Raspberry Pi Forum Professional and Industrial Users of Raspberry Pi
  • Replies 14 replies
  • Subscribers 710 subscribers
  • Views 3929 views
e14phil
e14phil over 8 years ago
Hi all!
I would love to hear your thoughts on using the Raspberry Pi 3 B+ in Professional and Industrial Use Cases.
The New Raspberry Pi 3 B+ has been intentionally built to make it easier/less expensive to be signed off with simplified Radio Module Conformity and the new PoE hat on its way, allowing for headless operation, Power over Ethernet and, Boot over ether net.
Do you use your Raspberry Pi in an industrial use (IIoT)?
Have you built the Raspberry Pi into a product? Was it easy to do?
What are your thoughts on Raspberry Pi's efforts to reduce time and money making the RF area meet Modular certification?
If you have not? What is deterring you?
New RF  Conformity documentation:
https://www.raspberrypi.org/documentation/hardware/raspberrypi/conformity.md
Interview with Ben and Roger
Discussing the new board and benefits of the RF module and PoE.
Eben Upton and Roger Thornton Interview: Raspberry Pi 3 Model B+
PoE Hat (Pre-order available now):
Raspberry Pi 3 Model B Plus (B+) PoE (Power Over Ethernet) Hat
The official Power over Ethernet (PoE) add-on board for the Raspberry Pi 3 Model B+! Use this HAT to power a Raspberry Pi via an Ethernet cable, removing the need for a separate power supply, an ideal solution for embedded and IoT projects. For Raspberry Pi 3 Model B+ and onwards, an 802.3af compliant POE injector, switch, or router device is required (not included).
  • Power over Ethernet 802.3af compliant
  • Power over Ethernet Boot (PXE Boot)
  • Class 2 device
  • Fully isolate Switched-Mode Power Supply (SMPS)
  • 36-56V Input Voltage
  • 5V Output Voltage
  • Supplies up to 2.5A
  • Fan Control
  • Plug-and-play compatibility with Raspberry Pi 3 Model B+
Best of all, it fits within the official Raspberry Pi Case!
    shabaz over 8 years ago
    Hi Phil!
    The PoE board will make it far more usable, because the Pi has always lacked a decent power connector. Now, finally a reliable connection can be made. Even if a wired connection is not essential, PoE can still be an effective way to get power to a device. Plus, an electrician isn't required to wire it in, so it can be cheaper to install. We use Pi's a lot for prototyping ideas. And I'm aware of firms producing devices which consist of a Pi internally, and are essentially software-based products, but they require somewhere to run, in specific locations with a certain price-point, and the Pi makes that possible. Here is an example: https://netbeez.net/product/
    • Vote Up +6 Vote Down
  • e14phil
    e14phil over 8 years ago in reply to shabaz
    Thats great Shabaz!  We are always interesting in hearding of people that use them for prototyping and even production.
    Netbeez seem pretty cool, they really could run their products via PoE.
    Do you have any other nameable examples that you know of?
    e14 Contributor over 8 years ago
    Hi Phil,
    we, at PONF GmbH, are developing the PONF Multiback Open Camera: a camera that shoots digital and film - www.ponfcamera.com
    The camera has interchangeable backs:one for film, one for digital.
    The digital back is based on Raspberri PI 3, we are testing it with the Compute Module and now with the 3 B+. We use Sony full frame (36 and 24 MP) or APS-C (24 MP) sensors as image sensors.
    We are in our early prototyping phase, and it's always interesting seeing advancements in the board !
    As the project is an Open Source one, it would be interesting having some feedback and cooperation in the development.
    • Vote Up +7 Vote Down
    shabaz over 8 years ago in reply to e14phil
    Unfortunately none that I could name (although I've suspected a few firms are using it in their products, but the've never specified it, for example with startups. Sometimes they like to hide the specifics).
    IDEA London may be an organization worth reaching out to, since you're already working closely with Startupbootcamp. I believe Startupbootcamp will have close contacts with IDEA London to get you connected. They tend to work with 'next level' startups, so there is a good chance that some are using the Pi, or could benefit from it.
  • e14phil
    e14phil over 8 years ago in reply to e14 Contributor
    Hi Raffaello!
    I know you have been working with Enrico. I have been following your build it is very very interesting!
  • ninjatrent
    ninjatrent over 8 years ago
    Hi Phil,
    Great post. Do you have any information regarding when the Raspberry  Pi 3 B+ will be in stock at Newark?
    Trent
  • e14phil
    e14phil over 8 years ago in reply to ninjatrent
    Hey Trent,
    I don't have a set date as they are being sent out in order of when they are ordered, pre-orders are currently open as we sold out of our first few batches very quickly.
    (As always is the case with new Raspberry Pi!)
    Phil
    michaelkellett over 8 years ago in reply to e14phil
    Hello Phil,
    The main thing about the RPi that puts one off using it in industrial or commercial applications is the perception that it is aimed at and marketed to the hobby and education market.
    To change that perception the following would be required:
    1) proper technical specification including BOM, schematic, operating temperature range, working environment  (humidity, vibration electrical etc) and reliability data.
    2) long term availability commitment
    3) predictability, of supply and ideally of development plans (Your own comment in the reply above rather states that case - product released but not actually purchasable.)
    4) some way of building and developing a decent business relationship with the supplier, the RPi people don't put out good vibes in this respect (A business only distribution and support portal might be the answer.)
    Take a look at this page on the RPi website:
    https://www.raspberrypi.org/products/
    It's the RPI product page but it's so totally hobby orientated, like the bulk of their website - if you based a product on the RPI then you are betting the project (and quite possibly your company) on it - the RPI Org image just doesn't feel right for that.
    • Vote Up +8 Vote Down
  • ipv1
    ipv1 over 8 years ago
    Hi e14phil,
    I am currently working on a project that makes use to the RPi for a number of reasons. The device is to be used in Highway Automation and Control Solutions and there are more than once solutions planned for this.
    The idea is to have a board that can be programmed in C++ or even C# and since many other boards have pathetic support, the RPi was the obvious choice. We are currently employing it in a product on site and have a custom addon board that compliments the functionality. I cannot disclose a lot but I can say in most applications, wireless has not been required till date for us. PoE and Boot from ethernet is definitely a good feature and we have our own optical converter of sorts to allow for remote location connectivity.
    I image even with Industrial IoT, wireless connectivity would not be a feature a lot of my clients look for. The compute module is definitely the right way to go but the newer B+ may have an edge with the better thermal dissipation. I have had to use the RPi 1 in cases where the product was battery powered.
    Just my two cents worth.
  • couchie
    couchie over 8 years ago
    POE for an RPI is genius! This is a perfect fit for a project I'm working on! I have one on the way via UPS now and can't wait to dive in!
