FPGA
FPGA
Blog Learning Vitis: Build Environment Quickie 2 - Wide Terminal?!
  • Author Author: drozwood90
  • Date Created: 30 Apr 2020 3:18 PM Date Created
  • Views 1099 views
drozwood90
drozwood90
30 Apr 2020
Make Terminal Easier to Use
Upon completing the install of Ubuntu, terminal is setup with a default of 24 columns. As MOST paths and commands we typically work with in a Linux based Xilinx environment are rather long it can make sense to increase the columns from 80 to 120 (or more!).
This not only allows you to actually see text easier, but it makes things more clear to understand.  With the new Vitis scripting, Avnet has added many new messages and colors to logs and terminal reporting.  This HOPEFULLY will increase your efficiency as you do not have to spend as much time dealing with understanding as doing!
Open a terminal, then Edit -> Preferences
Adjust the columns from 80 to 120
  • drozwood90
    drozwood90 over 5 years ago
    Hi all,
    I wanted to make it easier to find the various Vitis articles.  And while you can certainly just search, here is a nice easy list for you!
    Learning Vitis: 1 Setting up a Virtual Machine
    Learning Vitis: Build Environment Quickie 1 - See forever!
    Learning Vitis: 2 How to Download and "install" a pre-built platform
    Learning Vitis: 3 How to build an Example Application
    Learning Vitis: Build Environment Quickie 3 - A Tidy Shop is a Productive Shop
    Learning Vitis: 4 How to TEST an Example Application
    Learning Vitis: Build Environment Quickie 5 - Monitor the World?
    --Dan
  • drozwood90
    Hi all,
    --Dan
