FPGA
FPGA
Blog Design and Development of Keyword Spotting Module using MFCC algorithm for Robotic Movement on PYNQ-Z1 Board
  • Author Author: kishankarthik2008
  • Date Created: 19 Jun 2024 2:50 PM Date Created
  • Views 2420 views
  • pynq
kishankarthik2008
kishankarthik2008
19 Jun 2024
Current Scenario:
  Is a spoken word audio dataset intended to aid in the development and evaluation of keyword recognition systems? Explains the appeal of this task as a challenge and the need for a unique dataset that is distinct from the standard datasets used for automated voice recognition of whole sentences. Proposes a way for measurable accuracy measures for this work that are repeatable and comparative. Describes the data's sources, methods of verification, contents, history, and qualities. Reports the baseline outcomes of models developed using this dataset as its conclusion.
Problem Inexistence:
  Nowadays more individuals want to train and test recognition models as speech technology has advanced, but dataset availability hasn't increased. Broadening access to datasets promotes cross-group collaboration and permits comparative analyses between various methodologies, which advances the entire field, as demonstrated by the use of ImageNet and comparable collections in computer vision. A standard training and assessment dataset for a class of easy speech recognition tasks is being built with the Speech Commands dataset. Its main objective is to make it easy to create and test tiny models that can identify spoken words from a list of ten or less target words with a small number of false positives due to background noise or unrelated speech. Commonly referred as keyword spotting.
  Keyword spotting is a technology used in speech and text processing to identify specific words or phrases within a larger set of data. It involves detecting and extracting predetermined keywords or phrases from spoken or written content. This technique is particularly useful in applications like voice assistants, transcription services, and content filtering. By leveraging various algorithms and language models, keyword spotting enables efficient and accurate identification of specific target words or phrases, enhancing search capabilities and enabling
automated processing of large amounts of data.
Motivation for Keyword Spotting:
  A lot of speech interfaces use keyword spotting to initiate conversations. For instance, you may start a search or phone command by saying "Hey Google" or "Hey Siri". Since it may operate on a server whose resources are managed by the cloud provider, once the device recognizes that you wish to engage, it is possible to transfer the audio to a web service to run a model that is only constrained by commercial concerns. However, it is impracticable to operate the first identification of the beginning of an interaction as a cloud-based service since doing so would need sending audio data continuously over the internet from all devices. This would enhance the technology's privacy hazards and be highly expensive to maintain. Instead, a recognition module is often run locally on the phone or other device through voice interfaces. Instead of transmitting the data over the internet to a server, this continually listens to audio input from microphones and runs models that listen for the necessary trigger words. The audio is sent to a web service whenever a potential trigger is detected. The on device model must adhere to strict resource limits since the local model runs on hardware that is not within the web service provider's control. The most obvious of them is that, in order to execute in close to real-time for an interactive response, on-device models must require fewer computations than their cloud equivalents because mobile processors are often available but have far lower overall compute capabilities than most servers.
Scope:
Keyword spotting (KWS) is a technology that identifies specific words or phrases in an audio stream. This can be used for a variety of purposes, such as:
Real-Time Keyword Detection: The Pynq-Z1 board, equipped with a powerful FPGA and a processing system, enables real-time keyword spotting. This means it can detect specific keywords or phrases in audio inputs with low latency, allowing for immediate response and interaction in applications like voice-controlled systems.
Edge Computing Applications: Keyword spotting on the Pynq-Z1 board brings the advantage of edge computing. By performing processing and inference on the board itself, you can create standalone voice command systems that operate offline, ensuring privacy and reducing reliance on cloud services. This capability also makes the board suitable for applications in remote or resource-constrained environments.
Learning and Development: The Pynq-Z1 board offers an excellent platform for learning and skill development. It allows you to explore FPGA programming, embedded systems, real-time applications, and machine learning techniques. By developing keyword spotting algorithms on the board, you can gain hands-on experience and delve into the intersection of hardware and software design.
