RoadTest: Keysight Smart Bench Essentials
Author: john.porter
What other parts do you consider comparable to this product?: There are no known direct comparisons. Tektronix suggests a collection of equipment for a "Fundamental Teaching Bench". Rigol suggests a collection of equipment for an "Advanced Education Bench".
What were the biggest problems encountered?: The PathWave BenchVue control applications need refinement and additional features. Test flow is not enabled. The EDU33212A waveform generator is not directly supported by software to create/edit arbitrary waveforms. The waveform generator has severely limited .CSV file import capability.
Keysight Smart Bench Essentials Review - John Porter
Are you looking for a set of modern, feature-packed, coordinated instruments for your bench? Keysight’s Smart Bench Essentials (SBE) provides a complete solution of four essential devices, each with their own licensed Pathwave BenchVue software application:
| {gallery}The Keysight Smart Bench Essentials |
EDU34450A 5½ Digit Multimeter |
EDUX1052G 50MHz Digital Storage Oscilloscope |
EDU33212A Two-channel Arbitrary Waveform Generator |
EDU36311A - Triple-output Programmable DC Power Supply |
It is easy to see that Keysight has gone out of their way to match the Smart Bench Essentials instrument aesthetics nicely. All four devices have the same layout: sophisticated black on gray color scheme, large seven-inch color display, and row of six selection buttons. The form factor of the three smaller units is virtually identical, with the power supply understandably larger and deeper. Button layouts and channel colors are consistent across the four instruments. The consistency of the aesthetics, panels and interfaces goes far beyond just looking pretty though - for students, this uniformity encourages an intuitive understanding of the equipment and enables rapid learning.
The Smart Bench Essentials instruments are drawn from Keysight’s entry-level product lines, likely to keep the costs competitive. I really don’t believe Keysight was racing to have the bottom prices though, the SBE are more expensive than some competitors. However, this is quality gear. The instruments inherit technology found in Keysight’s higher end models and sets the SBE above lower cost competitors. The SBE’s performance may even challenge some mid-range models.
Keithley and Rigol have grouped some products into education collections (Fundamental Teaching Bench and Advanced Education Bench) however these distinct products seem to be simply put together and do not exhibit the deliberate consistency and operation of the Keysight Smart Bench Essentials.
Instrument Reviews
To keep this part of the review from reaching 30 or so continuous pages, I have provided separate blogs to present reviews for each of the Keysight Smart Bench Essentials instruments along with blogs for a remote access test case and unboxing. There you can find detailed information along with comparisons, interesting test cases, instrument specific software findings and performance evaluations. Links are here and at the end of this page.
Startup Video
Below I include a short video of the noise and light show when starting up the Essentials equipment. It is a race with a lot of fan noise and clicking! The oscilloscope does not win.
Software and Web Interface
Software
Keysight Pathwave BenchVue apps are a key component of the Smart Bench Essentials and add computer management and enhanced data logging to the platform. The apps add value and may be viewed as a 5th instrument in the series. These are licensed stand-alone apps, one app included for each instrument. Keysight has gone to great length to standardize the look and feel of the interface in each of the four apps:
| {gallery}Pathwave BenchVue DMM |
Keysight Pathwave BenchVue Digital Multimeter Startup |
Keysight Pathwave BenchVue Digital Multimeter Software Main Screen with options |
Keysight Pathwave BenchVue Digital Multimeter Software Data logging graph |
Keysight Pathwave BenchVue Digital Multimeter Software Data logging bar |
Keysight Pathwave BenchVue Digital Multimeter Software Data logging AC |
| {gallery}Pathwave BenchVue Oscilloscope |
Keysight Pathwave BenchVue Oscilloscope Main with options and cursor |
Keysight Pathwave BenchVue Oscilloscope Measurement options |
| {gallery}Pathwave BenchVue Function Generator |
Main screen with options |
Main full screen |
Setting Sweep |
Burst settings |
Sum settings |
Save settings screen |
Modulation settings |
Dual channel settings |
| {gallery}Pathwave BenchVue Power Supply |
Power Supply Main |
Power Supply Settings |
Power Supply OCP OVP |
Power Supply Data Logger Chart |
Power Supply Data Logging |
Power Supply Data Logging options |
Power Supply Email Alert Settings |
The Pathwave BenchVue apps can be confused with the BenchVue platform, the latter of which does not support the Smart Bench Essentials power supply, function generator nor DMM at present. The oscilloscope does inherit support in BenchVue but is presently all alone in there. An unexpected bonus to the apps, once they are licensed, is that they also support many other Keysight instruments you may have. In my case, I was surprised to discover the DSOX1102G oscilloscope and 34461A DMM gain new software support.
