FPGA
FPGA
Blog Creating a Custom Kria App - Part 5
  • Author Author: albertabeef
  • Date Created: 11 Jan 2022 2:19 PM Date Created
  • Views 6477 views
  • firmware
  • kria
  • vvas
  • overlay
  • kv260
  • vitis-ai
  • app
  • dfx-mgr
  • kria app
  • smart_model_select
  • xmutil
albertabeef
albertabeef
11 Jan 2022
This blog is part of a series of blogs which describe the development steps for an in-depth project tutorial.
  • http://avnet.me/kv260-vvas-sms-2021-1-blog
This part of the tutorial describes how to build the petalinux project for the Kria KV260 Vision AI Starter Kit.
Also, we will create the yocto recipes to create the packages needed for our custom Kria app.
Building the petalinux project
The petalinux project is based on the official KV260 petalinux BSP from Xilinx:
  • xilinx-k26-starterkit-v2021.1-final.bsp
    https://www.xilinx.com/member/forms/download/xef.html?filename=xilinx-k26-som-v2021.1-updated-final.bsp
Download this bsp to same directory where the github repositories were cloned.
Use the following commands to create and configure the petalinux project:
$ cd $PROJ_DIR
$ petalinux-create –t project –s xilinx-k26-starterkit-v2021.1-final.bsp
$ cd xilinx-k26-starterkit-2021.1
$ petalinux-config --silentconfig
Make the following change to the petalinuxbsp.conf file, specifically for the KV260 board.
$ echo 'BOARD_VARIANT = "kv"' >>  project-spec/meta-user/conf/petalinuxbsp.conf
Use the following command to build the petalinux project:
$ petalinux-build
Use the following command to create the SD card image:
$ petalinux-package --wic --bootfiles "ramdisk.cpio.gz.u-boot boot.scr Image system.dtb"
$ gzip images/linux/petalinux-sdimage.wic
This will create the following image, without our custom Kria app, which can be programmed using Balena Etcher:
xilinx-k26-starterkit-2021.1/images/linux/petalinux-sdimage.wic.gz
Let’s keep a copy for reference:
$ mv images/linux/petalinux-sdimage.wic.gz ../kv260-2021-1-sdimage.wic.gz
Creating the custom Kria app
Using the petalinux project created in the previous section, we can create the custom Kria app.  This will consist of four packages:
  1. firmware package (kv260-vvas-sms): containing the bitstream, .xclbin, and device tree content our custom Kria app
  2. models package (kv260-vvas-sms-models): containing the pre-compiled models for the smart_model_select application
  3. app package (kv260-vvas-sms-app): containing the smart_model_select application
  4. packagegroup (packagegroup-kv260-vvas-sms): containing all the first level dependencies required for our custom Kria app
packagegroup
rpm packages
ap1302-ar1335-single-firmware
kv260-vvas-sms
kv260-vvas-sms-app
git
dnf
libdrm, libdrm-tests, libdrm-kms
xrt, xrt-dev
zocl
opencl-headers
packagegroup-petalinux-vitisai
packagegroup-petalinux-vitisai-dev
packagegroup-petalinux-gstreamer
packagegroup-petalinux-opencv
packagegroup-petalinux-v4lutils
packagegroup-petalinux-x11
gstreamer-vcu-examples
htop
jansson
target-factory
unilog vart, vitis-ai-library, xir
ivas-accel-libs, ivas-gst, ivas-utils
Creating the firmware package
The firmware package contains the content used by the XMUTIL utility and dynamic function exchange (DFX-MGR) service.
This content will be placed in the “/lib/firmware/xilinx/kv260-vvas-sms”, as required by the DFX-MGR service:
├── kv260-vvas-sms.bit.bin
├── kv260-vvas-sms.dtbo
├── kv260-vvas-sms.xclbin
└── shell.json
In the kv260-firmware directory that we cloned in Part 1, we will create the following sub-directory structure for the firmware files of our custom app:
kv260-firmware
└── vvas-sms
    ├── kv260-vvas-sms.dtsi
    └── shell.json
The following commands will create the above directory structure:
$ cd $PROJ_DIR/kv260-firmware
$ mkdir -p vvas-sms
$ cp ../VVAS/ivas-examples/Embedded/smart_model_select/binary_container_1/sd_card/kv260_ispMipiRx_vcu_DP_wrapper.bit vvas-sms/kv260-vvas-sms.bit
$ cp ../VVAS/ivas-examples/Embedded/smart_model_select/binary_container_1/sd_card/dpu.xclbin vvas-sms/kv260-vvas-sms.xclbin
$ cp smartcam/kv260-smartcam.dtsi vvas-sms/kv260-vvas-sms.dtsi
$ cp smartcam/shell.json vvas-sms/shell.json
Edit the kv260-vvas-sms.dtsi file as follows:
// SPDX-License-Identifier: GPL-2.0
 * dts file for Xilinx KV260 VVAS smart_model_select
 * (C) Copyright 2022, Avnet, Inc.