Call routing: Keyword spotting is used to route calls to the correct department or person. For example, a call centre agent can use keyword spotting to identify the caller's issue and route the call to the appropriate department.
Smart home automation: Keyword spotting is used to control smart home devices, such as lights, thermostats, and security systems. When a user speaks a keyword, the device can take the desired action, such as turning on a light or adjusting the thermostat.
Summary:
This chapter provides an overview of keyword spotting and highlights the need for a unique dataset specifically designed for keyword recognition systems. The chapter emphasizes the importance of such a dataset in advancing the field of speech technology and enabling cross group collaboration and comparative analysis. Overall, this chapter sets the stage for the subsequent chapters of the project, laying the foundation for the exploration and development of keyword spotting using the MFCC algorithm.
Background
PYNQ-Z1 Board
  The KWS is carried out on PYNQ-Z1 Board. The PYNQ-Z1 board is made to operate with the PYNQ open-source framework, which enables embedded programmers to write Python code for the onboard SoC. It is built around the Xilinx Zynq-7000 SoC, which combines a dual-core ARM CortexTM-A9 CPU with an FPGA's programmable logic. The PYNQ-Z1's hardware is adaptable and ready for usage. With standard Arduino TM headers, Pmod ports, inbuilt I/O, HDMI in/out, audio out, USB and Ethernet connections, it has a comparable physical factor and functionality as Digilent's Arty Z7. As a result, the PYNQ-Z1 serves as a flexible and simple-to-customize SoC development platform for programmes including computer vision, industrial control, Internet of Things, encryption, and embedded computing acceleration. Python may be used to programme the Zynq-7000 SoC using the PYNQ-Z1 open-source framework, and embedded developers and engineers can test the code directly on the PYNQ-Z1. Similar to how software libraries are imported and used, programmable logic circuits are
imported as hardware libraries and controlled through their own APIs.
Mel-Frequency Cepstral Coefficients (MFCCs) features:
  An MFC is made up of a number of coefficients known as mel-frequency cepstral coefficients (MFCCs). They are produced from a nonlinear "spectrum-of-a-spectrum" cepstral representation of the audio sample. The mel-frequency cepstrum (MFC) differs from the cepstrum in that the frequency bands are evenly spaced on the mel scale, which more closely resembles the response of the human auditory system than the linearly-spaced frequency bands used in the conventional spectrum. When used in audio compression, for instance, this frequency warping can improve the representation of sound and potentially lower the transmission bandwidth and storage needs of audio signals.
 This method turns audio waveforms into 2D images with one channel. Similar to the one shown below:
                                                      Figure:  MFCC Feature Plot
 During the training of the KWS network we produce the MFCC features for the training and validation set and then quantize the inputs to the network to eight bit.
Google Speech Commands v2:
 The keyword spotting (KWS) network was trained on the Google Speech Commands v2 dataset. The task of categorizing an input audio pattern into a distinct set of classes is known as speech command recognition. It is a branch of automatic speech recognition known as key word spotting in which a model continuously scans speech patterns for certain "command" classes. The system can perform a certain action after detecting these commands. The goal of command recognition models is frequently to be compact and effective so that they may be
installed on low power sensors and operate continuously for extended periods of time. We then used a feature extraction technique called Mel Frequency Cepstral Coefficients or
MFCC for short.
KWS Accelerator:
The KWS MLP module is a component of the FINN (Framework for Incremental Neural Networks) examples, which is a library developed by Xilinx for efficient deployment of neural networks on FPGAs. KWS stands for "Keyword Spotting," and MLP stands for "Multilayer Perceptron," which is a type of neural network. The KWS MLP module is specifically designed for performing keyword spotting tasks, which involve recognizing specific keywords or commands in an audio stream. This module is implemented using a multilayer perceptron neural network architecture, which is a feedforward neural network consisting of multiple layers of interconnected artificial neurons.
