3D Printing
3D Printing
Blog Obsolete Potentiometer Controls: 3D Printing to the Rescue!
  • Author Author: shabaz
  • Date Created: 11 Jul 2025 1:38 AM Date Created
  • Views 5277 views
  • Likes 16 likes
  • Comments 23 comments
  • slide control
  • potentiometer
  • hifi
  • hi-fi
  • rotary control
shabaz
shabaz
11 Jul 2025
I suspect this is a common problem; lots of old Hi-Fi equipment have worn out pots and other controls, and it can be quite difficult locating exact replacement parts.
A friend had a music device (It’s a sort of DJ CD player with a lot of controls) around 30 years old, and it had a really worn down front panel. The controls were scratchy to operate, and in some cases, the grease had hardened, and the controls were very stiff. Some controls didn’t work, and others were crackly. Someone had already tried to clean it with a can of WD40.
Ordinarily I would turn down such a repair request, but it’s a friend, and he was pretty passionate about this particular device, he had no desire to replace with a modern digital solid-state music player. I decided to fix it, and ran into the problem that I simply couldn’t find alternative potentiometers that would precisely fit.
I briefly considered reverse-engineering the entire front panel board to rebuild it from scratch, but that would have been a lot of work. I decided to focus on the potentiometers instead.
I searched around and found some potentiometers that had the correct shaft (my friend didn’t want the plastic knobs to be altered from the original ones), but the potentiometers themselves were a lot smaller. After some brainstorming, I realized that I could make a little plastic adapter, and use a flexible PCB to route the pins of the potentiometer to match the original potentiometer.
I designed it using FreeCAD (I am still a learner, hence the design is simplistic).
I don’t own a 3D printer, so I had to use a 3D printing service (I used J.L.C.), it was surprisingly low-cost. I chose to print in nylon, which is quite tough and reasonably heat-resistant.
I designed the flexible PCB using KiCad, and again used the overseas manufacturer to order it. See  Creating a Flexible PCB!
For the potentiometer pins, I used 2.54 mm pin headers, and pulled out every other pin since I needed 5.08 mm spacing.
For the slider potentiometers, I did a similar thing, only I was able to use a normal PCB instead of a flexible one:
And here’s the final result! I used epoxy glue to fix the rotary potentiometer into its new 3D printed housing, and to attach the slider pot PCB onto its 3D printed base.
One down, about 23 more to go!
Thanks for reading.
  • kmikemoo
    kmikemoo over 1 year ago +1
    shabaz NICE! That's a brilliant solution.
    shabaz over 1 year ago in reply to kmikemoo +1
    Hi Mike, Thanks! First it felt extreme to repair like this, but on the other hand music enthusiasts get obsessive regarding their equipment they love, so it only seemed proportionate!
  • Fred27
    Fred27 over 1 year ago +1
    shabaz You've helped me so much (both directly and indirectly) on here that Id be happy to churn out a few 3D prints for you. One of the best things about 3D printing is not creating an object but being…
  • michaelkellett
    michaelkellett over 1 year ago
    Excellent fix !
    I get requests to fix things quite often and almost always turn them down (its impossible to make any money from them), but occasionally other things tip the balance.
    I just replaced the belts on a Pioneer cassette recorder and was amazed at how easy it is to get belts for 30 year old tape machines.
    But there are loads of parts that can't be directly replaced and yours is a great example of using modern technology to replicate old parts.
    How much did you have to pay for the 3D prints and the flexi boards ? (Hope you don't mind my asking.)
    MK
    shabaz over 1 year ago in reply to michaelkellett
    Hi Michael,
    That's awesome, nice to see cassette decks operating! I wasted many hours creating mix tapes : ) And then creating mix CDs with the early CD recorders where you had to not move and not touch a thing while it was recording, in fear of "buffer underrun".
    The 'multi-jet fusion' (MJF)-created nylon rotary pot adapters cost $31.81 for 25, so in GBP about 94p each. The linear pot adapters were $12 for 7. Some of the other plastic options (with a non-MJF process) cost less, but I've not tried any other option yet.
    The single-layer flex PCB was $32 for 25 of them. They would have been cheaper still if stiffener boards were not specified. With hindsight I probably didn't really need the stiffeners for this small task. The flex PCBs are always ENIG plated from J.L.C., they don't provide any other choice.
  • dang74
    dang74 over 1 year ago in reply to shabaz
    Amazing how the price of custom flex PCBs came down.  At one time the setup charges were cost prohibitive.
  • dang74