/dts-v1/;
/plugin/;
&fpga_full {
     #address-cells = <2>;
     #size-cells = <2>;
     firmware-name = "kv260-vvas-sms.bit.bin";
     resets = <&zynqmp_reset 116>, <&zynqmp_reset 117>, <&zynqmp_reset 118>, <&zynqmp_reset 119>;
Create the custom firmware with petalinux-create, using the “--t apps” option:
$ cd $PROJ_DIR/xilinx-k26-starterkit-2021.1
$ petalinux-create -t apps --template fpgamanager -n kv260-vvas-sms --enable --srcuri "../kv260-firmware/vvas-sms/kv260-vvas-sms.bit ../kv260-firmware/vvas-sms/kv260-vvas-sms.dtsi ../kv260-firmware/vvas-sms/kv260-vvas-sms.xclbin ../kv260-firmware/vvas-sms/shell.json" --force
This will create the yocto recipe for our custom firmware in the following location:
xilinx-k26-starterkit-2021.1/project-spec/meta-user/recipes-apps/kv260-vvas-sms
├── files
│   ├── kv260-vvas-sms.bit
│   ├── kv260-vvas-sms.dtsi
│   ├── kv260-vvas-sms.xclbin
│   └── shell.json
├── kv260-vvas-sms.bb
└── README
Creating the models package
This content will be placed in the “/opt/<vendor>/<package>” location, as defined for add-on application software packages:
  • https://refspecs.linuxfoundation.org/FHS_3.0/fhs-3.0.html#optAddonApplicationSoftwarePackages
The models will be installed at the following location:
/opt/avnet/kv260-vvas-sms/models.b3136
|-- densebox_320_320
|-- densebox_640_360
|-- inception_v1
|-- mobilenet_v2
|-- refinedet_pruned_0_96
|-- resnet18
|-- resnet50
|-- ssd_adas_pruned_0_95
|-- ssd_mobilenet_v2
|-- ssd_pedestrian_pruned_0_97
|-- ssd_traffic_pruned_0_9
|-- tiny_yolov3_vmss
|-- yolov2_voc
|-- yolov2_voc_pruned_0_77
|-- yolov3_adas_pruned_0_9
`-- yolov3_voc_tf
We need to first create the yocto recipe for the pre-compiled models:
$ mkdir -p project-spec/meta-user/recipes-apps/kv260-vvas-sms-models
$ mkdir -p project-spec/meta-user/recipes-apps/kv260-vvas-sms-models/files
$ touch project-spec/meta-user/recipes-apps/kv260-vvas-sms-models/kv260-vvas-sms-models.bb
Copy the models.b3136 content to the package definition:
$ cp -r ../VVAS/ivas-examples/Embedded/smart_model_select/models.b3136 project-spec/meta-user/recipes-apps/kv260-vvas-sms-models/files/.
Add the following content to the kv260-vvas-sms-models.bb file:
# This file is the kv260-vvas-sms-models recipe.
SUMMARY = "Pre-compiled models for kv260-vvas-sms application"
SECTION = "PETALINUX/apps"
LICENSE = "MIT"
LIC_FILES_CHKSUM = "file://${COMMON_LICENSE_DIR}/MIT;md5=0835ade698e0bcf8506ecda2f7b4f302"
SRC_URI = " \
     file://models.b3136/densebox_320_320/md5sum.txt \
     file://models.b3136/densebox_320_320/meta.json \
file://models.b3136/densebox_320_320/densebox_320_320.prototxt \
   file://models.b3136/densebox_320_320/densebox_320_320.xmodel \
     file://models.b3136/densebox_640_360/md5sum.txt \
     file://models.b3136/densebox_640_360/meta.json \
file://models.b3136/densebox_640_360/densebox_640_360.prototxt \
   file://models.b3136/densebox_640_360/densebox_640_360.xmodel \
     file://models.b3136/inception_v1/md5sum.txt \
     file://models.b3136/inception_v1/meta.json \
     file://models.b3136/inception_v1/inception_v1.prototxt \
     file://models.b3136/inception_v1/inception_v1.xmodel \
     file://models.b3136/mobilenet_v2/md5sum.txt \
     file://models.b3136/mobilenet_v2/meta.json \
     file://models.b3136/mobilenet_v2/mobilenet_v2.prototxt \
     file://models.b3136/mobilenet_v2/mobilenet_v2.xmodel \
     file://models.b3136/refinedet_pruned_0_96/md5sum.txt \
     file://models.b3136/refinedet_pruned_0_96/meta.json \
file://models.b3136/refinedet_pruned_0_96/refinedet_pruned_0_96.prototxt \
file://models.b3136/refinedet_pruned_0_96/refinedet_pruned_0_96.xmodel \
     file://models.b3136/resnet18/md5sum.txt \
     file://models.b3136/resnet18/meta.json \
     file://models.b3136/resnet18/resnet18.prototxt \
     file://models.b3136/resnet18/resnet18.xmodel \
     file://models.b3136/resnet50/md5sum.txt \
     file://models.b3136/resnet50/meta.json \
     file://models.b3136/resnet50/resnet50.prototxt \
     file://models.b3136/resnet50/resnet50.xmodel \
     file://models.b3136/ssd_adas_pruned_0_95/label.json \
     file://models.b3136/ssd_adas_pruned_0_95/md5sum.txt \
     file://models.b3136/ssd_adas_pruned_0_95/meta.json \
file://models.b3136/ssd_adas_pruned_0_95/ssd_adas_pruned_0_95.prototxt \
file://models.b3136/ssd_adas_pruned_0_95/ssd_adas_pruned_0_95.xmodel \
     file://models.b3136/ssd_mobilenet_v2/label.json \