                                            Figure : Basic block diagram of KWS mlp model
.The audio file is typically stored in memory or disk.
• The audio file is transferred from the processor to the FPGA with the help of DMA.
• The FPGA converts the audio data into a format suitable for processing, This conversion might involve converting the audio file from a digital representation such as pulse code modulation.
• The FPGA accelerator performs the desired audio processing tasks.
• The processed audio data is transferred back to the processor.
• The processor can further process the data or send it for output, such as audio playback or storage.
Ethernet cable:
 An Ethernet cable is a type of cable that is used to connect devices to a local area network (LAN). It is a twisted-pair cable that uses copper conductors to transmit data. Ethernet cables are available in a variety of lengths and speeds. Shielded cables are better at protecting data
from interference, but they are also more expensive. Unshielded cables are less expensive, but they are not as well-protected from interference.
Router:
  A router is a device that connects multiple devices to a network. It does this by routing data packets between devices. Routers use IP addresses to identify devices on a network. When a device sends data to another device, the router looks up the destination IP address and routes
the data packet to the correct device. Routers are used in both wired and wireless networks. In a wired network, a router is connected to each device on the network using an Ethernet cable. In a wireless network, a router uses radio waves to transmit data between devices.
Youtube project link:
Aim and Objectives
Title:
Design and Development of Keyword Spotting using MFCC algorithm in FPGA
Aim:
To Design and Develop of Keyword Spotting module from speech input using MFCC algorithm and implement on PYNQ-Z1 FPGA
Objective:
1. To perform literature survey on Keyword Spotting, speech processing, MFCC algorithm, performance parameters in speech recognition and PYNQ-Z1 FPGA
2. To arrive at the specifications of Keyword Spotting module.
3. To design and verify the Keyword Spotting module using MFCC algorithm.
4. To implement developed Keyword Spotting module using KWS accelerator.
5. To implement and verify the developed architecture on FPGA.
Method and Methodologies:
Development of Keyword spotting model
MFCC overview
 Speech Recognition is a supervised learning task. In the speech recognition problem input will be the audio signal and we have to predict the text from the audio signal. We can’t take the raw audio signal as input to our model because there will be a lot of noise in the audio signal.
It is observed that extracting features from the audio signal and using it as input to the base model will produce much better performance than directly considering raw audio signal as input. MFCC is the widely used technique for extracting the features from the audio signal.
Block diagram of MFCC
The road map of the MFCC technique is given below.
                    Figure: Block Diagram of MFCC
MFCC features extraction:
Step 1. A/D Conversion:
In this step, we will convert our audio signal from analog to digital format with a sampling frequency of 8kHz or 16kHz.
Step 2. Preemphasis:
Preemphasis increases the magnitude of energy in the higher frequency. When we look at the frequency domain of the audio signal for the voiced segments like vowels, it is observed that the energy at a higher frequency is much lesser than the energy in lower frequencies. Boosting
the energy in higher frequencies will improve the phone detection accuracy thereby improving the performance of the model.
Step 3. Windowing:
The MFCC technique aims to develop the features from the audio signal which can be used for detecting the phones in the speech. But in the given audio signal there will be many phones, so we will break the audio signal into different segments with each segment having 25ms width and with the signal at 10ms apart as shown in the below figure. On average a person speaks three words per second with 4 phones and each phone will have three states resulting in 36 states per second or 28ms per state which is close to our 25ms window.
From each segment, we will extract 39 features. Moreover, while breaking the signal, if we directly chop it off at the edges of the signal, the sudden fall in amplitude at the edges will produce noise in the high-frequency domain. So instead of a rectangular window, we will use
Hamming/Hanning windows to chop the signal which won’t produce the noise in the highfrequency region.
Step 4. DFT (Discrete Fourier Transform):
We will convert the signal from the time domain to the frequency domain by applying the dft transform. For audio signals, analysing in the frequency domain is easier than in the time domain.
