/viewtopic.php?t=341894
  • pooja_14
    0 pooja_14 over 2 years ago in reply to feiticeir0
    Thank you. Actually i found my mistake, it requires two interfaces. Here i'm only using wlan0, so I added a virtual interface wlan1 for hotspot while wlan0 is the preconfigured interface(wifi) from where i get internet access.
  • colporteur
    0 colporteur over 2 years ago
    sudo nmcli con add type wifi ifname wlan0 mode ap con-name accesspoint ssid “AP_Office” 802-11-wireless.band bg 802-11-wireless.channel 3 wifi-sec.key-mgmt wpa-psk wifi-sec.psk “somepasswordyouwillrecall” ipv4.method shared ipv4.address 192.168.6.1/24 ipv6.method disabled autoconnect true
    The network manager non-interactive command above will create an Access Point. The commands are documented in
    docs.redhat.com/.../Red_Hat_Enterprise_Linux-9-Configuring_and_managing_networking-en-US.pdf
    I have it working on both lite and full versions of bookworm both 64 & 32 bit.
    The RH document talks about dnsmasq providing DHCP to the AP. This is true even if dnsmasq package supported in systemd is not installed.
