    • Avnet Boards Community
Raspberry Pi
Raspberry Pi
Documents Which accessories are compatible with the New Raspberry Pi 4 Model B?
  • Author Author: e14phil
  • Date Created: 19 Jun 2019 1:28 PM Date Created
  • Last Updated Last Updated: 25 Jun 2019 4:10 PM
  • Views 10379 views
  • Comments 15 comments
NEW! Raspberry Pi 4
Technical Specifications | GPIO Pin Out | Unboxing Video | Benchmark Tests | Comparison Chart | FAQ | Quiz | Pi Accessories | Pi Projects | RoadTest
To give you some context to this post, first, meet the new Raspberry Pi 4 Computer.
It has the same physical almost "Credit Card Size" footprint but some major changes to the I/O which could interfere with your accessory choices.
Unsupported video URL format.
Raspberry Pi 4 Model B 1GB RAMRaspberry Pi 4 Model B 2GB RAMRaspberry Pi 4 Model B 4GB RAM
  • 1.5-GHz Quad Core Cortex-A72
  • Dual Micro-HDMI (Up to 4Kp60)
  • 5V/3A USB type C
  • 2x USB 3.0 and 2x USB 2.0
  • 1GB RAM
RASPBERRY PI 4 MODEL B, 1GBRASPBERRY PI 4 MODEL B, 1GB
  • 5V/3A USB type C
  • 2GB RAM
RASPBERRY PI 4 MODEL B, 2GBRASPBERRY PI 4 MODEL B, 2GB
  • 5V/3A USB type C
  • 4GB RAM
RASPBERRY PI 4 MODEL B, 4GBRASPBERRY PI 4 MODEL B, 4GB
Raspberry Pi is going through physical changes
The Older Raspberry Pi 3 Model B+The NEW Raspberry Pi 4 Model B
So what has changed?
New USB 3 Ports and the (Now Gigabit) Ethernet Port has changed sides!
Micro USB and Full Size HDMIDual Micro-HDMI and USB-C Type
Will my old case fit the New Raspberry Pi 4?
Fairly unlikely that your old case will fit and if it does It likely wont have I/O holes in the right places for the new Micro HDMI, USB 3, USB C and Ethernet
Will I need a new charger for the Raspberry Pi 4?
Yes. This one swap is the greatest positive, you are now less constrained and less likely to get "Brown Outs" caused by power hungry peripherals.
Will my GPIO Hat work on the new Raspberry Pi?
Very Likely! The Raspberry Pi 40Pin GPIO is built to be backwards compatible! You can double-check this here: Raspberry Pi 4 Model B Default GPIO Pinout with PoE Header
Will I need a new version of the PoE hat?
No, the PoE HAT designed for the Raspberry Pi 3 Model B+ is fully compatible with the Raspberry Pi 4 Model B.
element14 Recommended Accessories
Due to the change in board layout and the new USB Type C power connector, we recommend the following accessories.
USB Power Supplies
USB C Power Supplies
USB C Power SupplyManufacturer
5.1V, 3A USB-C PSU - UK WHITERaspberry PiBuy NowBuy Now
5.1V, 3A USB-C PSU - EU WHITERaspberry PiBuy NowBuy Now
5.1V, 3A USB-C PSU - US WHITERaspberry PiBuy NowBuy Now
5.1V, 3A USB-C PSU - AU WHITERaspberry PiBuy NowBuy Now
5.1V, 3A USB-C PSU - UK BLACKRaspberry PiBuy NowBuy Now
5.1V, 3A USB-C PSU - EU BLACKRaspberry PiBuy NowBuy Now
5.1V, 3A USB-C PSU - US BLACKRaspberry PiBuy NowBuy Now
5.1V, 3A USB-C PSU - AU BLACKRaspberry PiBuy NowBuy Now
Micro HDMI to HDMI Cable
Micro HDMI to HDMI CableManufacturer
1M MICRO-HDMI TO HDMI CABLE - WHITERaspberry PiBuy NowBuy Now
2M MICRO HDMI TO HDMI CABLE - WHITERaspberry PiBuy NowBuy Now
1M MICRO-HDMI TO HDMI CABLE - BLACKRaspberry PiBuy NowBuy Now
2M MICRO HDMI TO HDMI CABLE - BLACKRaspberry PiBuy NowBuy Now
Compatible Cases
Compatible Cases
Raspberry Pi 4 CasesManufacturer
Official Pi 4 CasesRaspberry PiBuy NowBuy Now
RASPBERRY PI 4 CASE - BLACKMulticomp ProBuy NowBuy Now
RASPBERRY PI 4 CASE - WHITEMulticomp ProBuy NowBuy Now
RASPBERRY PI 4 CASE - CLEARMulticomp ProBuy NowBuy Now
RASPBERRY PI 4 CASE - REDMulticomp ProBuy NowBuy Now
RPI 4 CASE W/PWR BUTTON - BLACKMulticomp ProBuy NowBuy Now
RPI 4 CASE W/PWR BUTTON - WHITEMulticomp ProBuy NowBuy Now
RPI 4 CASE W/PWR BUTTON - CLEARMulticomp ProBuy NowBuy Now
RPI 4 CASE W/PWR BUTTON - REDMulticomp ProBuy NowBuy Now
Want to know more?
Meet The New Raspberry Pi 4 Model B - element14 Presents
Raspberry Pi 4 Model B - Technical Specifications
Raspberry Pi 4 Model B Frequently Asked Questions (FAQ)
Benchmarking the Raspberry Pi 4 Model B
Do You Know Your Pi from Pie? Raspberry Pi Quiz!
Eben Upton talks about the new Raspberry Pi 4 Model B
Want to buy the new Raspberry Pi 4 Model B?
Product NameManufacturer
RASPBERRY PI 4 MODEL B, 1GBRaspberry PiBuy NowBuy Now
RASPBERRY PI 4 MODEL B, 2GBRaspberry PiBuy NowBuy Now
RASPBERRY PI 4 MODEL B, 4GBRaspberry PiBuy NowBuy Now
  • raspberry pi 4 accessories
  • jomoenginer
    jomoenginer over 6 years ago +4
    Oh. my! Looks like the 2Gb and above use a USB-C power adapter so a new power source will be required for these. The ethernet port location swap and dual HDMI will result in new cases being released for…
    shabaz over 6 years ago +4
    Hi! Maybe it's worth adding a fan and heatsinks to this list. Here's some suggestions: Ceramic heatsink for the CPU, 15x15x2mm: MPC151525T MPC151525T Ceramic heatsink for the RAM, 10x10x2mm: MPC101020T…
  • colporteur
    colporteur over 6 years ago +3
    No fair, after reading your post I now feel I am forced to apply for the RoadTest the Raspberry Pi 4 Model B (2GB) so I can experience all the new changes for myself. Great post, thanks.
  • colporteur
  • colporteur