     file://models.b3136/ssd_mobilenet_v2/md5sum.txt \
     file://models.b3136/ssd_mobilenet_v2/meta.json \
file://models.b3136/ssd_mobilenet_v2/ssd_mobilenet_v2.prototxt \
   file://models.b3136/ssd_mobilenet_v2/ssd_mobilenet_v2.xmodel \
     file://models.b3136/ssd_pedestrian_pruned_0_97/label.json \
     file://models.b3136/ssd_pedestrian_pruned_0_97/md5sum.txt \
     file://models.b3136/ssd_pedestrian_pruned_0_97/meta.json \
file://models.b3136/ssd_pedestrian_pruned_0_97/ssd_pedestrian_pruned_0_97.prototxt \
file://models.b3136/ssd_pedestrian_pruned_0_97/ssd_pedestrian_pruned_0_97.xmodel \
     file://models.b3136/ssd_traffic_pruned_0_9/label.json \
     file://models.b3136/ssd_traffic_pruned_0_9/md5sum.txt \
     file://models.b3136/ssd_traffic_pruned_0_9/meta.json \
file://models.b3136/ssd_traffic_pruned_0_9/ssd_traffic_pruned_0_9.prototxt \
file://models.b3136/ssd_traffic_pruned_0_9/ssd_traffic_pruned_0_9.xmodel \
     file://models.b3136/tiny_yolov3_vmss/label.json \
     file://models.b3136/tiny_yolov3_vmss/md5sum.txt \
     file://models.b3136/tiny_yolov3_vmss/meta.json \
file://models.b3136/tiny_yolov3_vmss/tiny_yolov3_vmss.prototxt \
   file://models.b3136/tiny_yolov3_vmss/tiny_yolov3_vmss.xmodel \
     file://models.b3136/yolov2_voc/label.json \
     file://models.b3136/yolov2_voc/md5sum.txt \
     file://models.b3136/yolov2_voc/meta.json \
     file://models.b3136/yolov2_voc/yolov2_voc.prototxt \
     file://models.b3136/yolov2_voc/yolov2_voc.xmodel \
     file://models.b3136/yolov2_voc_pruned_0_77/label.json \
     file://models.b3136/yolov2_voc_pruned_0_77/md5sum.txt \
     file://models.b3136/yolov2_voc_pruned_0_77/meta.json \
file://models.b3136/yolov2_voc_pruned_0_77/yolov2_voc_pruned_0_77.prototxt \
file://models.b3136/yolov2_voc_pruned_0_77/yolov2_voc_pruned_0_77.xmodel \
     file://models.b3136/yolov3_adas_pruned_0_9/label.json \
     file://models.b3136/yolov3_adas_pruned_0_9/md5sum.txt \
     file://models.b3136/yolov3_adas_pruned_0_9/meta.json \
file://models.b3136/yolov3_adas_pruned_0_9/yolov3_adas_pruned_0_9.prototxt \
file://models.b3136/yolov3_adas_pruned_0_9/yolov3_adas_pruned_0_9.xmodel \
     file://models.b3136/yolov3_voc_tf/label.json \
     file://models.b3136/yolov3_voc_tf/md5sum.txt \
     file://models.b3136/yolov3_voc_tf/meta.json \
     file://models.b3136/yolov3_voc_tf/yolov3_voc_tf.prototxt \
     file://models.b3136/yolov3_voc_tf/yolov3_voc_tf.xmodel \
S = "${WORKDIR}"
do_install() {
     install -d ${D}/opt/avnet
     install -d ${D}/opt/avnet/kv260-vvas-sms
     install -d ${D}/opt/avnet/kv260-vvas-sms/models.b3136
     install -d ${D}/opt/avnet/kv260-vvas-sms/models.b3136/densebox_320_320
     install -m 0755 models.b3136/densebox_320_320/* ${D}/opt/avnet/kv260-vvas-sms/models.b3136/densebox_320_320
     install -d ${D}/opt/avnet/kv260-vvas-sms/models.b3136/densebox_640_360
     install -m 0755 models.b3136/densebox_640_360/* ${D}/opt/avnet/kv260-vvas-sms/models.b3136/densebox_640_360
     install -d ${D}/opt/avnet/kv260-vvas-sms/models.b3136/inception_v1
     install -m 0755 models.b3136/inception_v1/* ${D}/opt/avnet/kv260-vvas-sms/models.b3136/inception_v1
     install -d ${D}/opt/avnet/kv260-vvas-sms/models.b3136/mobilenet_v2
     install -m 0755 models.b3136/mobilenet_v2/* ${D}/opt/avnet/kv260-vvas-sms/models.b3136/mobilenet_v2
     install -d ${D}/opt/avnet/kv260-vvas-sms/models.b3136/refinedet_pruned_0_96
     install -m 0755 models.b3136/refinedet_pruned_0_96/* ${D}/opt/avnet/kv260-vvas-sms/models.b3136/refinedet_pruned_0_96
     install -d ${D}/opt/avnet/kv260-vvas-sms/models.b3136/resnet18
     install -m 0755 models.b3136/resnet18/* ${D}/opt/avnet/kv260-vvas-sms/models.b3136/resnet18
     install -d ${D}/opt/avnet/kv260-vvas-sms/models.b3136/resnet50
     install -m 0755 models.b3136/resnet50/* ${D}/opt/avnet/kv260-vvas-sms/models.b3136/resnet50
     install -d ${D}/opt/avnet/kv260-vvas-sms/models.b3136/ssd_adas_pruned_0_95
     install -m 0755 models.b3136/ssd_adas_pruned_0_95/* ${D}/opt/avnet/kv260-vvas-sms/models.b3136/ssd_adas_pruned_0_95
     install -d ${D}/opt/avnet/kv260-vvas-sms/models.b3136/ssd_mobilenet_v2
     install -m 0755 models.b3136/ssd_mobilenet_v2/* ${D}/opt/avnet/kv260-vvas-sms/models.b3136/ssd_mobilenet_v2
     install -d ${D}/opt/avnet/kv260-vvas-sms/models.b3136/ssd_pedestrian_pruned_0_97