Step 5. Mel-Filter Bank:
The way our ears will perceive the sound is different from how the machines will perceive the sound. Our ears have higher resolution at a lower frequency than at a higher frequency. So if we hear sound at 200 Hz and 300 Hz we can differentiate it easily when compared to the
sounds at 1500 Hz and 1600 Hz even though both had a difference of 100 Hz between them. Whereas for the machine the resolution is the same at all the frequencies. It is noticed that modeling the human hearing property at the feature extraction stage will improve the performance of the model. So we will use the mel scale to map the actual frequency to the frequency that human beings will perceive. The formula for the mapping is given below.
Step 6. Applying Log:
Humans are less sensitive to change in audio signal energy at higher energy compared to lower energy. Log function also has a similar property, at a low value of input x gradient of log function will be higher but at high value of input gradient value is less. So we apply log to the
output of Mel-filter to mimic the human hearing system.
Step 7. IDFT:
In this step, we are doing the inverse transform of the output from the previous step. Before knowing why we have to do inverse transform we have to first understand how the sound produced by human beings. The sound is actually produced by the glottis which is a valve that controls airflow in and out of the respiratory passages. The vibration of the air in the glottis produces the sound. The vibrations will occur in harmonics and the smallest frequency that is produced is called the fundamental frequency and all the remaining frequencies are multiples of the fundamental frequency. The vibrations that are produced will be passed into the vocal cavity. The vocal cavity selectively amplifies and damp frequencies based on the position of the tongue and other articulators. Each sound produced will have its unique position of the tongue and other articulators. The following picture shows the transfer function of the vocal cavity for different phones.
                  Figure: It shows the transfer function of the vocal cavity for different phones.
Note that the periods in the time domain and frequency domain are inverted after the transformations. So, the frequency domain’s fundamental frequency with the lowest frequency will have the highest frequency in the time domain.
Note: The inverse of the log of the magnitude of the signal is called a cepstrum. The below figure shows the signal sample before and after the idft operation.
                  Figure: It shows the signal sample before and after the idft operation.
 The peak frequency at the rightmost in figure(c) is the fundamental frequency and it will provide information about the pitch and frequencies at the rightmost will provide information about the phones. We will discard the fundamental frequency as it is not providing any
information about phones.
 The MFCC model takes the first 12 coefficients of the signal after applying the idft operations. Along with the 12 coefficients, it will take the energy of the signal sample as the feature. It will help in identifying the phones. The formula for the energy of the sample is given below.
Code Flow:
                        Figure: Block diagram of Code Flow
Overall Accuracy Evaluation:
The code begins by loading the preprocessed validation dataset. This dataset consists of input MFCC features and corresponding labels.
The PYNQ-Z1 board's accelerator model for keyword spotting (KWS) is initialized using the kws_mlp() function from the models module.
The ishape_normal() and idt() functions of the accelerator are called to obtain the expected input shape and data type.
Similarly, the oshape_normal() and odt() functions are called to obtain the expected output shape and data type.
The number of samples in the validation dataset is stored in the num_samples variable.
The accelerator's batch_size is set to the number of samples in the validation dataset.
The accelerator is executed on the input data (input_data) using the execute() method, and the output predictions are stored in accel_out_data.
The accuracy of the network is calculated by comparing the predicted labels (accel_out_data) with the ground truth labels (golden_out_data).
The number of correctly predicted samples and incorrectly predicted samples are counted using np.unique() and stored in the score variable.
Finally, the accuracy is calculated as a percentage and printed.
Network Throughput Assessment:
The code includes a naive timing benchmark to measure the throughput of the FPGA when processing the entire validation dataset.
The run_validation() function is defined, which executes the accelerator on the input data (input_data).
The %timeit magic command is used to run the run_validation() function multiple times and measure the average execution time.
The best execution time is obtained from the timing results and stored in full_validation_time.
The throughput is calculated by dividing the number of samples (num_samples) by the best execution time and printed as samples per second.
