FPGA
FPGA
Blog Learning Vitis: Build Environment Quickie 3 - A Tidy Shop is a Productive Shop
  • Author Author: drozwood90
  • Date Created: 30 Apr 2020 3:20 PM Date Created
  • Views 819 views
drozwood90
drozwood90
30 Apr 2020
Cleanup Favorites
Ubuntu defaults to quite a selection of items on the favorites bar.  These make sense if you are using this as a primary operating system. In the case of how we intend to use this, most of these do not make sense.  It is suggested to remove all but the bare essential items.  This allows for more room at various resolutions for icons we care about, such as terminal sessions, GTKTerm, Vitis, etc.
  First, right click an item on the favorites bar, then left click on “Remove From Favorites”
→imageimage
  • drozwood90
    drozwood90 over 5 years ago
    Hi all,
    I wanted to make it easier to find the various Vitis articles.  And while you can certainly just search, here is a nice easy list for you!
    Learning Vitis: 1 Setting up a Virtual Machine
    Learning Vitis: Build Environment Quickie 1 - See forever!
    Learning Vitis: 2 How to Download and "install" a pre-built platform
    Learning Vitis: Build Environment Quickie 2 - Wide Terminal?!
    Learning Vitis: 3 How to build an Example Application
    Learning Vitis: 4 How to TEST an Example Application
    Learning Vitis: Build Environment Quickie 5 - Monitor the World?
    --Dan