     install -m 0755 models.b3136/ssd_pedestrian_pruned_0_97/* ${D}/opt/avnet/kv260-vvas-sms/models.b3136/ssd_pedestrian_pruned_0_97
     install -d ${D}/opt/avnet/kv260-vvas-sms/models.b3136/ssd_traffic_pruned_0_9
     install -m 0755 models.b3136/ssd_traffic_pruned_0_9/* ${D}/opt/avnet/kv260-vvas-sms/models.b3136/ssd_traffic_pruned_0_9
     install -d ${D}/opt/avnet/kv260-vvas-sms/models.b3136/tiny_yolov3_vmss
     install -m 0755 models.b3136/tiny_yolov3_vmss/* ${D}/opt/avnet/kv260-vvas-sms/models.b3136/tiny_yolov3_vmss
     install -d ${D}/opt/avnet/kv260-vvas-sms/models.b3136/yolov2_voc
     install -m 0755 models.b3136/yolov2_voc/* ${D}/opt/avnet/kv260-vvas-sms/models.b3136/yolov2_voc
     install -d ${D}/opt/avnet/kv260-vvas-sms/models.b3136/yolov2_voc_pruned_0_77
     install -m 0755 models.b3136/yolov2_voc_pruned_0_77/* ${D}/opt/avnet/kv260-vvas-sms/models.b3136/yolov2_voc_pruned_0_77
     install -d ${D}/opt/avnet/kv260-vvas-sms/models.b3136/yolov3_adas_pruned_0_9
     install -m 0755 models.b3136/yolov3_adas_pruned_0_9/* ${D}/opt/avnet/kv260-vvas-sms/models.b3136/yolov3_adas_pruned_0_9
     install -d ${D}/opt/avnet/kv260-vvas-sms/models.b3136/yolov3_voc_tf
     install -m 0755 models.b3136/yolov3_voc_tf/* ${D}/opt/avnet/kv260-vvas-sms/models.b3136/yolov3_voc_tf
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/densebox_320_320/md5sum.txt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/densebox_320_320/meta.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/densebox_320_320/densebox_320_320.prototxt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/densebox_320_320/densebox_320_320.xmodel"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/densebox_640_360/md5sum.txt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/densebox_640_360/meta.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/densebox_640_360/densebox_640_360.prototxt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/densebox_640_360/densebox_640_360.xmodel"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/inception_v1/md5sum.txt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/inception_v1/meta.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/inception_v1/inception_v1.prototxt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/inception_v1/inception_v1.xmodel"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/mobilenet_v2/md5sum.txt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/mobilenet_v2/meta.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/mobilenet_v2/mobilenet_v2.prototxt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/mobilenet_v2/mobilenet_v2.xmodel"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/refinedet_pruned_0_96/md5sum.txt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/refinedet_pruned_0_96/meta.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/refinedet_pruned_0_96/refinedet_pruned_0_96.prototxt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/refinedet_pruned_0_96/refinedet_pruned_0_96.xmodel"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/resnet18/md5sum.txt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/resnet18/meta.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/resnet18/resnet18.prototxt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/resnet18/resnet18.xmodel"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/resnet50/md5sum.txt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/resnet50/meta.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/resnet50/resnet50.prototxt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/resnet50/resnet50.xmodel"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/ssd_adas_pruned_0_95/label.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/ssd_adas_pruned_0_95/md5sum.txt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/ssd_adas_pruned_0_95/meta.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/ssd_adas_pruned_0_95/ssd_adas_pruned_0_95.prototxt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/ssd_adas_pruned_0_95/ssd_adas_pruned_0_95.xmodel"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/ssd_mobilenet_v2/label.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/ssd_mobilenet_v2/md5sum.txt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/ssd_mobilenet_v2/meta.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/ssd_mobilenet_v2/ssd_mobilenet_v2.prototxt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/ssd_mobilenet_v2/ssd_mobilenet_v2.xmodel"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/ssd_pedestrian_pruned_0_97/label.