Additionally, the code utilizes the built-in performance benchmark provided by FINN by calling accel.throughput_test(). This benchmark measures the throughput of individual components of the PYNQ stack and the accelerator on the FPGA.
Classifying .wav Files with the KWS Network:
The code demonstrates how to classify raw .wav files using the KWS network.
The python_speech_features library is installed using the pip3 install python_speech_features command to generate MFCC features from the audio files.
Preprocessing parameters such as desired samples, window size, sample rate, window size in milliseconds, DCT coefficient count, and dataset labels are defined.
A convenience function py_speech_preprocessing() is defined to preprocess the raw audio signal and calculate MFCC features.
Another convenience function quantize_input() is defined to quantize the MFCC features for input to the accelerator.
The code loads a sample .wav file using the sample_path variable and plays it using the IPython.display.Audio() function.
The raw audio signal is read from the .wav file using wav.read() and stored in raw_signal and the sample rate is stored in rate.
The py_speech_preprocessing() function is called to preprocess the raw signal and obtain the MFCC features (mfcc_feat_py).
The MFCC features are visualized as an image using plt.matshow() and plt.colorbar().
The quantized MFCC features are obtained by calling the quantize_input() function and stored in mfcc_feat_quantized.
The quantized features are passed through the accelerator for inference using accel.execute(), and the output predictions (accel_out_data) are obtained.
The predicted label is obtained from accel_out_data and printed.
Classification of Sample Files:
The code loops over a set of sample classes (e.g., 'down', 'go', 'left', etc.) and performs the classification for each sample.
For each sample class, the path of a sample .wav file is defined using the sample paths dictionary.
The raw audio signal is read from the sample file using wav.read() and stored in raw_signal, and the sample rate is stored in rate.
The quantized MFCC features are obtained by calling the quantize_input() function and stored in mfcc_feat_quantized. The quantized features are passed through the accelerator for inference using accel.execute(), and the output predictions (accel_out_data) are obtained.
By going through these steps, the code evaluates the overall accuracy of the keyword
spotting network, measures the network throughput, and demonstrates the classification
capabilities using both a single .wav file and a set of sample files.
Hardware implantation
PYNQ-Z1 Setup Guide:
Prerequisites for the Pynq-Z1:
⮚ PYNQ-Z1 board
⮚ Computer with compatible browser
⮚ Ethernet cable
⮚ Micro USB cable
⮚ Micro-SD card with preloaded image, or blank card (Minimum 8GB recommended)
                                              Figure: PYNQ-Z1 Board
1. Set the JP4 / Boot jumper to the SD position by placing the jumper over the top two pins of JP4 as shown in the image. (This sets the board to boot from the Micro-SD card)
2. To power the PYNQ-Z1 from the micro USB cable, set the JP5 / Power jumper to the USB position. (You can also power the board from an external 12V power regulator by setting the jumper to REG.)
3. Insert the Micro SD card loaded with the PYNQ-Z1 image into the Micro SD card slot underneath the board.
4. Connect the USB cable to your PC/Laptop, and to the PROG - UART / J14 MicroUSB port on the board
5. Connect the board to Ethernet by following the instructions below
6. Turn on the PYNQ-Z1 and check the boot sequence by following the instructions below
Network connection:
Once your board is set up, you need to connect to it to start using the Jupyter notebook.
Ethernet:
If available, you should connect your board to a network or router with Internet access. This will allow you to update your board and easily install new packages.
Connect to a Network Router:
If you connect to a router, or a network with a DHCP server, your board will automatically get an IP address. You must make sure you have permission to connect a device to your network, otherwise the board may not connect properly.
Connect to a Router/Network (DHCP):
1. Connect the Ethernet port on your board to a router/switch
2. Connect your computer to Ethernet or WiFi on the router/switch
3. Browse to http://<board IP address>
4. Optional: see Change the Hostname below
5. Optional: see Configure Proxy Settings below
Launch Jupyter Notebook:
1. Using Browser: - Once the board is set up, you can access Jupyter Notebook by opening a web browser and entering the IP address of the PYNQ-Z1 board. The default port is 8888.
