FPGA
FPGA
Blog Booting up Ultrazed-EG dev board
  • Author Author: Manan_98
  • Date Created: 1 Nov 2022 2:27 PM Date Created
  • Views 1152 views
Manan_98
Manan_98
1 Nov 2022
Hello all,
I am not able to boot up the board even after following the steps exactly given in the manual. It seems that the board is not drawing any current as the fan which I am mounting on it is also not powering up and the PS red LED is also not glowing. Apart from that, I am not able to find the "rootfs.cpio.gz" file in the downloads section of AVNET. Any leads on this would be greatly appreciated.
Thank you
  • flyingbean
    flyingbean over 3 years ago
    Check the booting mode configuration: DIP setting as below
    I used a carrier board with Ultrazed-EG before. So please read the hardware user guide for your trouble-shooting:
    https://www.avnet.com/wps/wcm/connect/onesite/4f81c10d-aca8-4ccc-942a-2b07d1b8fcf0/5264-UG-AES-ZU3EGES-1-SOM-G-v1-1-V1.pdf?MOD=AJPERES&CACHEID=ROOTWORKSPACE.Z18_NA5A1I41L0ICD0ABNDMDDG0000-4f81c10d-aca8-4ccc-942a-2b07d1b8fcf0-obVY6kd
    Good luck!
  • flyingbean
    Good luck!