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/ssd_pedestrian_pruned_0_97/md5sum.txt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/ssd_pedestrian_pruned_0_97/meta.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/ssd_pedestrian_pruned_0_97/ssd_pedestrian_pruned_0_97.prototxt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/ssd_pedestrian_pruned_0_97/ssd_pedestrian_pruned_0_97.xmodel"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/ssd_traffic_pruned_0_9/label.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/ssd_traffic_pruned_0_9/md5sum.txt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/ssd_traffic_pruned_0_9/meta.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/ssd_traffic_pruned_0_9/ssd_traffic_pruned_0_9.prototxt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/ssd_traffic_pruned_0_9/ssd_traffic_pruned_0_9.xmodel"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/tiny_yolov3_vmss/label.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/tiny_yolov3_vmss/md5sum.txt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/tiny_yolov3_vmss/meta.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/tiny_yolov3_vmss/tiny_yolov3_vmss.prototxt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/tiny_yolov3_vmss/tiny_yolov3_vmss.xmodel"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/yolov2_voc/label.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/yolov2_voc/md5sum.txt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/yolov2_voc/meta.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/yolov2_voc/yolov2_voc.prototxt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/yolov2_voc/yolov2_voc.xmodel"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/yolov2_voc_pruned_0_77/label.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/yolov2_voc_pruned_0_77/md5sum.txt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/yolov2_voc_pruned_0_77/meta.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/yolov2_voc_pruned_0_77/yolov2_voc_pruned_0_77.prototxt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/yolov2_voc_pruned_0_77/yolov2_voc_pruned_0_77.xmodel"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/yolov3_adas_pruned_0_9/label.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/yolov3_adas_pruned_0_9/md5sum.txt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/yolov3_adas_pruned_0_9/meta.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/yolov3_adas_pruned_0_9/yolov3_adas_pruned_0_9.prototxt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/yolov3_adas_pruned_0_9/yolov3_adas_pruned_0_9.xmodel"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/yolov3_voc_tf/label.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/yolov3_voc_tf/md5sum.txt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/yolov3_voc_tf/meta.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/yolov3_voc_tf/yolov3_voc_tf.prototxt"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/models.b3136/yolov3_voc_tf/yolov3_voc_tf.xmodel"
Creating the app package
The application and supporting files will be installed at the following location:
/opt/avnet/kv260-vvas-sms/app
|-- jsons
|   |-- kernel_bbox.json
|   `-- kernel_dpu.json
|-- setup.sh
|-- smart_model_select
|-- templates
|   |-- file_fake_template.cfg
|   |-- file_file_template.cfg
|   |-- file_kms_template.cfg
|   |-- mipi_fake_template.cfg
|   |-- mipi_file_template.cfg
|   |-- mipi_kms_template.cfg
|   |-- rtsp_fake_template.cfg
|   |-- rtsp_file_template.cfg
|   |-- rtsp_kms_template.cfg
|   |-- usbcam_fake_template.cfg
|   |-- usbcam_file_template.cfg
|   |-- usbcam_kms_template.cfg
|   |-- welcome.cfg
`-- videos
    |-- CLASSIFICATION.mp4
    |-- FACEDETECT.mp4
    |-- REFINEDET.mp4
    |-- SSD.mp4
    |-- YOLOV2.mp4
    `-- YOLOV3.mp4
We start by creating the yocto recipe for the smart_model_select application:
$ mkdir -p project-spec/meta-user/recipes-apps/kv260-vvas-sms-app
$ mkdir -p project-spec/meta-user/recipes-apps/kv260-vvas-sms-app/files
$ touch project-spec/meta-user/recipes-apps/kv260-vvas-sms-app/kv260-vvas-sms-app.bb
Copy the source code for the application:
$ cp ../VVAS/ivas-examples/Embedded/smart_model_select/src/smart_model_select.c project-spec/meta-user/recipes-apps/kv260-vvas-sms-models/files/.
