3D Printing
3D Printing
3D Printing Forum Ender 3 pro
  • Replies 13 replies
  • Subscribers 335 subscribers
  • Views 2979 views
Ender 3 pro
Jokerschild666
Jokerschild666 over 2 years ago
I have had my ender for about a year now and I just replaced the z motor on it the wires are good but when I try to home the motor just humms and doesn't move then a home error shows on screen and says reset printer is it a software issue help
    dougw over 2 years ago +1
    It sounds like the motor windings are not connected properly. Is it possible the connector orientation got swapped? Is it an identical motor? (same voltage and current requirement)
  • Jokerschild666
    Jokerschild666 over 2 years ago in reply to dougw
    I bought it straight from ender i have three z motors even tried the old motor same thing happens I put new wires the only thing I haven't is upgrade the firmware yet
  • anniel747
    anniel747 over 2 years ago
    [deleted]
    dougw over 2 years ago in reply to Jokerschild666
    If you turn the motor by hand does the mechanism move freely?
  • Jokerschild666
    Jokerschild666 over 2 years ago in reply to anniel747
    When I move it by hand it's fine because I thought at the time it went bad when I put the new motor I didn't update software I can send you a video and pic if you like
    Do the motors work when they are not mechanically connected - just electrical connection?
  • Jokerschild666
    They work fine when it's not on
  • Jokerschild666
    yes
    It sounds like something is binding up so the motor can't turn when connected mechanically. Is the mounting skewed or offset a bit? Is the mechanism free to move when turned by hand?
    Is there a limit switch activated, preventing motion?
  • Jokerschild666
    I have unscrewed and just set it on side and tried it same thing happens I think it's a software thing cause I try to just move another motor and they won't move at all
