Embedded and Microcontrollers
Blog MSPM0 project with VS Code, CMake and GCC - part 4: EasyL1105 example
  • Date Created: 4 Sep 2026 9:36 AM Date Created
  • Views 268 views
  • Comments 8 comments
  • MSPM0L1105
  • ccs
  • gcc
  • MSPM0
  • easyL1105
  • VS Code
  • vscode
  • code_composer_studio
4 Sep 2026
In this blog series, I build a Texas Instruments MSPM0 example with VS Code as IDE, and CMake as build infrastructure.
In posts 1 - 3, I created an end to end flow, from install over build to debug.
In post 4: testing it out on the EasyL1105: A Dev Board for the TI ARM Cortex-M0+ L-Series with a blinky.
Project and Changes
I used TI's existing pwm_led_driver example for the L1105 (project is attached at the end of this post).
Changes to SysConfig:
  • different GPIO for LED:
    the code I attached uses PA14, to reflect my setup. I have a blue LED on PA14..
    If you use an unaltered EasyL1105 board, edit pwm_led_driver.syscfg and change PA14 to PA26 on line 27. That's where one of its LEDs sits.
Changes to the scripts:
  • in CMakeLists.txt I changed the project name, and the file names of the sysconfig and .c file
  • in launch.json, I changed the device to MSPML1105 on line 32
Debugger
I used the on-board XSD110 from one of my LaunchPads. Works equally well with a standalone XSD110.
On the EasyL1105, I removed all jumpers (in particular the power ones). On the LaunchPad, I removed all jumpers that connect the debugger to the controller. Then I routed Ground, 3V3, nRST, SWDIO and SWCLK from debugger to EasyL1105 J5 (SWD connector).
I selected the project in VS Code CMake extension. Selected GCC toolkit. Config, Build.
After that, started a debug session. All worked. The code got loaded on the MSPM0L1105, and the LED started glowing...
The build script also generates a .hex firmware compatible with shabaz'  python programmer.
VS Code project: EasyL1105_vscode_20260906.zip
post 3:  MSPM0 project with VS Code, CMake and GCC - part 3: debug
post 5:  MSPM0 project with VS Code, CMake and GCC - part 5: Open .syscfg file in SysConfig GUI
part of the EasyL1105 series. all posts
    shabaz 2 months ago +1
    The MSPM0 Python programmer has just recently been updated, I set AI on it, to give it a decent scroll buffer, and also show the status at the bottom. Now it looks like a real text-based app. Also…
    shabaz 2 months ago
    Hi Jan,
    This is super-useful! The integration with VS Code is really nice.
    I had a request, I was wondering, would it be possible to have a the CMakeLists.txt file not generate the sysconfig output, perhaps if specified somehow, or if the sysconfig file is not present? I'm thinking about the scenario where someone might forget to share the sysconfig file and only supply the generated output, or the scenario where someone directly touched the generated output, hence cannot regenerate the output.
    DAB 2 months ago
    Great series Jan.
  • Qbit
    Qbit 2 months ago
    Nice follow up!
