FPGA
FPGA
Blog Booting up Ultrazed-EG dev board
  • Author Author: Manan_98
  • Date Created: 1 Nov 2022 2:27 PM Date Created
  • Views 1152 views
Manan_98
Manan_98
1 Nov 2022
Hello all,
I am not able to boot up the board even after following the steps exactly given in the manual. It seems that the board is not drawing any current as the fan which I am mounting on it is also not powering up and the PS red LED is also not glowing. Apart from that, I am not able to find the "rootfs.cpio.gz" file in the downloads section of AVNET. Any leads on this would be greatly appreciated.
Thank you
  • rsjawale24
    rsjawale24 over 4 years ago
    I would suggest to use a digital multimeter to check if the board is getting the supply or not. Maybe some power supply IC has failed or shorted. You can identify the power supply area on the PCB by inspection method. Just follow the path from the power input side. First check the voltage at the power input.
  • Manan_98
    Manan_98 over 4 years ago in reply to rsjawale24
    Thanks rsjawale24. Do you happen to know anything about the "rootfs.cpio.gz" file ?
  • Manan_98
  • rsjawale24
    rsjawale24 over 4 years ago in reply to Manan_98
    No idea about that. Maybe some other members who have worked with the Ultrazed-EG may help you out