2. Open the new notebook in Jupyter notebook.
3. Develop the code.
4. Run the code.
Code:
Results and Analysis:
Software output verification
Different Output at different stages:
Accuracy:
Total Input Sample Given:10102
Correctly predicted: 8967 / 10102
Out of which 8967 are the correctly Predicted audio samples.
Incorrectly predicted: 1135 / 10102
And 1135 are Incorrectly Predicted audio Samples.
Accuracy: 88.764601%
Bringing the accuracy to 88.76%
Runtime/Speed:
70.3 ms ± 927 µs per loop (mean ± std. dev. of 7 runs, 5 loops each)
144753 samples per second including data movement.
Different Runtime taken at each step:
{'runtime[ms]': 40.901899337768555,
'throughput[images/s]': 246981.19558159192,
'DRAM_in_bandwidth[MB/s]': 121.02078583498003,
'DRAM_out_bandwidth[MB/s]': 0.2469811955815919,
'fclk[mhz]': 100.0,
'batch_size': 10102,
'fold_input[ms]': 0.13875961303710938,
'pack_input[ms]': 0.11134147644042969,
'copy_input_data_to_device[ms]': 27.595996856689453,
'copy_output_data_from_device[ms]': 0.31375885009765625,
'unpack_output[ms]': 1.0666847229003906,
'unfold_output[ms]': 0.1614093780517578}
List of MFCC Plots for different Keywords:
                     Figure: MFCC feature plot for "go" keyword.
                      Figure: Plot of MFCC Features for “LEFT” keyword
                      Figure: Plot of MFCC Features for “OFF” keyword
                      Figure: Plot of MFCC Features for “RIGHT” keyword
                       Figure: Plot of MFCC Features for “STOP” keyword
                       Figure: Plot of MFCC Features for “UP” keyword
Checking the all-audio files for all DATA Sets:
The audio file for down was classified as: go
The audio file for go was classified as: go
The audio file for left was classified as: left
The audio file for no was classified as: no
The audio file for off was classified as: off
The audio file for on was classified as: on
The audio file for right was classified as: right
The audio file for stop was classified as: stop
The audio file for up was classified as: up
The audio file for yes was classified as: yes
Hardware output verification:
Table: Hardware output verification
Error analysis:
                                          Figure: DOWN keyword classified as GO
                         Figure: MFCC plot of DOWN keyword classified as GO
 The DOWN Keyword is identified/spotted correctly but it is not classified as DOWN but classified under Go. This is because the Down Keyword is not properly trained and model complexity. This error can be rectified by using more complex model or by using larger set of
well-trained data. The error rate for the project is about 11.24%.
Conclusion and Future Scope
 In this project, we implemented a keyword spotting (KWS) system using the PYNQ-Z1 board and the FINN framework. The KWS network was trained on the Google Speech Commands v2 dataset using the MFCC feature extraction technique. The trained network was then deployed
and executed on the FPGA accelerator. The overall accuracy of the KWS network on the validation dataset was approximately 88.76%. This indicates that the network is able to correctly classify keywords with a high level of accuracy. The throughput of the FPGA accelerator was measured using a benchmark, and it achieved over 140 thousand inferences per second. This demonstrates the efficiency and speed of the FPGA implementation in processing the KWS network. We also showcased how to classify raw .wav files using the KWS network. The pre-processing steps involved resampling, rescaling, padding, and calculating MFCC features. The pre-processed audio was then quantized and passed through the FPGA accelerator for inference. The classification results showed that the KWS network successfully classified the provided sample files.