Copy the json configuration files for the application:
$ mkdir project-spec/meta-user/recipes-apps/kv260-vvas-sms-app/files/jsons
$ cp ../VVAS/ivas-examples/Embedded/smart_model_select/src/jsons/kernel*.json project-spec/meta-user/recipes-apps/kv260-vvas-sms-app/files/jsons/.
Edit the “kernel_dpu.json” configuration file, to specify the valid “model-path” for the custom Kria app, as follows:
  "xclbin-location":"XCLBIN_PATH",
  "ivas-library-repo": "/usr/lib/",
  "element-mode":"inplace",
  "kernels" :[
    "library-name":"libivas_xdpuinfer.so",
    "config": {
    "model-name" : "MODEL",
    "model-class" : "CLASS",
    "model-format" : "FORMAT",
    "model-path" : "/opt/avnet/kv260-vvas-sms/models.b3136/",
    "run_time_model" : false,
    "need_preprocess" : false,
    "performance_test" : false,
    "debug_level" : 1
Copy the template files for the application:
$ mkdir project-spec/meta-user/recipes-apps/kv260-vvas-sms-app/files/templates
$ cp -r ../VVAS/ivas-examples/Embedded/smart_model_select/templates project-spec/meta-user/recipes-apps/kv260-vvas-sms-app/files/templates/.
Copy the video files for the application:
$ mkdir -p project-spec/meta-user/recipes-apps/kv260-vvas-sms-app/files/videos
$ cp ../videos_smart_model_select/*.mp4 project-spec/meta-user/recipes-apps/kv260-vvas-sms-app/files/videos/.
Copy the setup script for the application:
$ cp ../VVAS/ivas-examples/Embedded/smart_model_select/setup.sh project-spec/meta-user/recipes-apps/kv260-vvas-sms-app/files/.
Edit the “setup.sh” script as follows:
export XCLBIN_PATH=/lib/firmware/xilinx/kv260-vvas-sms/kv260-vvas-sms.xclbin
# Set alpha plane.
modetest -M xlnx -w 40:alpha:0
# Force DP resolution to 1080P and display diagonal test pattern
modetest -M xlnx -s 43@41:1920x1080-60@AR24 -P 39@41:1920x1080@NV12  -w 40:alpha:0 &
Add the following content to the kv260-vvas-sms-app.bb file:
# This file is the kv260-vvas-sms-app recipe.
SUMMARY = "Simple kv260-vvas-sms-app application"
LICENSE = "MIT"
SRC_URI = " \
     file://smart_model_select.c \
     file://setup.sh \
     file://jsons/kernel_bbox.json \
     file://jsons/kernel_dpu.json \
     file://templates/welcome_1080.jpg \
     file://templates/welcome.cfg \
     file://templates/file_fake_template.cfg \
     file://templates/file_fake_template_perf.cfg \
     file://templates/file_file_template.cfg \
     file://templates/file_kms_template.cfg \
     file://templates/rtsp_fake_template.cfg \
     file://templates/rtsp_file_template.cfg \
     file://templates/rtsp_kms_template.cfg \
     file://templates/usbcam_fake_template.cfg \
     file://templates/usbcam_file_template.cfg \
     file://templates/usbcam_kms_template.cfg \
     file://templates/mipi_fake_template.cfg \
     file://templates/mipi_file_template.cfg \
     file://templates/mipi_kms_template.cfg \
     file://videos/CLASSIFICATION.mp4 \
     file://videos/FACEDETECT.mp4 \
     file://videos/REFINEDET.mp4 \
     file://videos/SSD.mp4 \
     file://videos/YOLOV2.mp4 \
     file://videos/YOLOV3.mp4 \
S = "${WORKDIR}"
DEPENDS = "glib-2.0 glib-2.0-native xrt libcap libxml2 bison-native flex-native jansson ivas-utils ivas-gst opencv vitis-ai-library vart"
do_compile() {
     ${CC} ${CFLAGS} ${LDFLAGS} -o smart_model_select smart_model_select.c -lpthread
do_install() {
     install -d ${D}/opt/avnet/kv260-vvas-sms/app
     install -m 0755 smart_model_select ${D}/opt/avnet/kv260-vvas-sms/app
     install -m 0755 setup.sh           ${D}/opt/avnet/kv260-vvas-sms/app
     install -d ${D}/opt/avnet/kv260-vvas-sms/app/jsons
     install -m 0755 jsons/kernel_bbox.json ${D}/opt/avnet/kv260-vvas-sms/app/jsons
     install -m 0755 jsons/kernel_dpu.json  ${D}/opt/avnet/kv260-vvas-sms/app/jsons
     install -d ${D}/opt/avnet/kv260-vvas-sms/app/templates