The four Pathwave BenchVue apps have many common elements, which makes sense considering Keysight has gone to length to standardize the interfaces. I provide additional information for each individual app in the accompanying review blogs (links at the end). Pathwave BenchVue apps complement and strengthen the Keysight Smart Bench Essentials collection with these features:
The Pathwave BenchVue apps are in need of some refinement and enhancement. I have noted areas for improvement below. There are some significant omissions that I hope to see addressed in later revisions:
| {gallery}Pathwave BenchVue Setup and Issues |
Pathwave BenchVue Connection Dialog |
Pathwave BenchVue Connection Expert |
Pathwave BenchVue process to add a license |
Can't find instruments |
Pathwave BenchVue - Cannot Edit ARB Files |
Web Interface
Keysight hits the mark with great execution of the built-in web interface on each instrument. The web interfaces accurately represent each device’s panel and provide direct control of all functions. The display updates with a short delay and shows the same graphic image as on each instrument. In almost every case, I preferred the web interface over the BenchVue application – it is implemented very well and is reliable. The VNC implementation on the EDUX1052G is solid and reasonably quick. While I couldn’t turn the equipment on/off or move cables from the web, I felt that I could manage each device effectively. The security of the web interfaces needs attention however, and would benefit from SSL encryption. You do not want to put these instruments directly on the Internet without controls in place.
| {gallery}Web Interfaces |
DMM Web |
Oscilloscope Web |
Oscilloscope Web Image Capture |
Oscilloscope VNC |
Waveform Generator Web |
Power Supply Web |
Educational Evaluation
Although I am no longer a full-time student, I continue to learn something new every single day and am always seeking out innovative ideas. I have been an instructor in a past career. So, it was natural for me to consider how the Keysight Smart Bench Essentials can empower those new to electronics engineering and their instructors.
The Smart Bench Essentials instruments deliver a complete lab configuration, easy to learn yet powerful enough for advanced experimentation as each student progresses. Clearly, this is where Keysight has focused their sights, and they do not miss. Each instrument considers a student’s perspective and supplies help to guide them along. The common interface of the panels and software enables students to become familiar and comfortable with the series quickly.
Holding almost any button on any of the instruments brings up an informative context specific help menu to explain what the function does and how to use it. I found this immensely helpful throughout my testing, and I know that students will as well. The instruments are perfectly matched for educational facilities and for students learning electronics concepts.
Understanding how to effectively use an oscilloscope can be particularly challenging for new students. To provide additional support to instructors, students and those seeking to learn how to operate an oscilloscope, Keysight includes several built-in training signals with the EDUX1052G. This is perhaps one of my favorite features of the EDUX1052G. These can be used to present a variety of signals and conditions that an engineer can expect, without the need of external circuitry. Keysight also provides the free “Educator’s Training Kit for 1000 X-Series Oscilloscopes Lab Guide and Tutorial for Undergraduate Electrical Engineering and Physics Students”. This guide is essentially a series of 14 guided lab assignments that leverage the built-in training signals to create a variety of common scenarios for measurement and analysis. The guide, combined with the training signals, is a top-quality instructional tool. If you are new to the world of oscilloscopes, running through these labs with the EDUX1052G will help you quickly develop into a proficient oscilloscope operator.
| {gallery}Training Signals and Educational Material |
Training Signals |
Triggering on, Capturing, and Analyzing an Infrequent Event - what is that waveform? |
Triggering on, Capturing, and Analyzing an Infrequent Event - found glitch by setting pulse width |
Noisy Sine Wave - Triggering on Wave and on rising edges of Noise |
Formerly Noisy Sine Wave - Now Appears Clean, Triggered using HF reject and Averaging |
Collaboration between students and between educational facilities has become standard practice. The global pandemic has, in many ways, moved instruction from the classroom to the home. Engineering programs were no exception. Tools that enhance collaboration and accessibility will excel in this environment - the Keysight Smart Bench Essentials makes great steps forward however does not deliver remote capability on its own. Institutes may want to consider the PathWave Lab Operations for Remote Learning to implement remote instruction.
Links to Reviews and Blogs
Conclusion
In summary, Keysight’s Smart Bench Essentials successfully delivers an industry leading educational workbench through a series of coordinated high-quality instruments. Students, instructors and hobbyists will find the Smart Bench Essentials to be encouraging and intuitive for beginners, while supporting the needs of more sophisticated users. These devices bring value!
Keysight has placed considerable purpose into developing a full educational package with the Smart Bench Essentials, and they deliver with a solid set of essential instruments. Further development is needed to apply polish to the Pathwave BenchVue apps and augment their capabilities. The series falls short on promises for interoperability at present. Distance learning software is available however not included. I hope to see software updates soon and eager to see the possibilities these may bring.
I was thrilled to be provided this opportunity to evaluate the Smart Bench Essentials and extend my thanks to Element 14 and Keysight for the exciting journey. Please let me know if you liked this review! If you have any questions, post them below and I will do my best to answer.
Smart Bench Essentials – well done Keysight!
