Ask an Expert Forum John Wiltrout, I was remiss in under-correcting you the other day!
  • Replies 13 replies
  • Subscribers 338 subscribers
  • Views 2277 views
  • resistors
See a helpful answer?
D_Hersey
D_Hersey over 11 years ago
In a thread you stated that the only way to compare two resistors was to put them in a string, put a potential across said string and measure and compare the drops of the two loads.  I won't go digging up the thread, because I am far too much of a gentleman for something as crass as that.  Please take the essence of my rendition as accurate.
At the time I noted that you had overlooked the Norton alternative.  But as my head hit the pillow tonight, the ghosts of ETs past implored me in both ears:  SOMEONE IS WRONG ON THE INTERNET!  Our doppelgänger del Norte, JWT!  You are guilty of dissimulating John's degree of wrongness, Don!  Get up and type!
Consider:
Imagine that the first two circuits have a dashed rectangles around them, sparing the terminals.  They are 'black boxes.'  For concreteness, let's imagine that each resistor is one ohm/Siemens.  The black boxes would measure out to be one ohm/Siemens.
Pretend that the horizontal line in the second diagram is a jumper.  How much current flows through this wire?  None, ever.  Whether the jumper is attached will be known only to the 'inside the box' community.
So, the (bipolar) ammeter in the third diagram reads zero if Ra=Rb.  Else it will indicate which resistor is larger/smaller.  Remember, the galvanic meter is highly sensitive, although passive.  This circuit arrangement is called a "Whetstone Bridge."
Whetstone is a place in England where people like to balance things.
So there we have it, friend.
    jw0752 over 11 years ago
    Hi Don,
    Thank you for your explanation of the Wheatstone Bridge. I must confess that I do not remember making the statement that the only way to compare 2 resistors is to put them in a string and compare the drops of the two loads. While I may have proposed such a scheme to compare two resistors it is against my nature to make such a claim exclusive. I learned a long time about the problem with words like "only" or "every". The semantics of the premise aside I am very interested in learning more about the Norton Alternative. I will do a little research on it, I see that you also proposed the Norton Alternative to the person experimenting with the dust detector. I am also interested in seeing how many unique ways The Forum can find to compare 2 resistances. I will begin by suggesting that we can put them in parallel and under a common voltage and then measure the temperature rise of each under similar conditions.
    michaelkellett over 11 years ago
    Sorry to come over all pedantic on you Don (well not really image):
    It's Wheatstone (after the man, Sir Charles Wheatstone), a whetstone is  a different kettle of fish altogether:
    Wheatstone bridge - Wikipedia, the free encyclopedia
    Whetstone - Wikipedia, the free encyclopedia
    Hi Don,
    I spent some time last night researching the Norton Op Amp and read up on an LM3900. This is a very interesting chip and I have put it on my list of parts to order. I look forward to mocking up some circuits to help me understand it better. Once again thank you for taking the time to educate and keep the forum stoked up.
    michaelkellett over 11 years ago in reply to jw0752
    Hello John,
    Did you find the original NS app note:
    www.ti.com/lit/an/snoa653/snoa653.pdf
    Actually it may not be the original.
    I have the NS Linear Integrated Circuits data and app notes books in hard copy from 1972. The data sheet for the LM3900 has several pages of example circuits but there is no app not for it in the 1972 book.
    I've always thought it was an interesting part but I've only seen it used once by another engineer (Ian Pullen in the Lustraphone LP101 FM Tuner audio output stages) and I've only used it once or twice myself.
    jw0752 over 11 years ago in reply to michaelkellett
    Hi Michael,
    Thank you for the link as it is much more complete than I was able to find last night. I am learning as much as I can about unique electronic components as these are the potential building blocks for any future projects. When I find something new like this I read about it and then I try to make some test circuits to verify that I can apply what I have learned. While I do not yet have the skill to design anything sophisticated I have learned from past experience that it is a process and if I continue to keep stepping ahead my skill level will improve. I appreciate your input.
  • D_Hersey
    Michael, I was kidding.  When I post in the middle of the night I am just giggling deliriously, not paying much attention.  Thank you for the correction, I was being a stinker.
    Keep it up John, you will one day realize that you have broken through to a level where you will fly freely through this stuff.  IIRC you made your alleged misstatement during a thread by a guy who wanted to detect the presence of metal in a slurry going down a tube.  I won't hold you to it and I certainly won't vouch for my ever-dimming powers of recall.
    Now to the chase:
    You could switch the two resistors into and out of the reference leg of an oscillator and compare frequencies.
    You could use a Wilson mirror:
    Current through Rp sets the B-E drops of both Qs.  If Rt is greater than Rp, the mirror will reach the limit of its compliance and Q2 will saturate.  If there is greater than a C-E drop across Q2, Rt is the smaller.
  • D_Hersey
    Of course, credit where it is due:
    http://en.wikipedia.org/wiki/Charles_Wheatstone
  • D_Hersey
    C'mon guys.
    You could put them in a calorimeter.  Mine is Thermos brand, as I don't represent any governments or corporations.  We just energise them for a second and measure delta T.
    Power in a resistor is IIR.  If we energise them with current, the larger resistor will get warmer.
    Power in a resistor is VVS  If we energise them with potential, the larger conductor will get warmer.
    If the resistors are otherwise indistinguishable, we might be able to judge the hotter through gauging the blackbody peak.
    Possibly, this research could be facilitated with light bulbs.
  • D_Hersey
    We could use the garage and patience, again presuming that the resistors are similar in everything but value.
    We could hook the resistors up in series to a big, big battery.  My garage is really, really damp.  I am less than a mile from the creek.  As I alluded to earlier, I live by the south west end of Lake Michigan/Huron.
    Reduction, go figure, is getting electrons.  Blame Ben Franklin, lamest president ever!
    Therefore oxidation is giving electrons.  The way to do that is be positive.
    The lead attached to the positive terminal will rust at an accelerated rate.  The lead attached to the negative terminal at a retarded rate.
    So, how rusty is the intermediate node gettin'?  If it is nearly as rusty as the + term, I say the smaller resistor is up top in the string.  If it is nearly as pristine as that high-rent negativland, I say the big resistor is in the top bunk.
    https://www.youtube.com/watch?v=DV08nrktjlI
  • D_Hersey
    Striction.
    Energise a capacitor, it gets smaller.  Unlike charges attract.  We have all heard a humming capacitor-yard.
    Energise an inductor, it gets smaller.  Unlike magnetic poles attract.
    Energise a resistor, it gets larger, we've warmed  it up.
    We could measure the relative strain or compression, depending upon our set-up.  Or simply displacement.