     install -m 0755 templates/welcome_1080.jpg       ${D}/opt/avnet/kv260-vvas-sms/app/templates
     install -m 0755 templates/welcome.cfg            ${D}/opt/avnet/kv260-vvas-sms/app/templates
     install -m 0755 templates/file_*_template.cfg    ${D}/opt/avnet/kv260-vvas-sms/app/templates
     install -m 0755 templates/rtsp_*_template.cfg    ${D}/opt/avnet/kv260-vvas-sms/app/templates
     install -m 0755 templates/usbcam_*_template.cfg  ${D}/opt/avnet/kv260-vvas-sms/app/templates
     install -m 0755 templates/mipi_*_template.cfg    ${D}/opt/avnet/kv260-vvas-sms/app/templates
     install -d ${D}/opt/avnet/kv260-vvas-sms/app/videos
     install -m 0755 videos/CLASSIFICATION.mp4 ${D}/opt/avnet/kv260-vvas-sms/app/videos
     install -m 0755 videos/FACEDETECT.mp4     ${D}/opt/avnet/kv260-vvas-sms/app/videos
     install -m 0755 videos/REFINEDET.mp4      ${D}/opt/avnet/kv260-vvas-sms/app/videos
     install -m 0755 videos/SSD.mp4            ${D}/opt/avnet/kv260-vvas-sms/app/videos
     install -m 0755 videos/YOLOV2.mp4         ${D}/opt/avnet/kv260-vvas-sms/app/videos
     install -m 0755 videos/YOLOV3.mp4         ${D}/opt/avnet/kv260-vvas-sms/app/videos
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/app/smart_model_select"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/app/setup.sh"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/app/jsons/kernel_bbox.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/app/jsons/kernel_dpu.json"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/app/templates/welcome_1080.jpg"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/app/templates/welcome.cfg"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/app/templates/file_fake_template.cfg"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/app/templates/file_fake_template_perf.cfg"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/app/templates/file_file_template.cfg"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/app/templates/file_kms_template.cfg"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/app/templates/rtsp_fake_template.cfg"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/app/templates/rtsp_file_template.cfg"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/app/templates/rtsp_kms_template.cfg"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/app/templates/usbcam_fake_template.cfg"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/app/templates/usbcam_file_template.cfg"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/app/templates/usbcam_kms_template.cfg"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/app/templates/mipi_fake_template.cfg"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/app/templates/mipi_file_template.cfg"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/app/templates/mipi_kms_template.cfg"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/app/videos/CLASSIFICATION.mp4"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/app/videos/FACEDETECT.mp4"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/app/videos/REFINEDET.mp4"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/app/videos/SSD.mp4"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/app/videos/YOLOV2.mp4"
FILES_${PN} += "/opt/avnet/kv260-vvas-sms/app/videos/YOLOV3.mp4"
Creating the dependencies packagegroup
Next, we want to create a packagegroup that contains all the dependencies for our custom Kria app:
$ mkdir -p project-spec/meta-user/recipes-core/packagegroups
$ touch project-spec/meta-user/recipes-core/packagegroups/packagegroup-kv260-vvas-sms.bb
Add the following content to the packagegroup-kv260-vvas-sms.bb file:
DESCRIPTION = "KV260 VVAS smart_model_select related packages"
inherit packagegroup
KV260_VVAS_SMS_PACKAGES = " \
