Code Exchange
Code Exchange
Blog GitHub: automate project documentation with DoxyGen, and publish online after pushing commits
Join Code Exchange to participate - click to join for free!
  • Date Created: 15 Jul 2024 11:46 AM Date Created
  • Views 8090 views
  • Comments 6 comments
  • doxygen
  • github actions
  • yaml
  • github.io
  • github
  • teseo_c++
15 Jul 2024
The title says it all. You can generate project documentation from the comments in the source files. I'm using doxygen for that. What I tried today (and succeeded in), is to make a GitHub action that:
  • kicks off a process on one of its job servers that automatically generates the documentation
  • kicks of a second process to deploy that on github.io
Prerequisite at this point, is that you know how to configure your project for doxygen. And that you know how to write good comments that make for good documentation. Here's a link to one of my ./Doxygen configuration files, if you need inspiration. Take care that you have such a file checked into your project's github repository.
Then create a new GitHub action. You can that by creating a .yaml file in the .github/workflow subdir of your project and push that, or you can open your GitHub repo online, and navigate to Actions -> wew workflow -> set up a workflow yourself. The latter option has the advantage that you get some code support and validation. I named my file .github/workflows/doxygen-gh-pages.yml.
I set up 3 actions, that all will run on GitHub hosted servers:
  1. checkout the code
  2. generate the documentation with a nice GitHub market place plugin.
  3. publish to github.io
Here's the full content
# Sample workflow for building and deploying a Doxygen site to GitHub Pages
name: Deploy Doxygen with GitHub Pages dependencies preinstalled
on:
  # Runs on pushes targeting the default branch
  push:
    branches: ["main"]
  # Allows you to run this workflow manually from the Actions tab
  workflow_dispatch:
# Sets permissions of the GITHUB_TOKEN to allow deployment to GitHub Pages
permissions:
  contents: read
  pages: write
  id-token: write
# Allow only one concurrent deployment, skipping runs queued between the run in-progress and latest queued.
# However, do NOT cancel in-progress runs as we want to allow these production deployments to complete.
concurrency:
  group: "pages"
  cancel-in-progress: false
jobs:
  # Build job
  build:
    runs-on: ubuntu-latest
    steps:
      - name: Checkout
        uses: actions/checkout@v4
      - name: Setup Pages
        uses: actions/configure-pages@v5
      - name: Run Doxygen
        uses: mattnotmitt/doxygen-action@v1.9.5
        with:
          # working-directory: '${{github.workspace}}/Kerbal/doxygen'
          doxyfile-path: 'Doxyfile'
      - name: Upload artifact
        uses: actions/upload-pages-artifact@v3
        with:
          path: doc_generated/html
  # Deployment job
  deploy:
    environment:
      url: ${{ steps.deployment.outputs.page_url }}
    needs: build
    steps:
      - name: Deploy to GitHub Pages
        uses: actions/deploy-pages@v4
The nice thing is that you don't have to store any credentials. They are dynamically generated by GitHub. As repository manager, you control what can be in that .yaml file. And you can thus control what is allowed, and what actions run.
Here is a part of the run logs:
Checkout and doxygen html documents generation
Then deploy to github.io:
I created this for my Pico GPS library. The documentation is online: https://jancumps.github.io/pico_gps_teseo/
Next:  GitHub: automate Raspberry Pico project build verification with GitHub Actions
Link to
all posts.
    Jan Cumps over 1 year ago
    The GitHub doxygen-action task has a number of versions. Each version matches a DoxyGen document generator version.
    Since a few weeks, the author created an "edge" version. That one will always install the latest DoxyGen version available.
          - name: Run Doxygen
            uses: mattnotmitt/doxygen-action@edge
            with:
    At the time of writing, it 'll use DoxyGen 1.13.2
    The author has added a funny message:
          - name: Run Doxygen
            with:
