Embedded and Microcontrollers
Blog Build Bootloader compatible firmware for EasyL1105 MSPM0 board with Code Composer Studio
  • Date Created: 12 Sep 2025 5:36 PM Date Created
  • Views 1479 views
  • MSPM0L1105
  • ccs
  • MSPM0
  • bootloader
  • easyL1105
  • texas instruments
  • code_composer_studio
12 Sep 2025
 shabaz designed a development kit for the recent Texas Instruments MSPM0 microcontroller series.
In this post, I build a .HEX file that can be used with the Python bootloader for this board.
Level: very easy.
(post that introduces the kit)
 Required hardware and software
  • EasyL1105 kit
  • a version of Code Composer Studio that supports MSPM0. I use ccstudio 20
  •  EasyL1105 MSPM0 board: hello, world example project
Generate firmware in ihex format
ccstudio configures your GCC project to generate ARM ELF firmware. The bootloader expects ihex. These additional steps in the project setup build output in that format.
enable GNU ObjectCopy Utility
configure GNU ObjectCopy
  • output file name: ${PROJECT_BUILD_DIR}/${ProjName}.hex
  • format: ihex
  • flags: --gap-fill 0xFF
That's all. You now have a compatible firmware binary
Programming the kit
This is explained in  EasyL1105: A Dev Board for the TI ARM Cortex-M0+ L-Series .
Here's my command line:
python3 "C:\Users\jancu\Documents\git\git_shabaz\easyL1105\mspm0_programmer\python\mspm0_prog.py" --port COM18 C:\Users\jancu\workspace_ccstheia\EasyL1105_helloworld\Debug\helloworld.hex
Thanks for reading.
Related posts
    shabaz over 1 year ago
    Glad that Python programmer is working! It does need more testing, so if you ever come across a situation where you're getting unexpected results with it, it may be worth double-checking with the result with SWD or UniFlash etc. I dont know of any bug with the Python programmer so far, but Ive only used it for small simple programs.
    Jan Cumps over 1 year ago in reply to shabaz
    I tried it with 6 projects, and they all worked with SWD and bootloader
    I'm trying a larger project with FreeRTOS. Still struggling to get past compile errors.
    If that one loads with the bootloader, anything will.
    disclaimer: don't know about signed firmware yet. I haven't got that working in either case.