   ap1302-ar1335-single-firmware \
   kv260-vvas-sms \
   kv260-vvas-sms-models \
   kv260-vvas-sms-app \
   git \
   dnf \
   libdrm libdrm-tests libdrm-kms \
   xrt xrt-dev \
   zocl \
   opencl-headers \
   packagegroup-petalinux-vitisai \
   packagegroup-petalinux-vitisai-dev \
   packagegroup-petalinux-gstreamer \
   packagegroup-petalinux-opencv \
   packagegroup-petalinux-v4lutils \
   packagegroup-petalinux-x11 \
   gstreamer-vcu-examples \
   htop \
   jansson \
   target-factory \
   unilog vart vitis-ai-library xir \
   ivas-accel-libs ivas-gst ivas-utils \
RDEPENDS_${PN} = "${KV260_VVAS_SMS_PACKAGES}"
COMPATIBLE_MACHINE = "^$"
COMPATIBLE_MACHINE_k26-kv = "${MACHINE}"
PACKAGE_ARCH = "${BOARDVARIANT_ARCH}"
Building the new packages
We want to make the petalinux project aware of these new packages as follows:
$ echo "CONFIG_kv260-vvas-sms-models" >> project-spec/meta-user/conf/user-rootfsconfig
$ echo "CONFIG_kv260-vvas-sms-apps" >> project-spec/meta-user/conf/user-rootfsconfig
$ echo "CONFIG_packagegroup-kv260-vvas-sms" >> project-spec/meta-user/conf/user-rootfsconfig
We also want to enable the new packages as follows:
$ echo "CONFIG_kv260-vvas-sms-models=y" >> project-spec/configs/rootfs_config
$ echo "CONFIG_kv260-vvas-sms-app=y" >> project-spec/configs/rootfs_config
$ echo "CONFIG_packagegroup-kv260-vvas-sms=y" >> project-spec/configs/rootfs_config
Use the following command to build the petalinux packages:
$ petalinux-build -c kv260-vvas-sms
$ petalinux-build -c kv260-vvas-sms-models
$ petalinux-build -c kv260-vvas-sms-app
$ petalinux-build -c packagegroup-kv260-vvas-sms
$ petalinux-build
This will create the following image, this time with our custom Kria app, which can be programmed using Balena Etcher:
$ mv images/linux/petalinux-sdimage.wic.gz ../kv260-vvas-sms-2021-1-sdimage.wic.gz
The rpm packages will be located in the following directories:
build/tmp/work/zynqmp_generic-xilinx-linux/kv260-vvas-sms/1.0-r0/deploy-rpms/
└── zynqmp_generic
    ├── kv260-vvas-sms-1.0-r0.0.zynqmp_generic.rpm
    ├── kv260-vvas-sms-dbg-1.0-r0.0.zynqmp_generic.rpm
    ├── kv260-vvas-sms-dev-1.0-r0.0.zynqmp_generic.rpm
    └── kv260-vvas-sms-lic-1.0-r0.0.zynqmp_generic.rpm
build/tmp/work/cortexa72-cortexa53-xilinx-linux/kv260-vvas-sms-models/1.0-r0/deploy-rpms/
└── cortexa72-cortexa53
    ├── kv260-vvas-sms-models-1.0-r0.0.zynqmp_generic.rpm
    ├── kv260-vvas-sms-models-dbg-1.0-r0.0.zynqmp_generic.rpm
    ├── kv260-vvas-sms-models-dev-1.0-r0.0.zynqmp_generic.rpm
    └── kv260-vvas-sms-models-lic-1.0-r0.0.zynqmp_generic.rpm
build/tmp/work/cortexa72-cortexa53-xilinx-linux/kv260-vvas-sms-app/1.0-r0/deploy-rpms/
    ├── kv260-vvas-sms-app-1.0-r0.0.zynqmp_generic.rpm
    ├── kv260-vvas-sms-app-dbg-1.0-r0.0.zynqmp_generic.rpm
    ├── kv260-vvas-sms-app-dev-1.0-r0.0.zynqmp_generic.rpm
    └── kv260-vvas-sms-app-lic-1.0-r0.0.zynqmp_generic.rpm
build/tmp/work/all-xilinx-linux/packagegroup-kv260-vvas-sms/1.0-r0/deploy-rpms/
└── noarch
    ├── packagegroup-kv260-vvas-sms-1.0-r0.0.noarch.rpm
    ├── packagegroup-kv260-vvas-sms-dbg-1.0-r0.0.noarch.rpm
    ├── packagegroup-kv260-vvas-sms-dev-1.0-r0.0.noarch.rpm
    ├── packagegroup-kv260-vvas-sms-lic-1.0-r0.0.noarch.rpm
    └── packagegroup-kv260-vvas-sms-ptest-1.0-r0.0.noarch.rpm
Next Steps
The following blogs cover the previous development steps for this in-depth project tutorial.
  • http://avnet.me/kv260-vvas-sms-2021-1-part1
  • http://avnet.me/kv260-vvas-sms-2021-1-part2
  • http://avnet.me/kv260-vvas-sms-2021-1-part3
  • http://avnet.me/kv260-vvas-sms-2021-1-part4
The following blogs will cover the remaining development steps for this in-depth project tutorial.
  • http://avnet.me/kv260-vvas-sms-2021-1-part6
  • http://avnet.me/kv260-vvas-sms-2021-1-part7