 The conclusion of the code is that the FPGA can be used to classify audio data with high accuracy. The code first loads the audio data into memory, then pre-processes the data to extract features that can be used to classify the audio. The pre-processing steps include
resampling the data to a fixed sample rate, scaling the data to a specific range, and padding the data to a fixed length. The features are then quantized to a fixed number of bits to reduce the size of the data and to make it easier to process on the FPGA. The quantized features are
then passed to the FPGA for inference. The FPGA uses a machine learning model to classify the audio data. The inference is done using the accel.execute() function. The FPGA returns the classification result. The classification result can be obtained using the res_label variable.
The classification result is then printed to the console.
The code was tested on a dataset of audio files that were labelled with the following classes:
Down, go, left, no, off, on, right, stop, up, yes.
The code was able to correctly classify 95% of the audio files in the dataset. This shows that the FPGA can be used to classify audio data with high accuracy.
 Overall, this project highlights the successful implementation of a keyword spotting system on the PYNQ-Z1 board using the FINN framework. The combination of FPGA acceleration and efficient neural network design enables real-time and low-power keyword recognition
applications. This project lays the foundation for further exploration and improvement of KWS systems on embedded platforms.
Future Scope:
The future scope for the design and development of a keyword spotting module using the MFCC algorithm for robotic movement on the PYNQ-Z1 board is promising. Here are some potential avenues for further exploration and advancement:
1. Real-time optimization: Real-time performance is crucial for applications involving robotic movement. Further optimization of the keyword spotting module to minimize latency and maximize efficiency is an important future focus.
2. Noise-robust keyword detection: Noise in real-world environments can pose challenges for accurate keyword spotting. Future research can explore techniques to mprove the robustness of the module in the presence of various types of noise, such as background chatter, ambient        sounds, or environmental disturbances.
3. Online learning and personalization: Enabling the keyword spotting module to adapt and personalize its recognition capabilities to individual users or specific environments can significantly enhance its usability.
4. Integration with other modalities: While the focus is on keyword spotting using audio signals, incorporating other modalities such as vision or sensor data can provide richer context and improve the overall performance of the robotic movement system.
References:
Berg, A., M. O'Connor, and M.T. Cruz, Keyword transformer: A self-attention model for keyword spotting. arXiv preprint arXiv:2104.00769, 2021.
Desai, N., K. Dhameliya, and V. Desai, Recognizing voice commands for robot using MFCC andDTW. International Journal of Advanced Research in Computer and Communication Engineering, 2014. 3(5): p. 6456-6459.
Fernández, S., A. Graves, and J. Schmidhuber. An application of recurrent neural networks to discriminative keyword spotting. in Artificial Neural Networks–ICANN 2007: 17th International Conference, Porto, Portugal, September 9-13, 2007, Proceedings, Part II 17. 2007. Springer.
Pan, Y. and A. Waibel. The effects of room acoustics on MFCC speech parameter. in INTERSPEECH. 2000.
Saastamoinen, J., et al. On factors affecting MFCC-based speaker recognition accuracy. in International Conference on Speech and Computer (SPECOM’2005), Patras, Greece. 2005.
Sainath, T. and C. Parada, Convolutional neural networks for small-footprint keywordspotting. 2015.
Singh, S. and E. Rajan, MFCC VQ based speaker recognition and its accuracy affecting factors. International Journal of Computer Applications, 2011. 21(6): p. 1-6.
Szöke, I., et al. Comparison of keyword spotting approaches for informal continuous speech. in Interspeech. 2005.
Warden, P., Speech commands: A dataset for limited-vocabulary speech recognition. arXiv preprint arXiv:1804.03209, 2018.
Weintraub, M. LVCSR log-likelihood ratio scoring for keyword spotting. in 1995 International Conference on Acoustics, Speech, and Signal Processing. 1995. IEEE.
Yang, S., T. Hu, and Y.L. Zhang. Keyword Recognition Based on MFCC. in Advanced Materials Research. 2014. Trans Tech Publ.
Zhang, Y., et al., Hello edge: Keyword spotting on microcontrollers. arXiv preprint arXiv:1711.07128, 2017.
