FPGA
FPGA
Blog Stereo Calibration for the Dual Camera Mezzanine
  • Author Author: albertabeef
  • Date Created: 10 Aug 2022 5:21 PM Date Created
  • Views 21433 views
  • Likes 10 likes
  • ultra96v2
  • ultra96-v2
  • isp
  • 96 boards
  • ar0144
  • onsemi dual mipi camera
  • 96boards on semiconductor dual camera mezzanine
  • ap1302
  • dual camera
  • stereo calibration
  • stereo
  • ias
albertabeef
albertabeef
10 Aug 2022
This blog post provides details on how to perform stereo calibration for the Ultra96-V2 development board with Dual-Camera Mezzanine.
Getting Started with the pre-built image
If you want to re-build the vivado 2021.2 and petalinux 2021.2 projects yourself, refer to the following blog post:
  • https://avnet.me/u96v2-dualcam-2021.2
If you want to start from a pre-built image, use the 201.2 design that is augmented with Vitis-AI 2.0, available in the following project:
  •  https://avnet.me/vitis-ai-2.0-dualcam
Cloning the dualcam python examples repository
With the SD card image programmed on hardware, and the Ultra96-V2 configured for WIFI access, clone the following repository:
$ git clone -b 2021.2 https://github.com/AlbertaBeef/avnet_dualcam_python_examples
$ cd avnet_dualcam_python_examples
Stereo Calibration Theory
This tutorial will not cover the theory behind stereo calibration, as this topic is well documented on-line.
For more details on camera calibration and stereo calibration, refer to the following articles from LearnOpenCV:
  • https://learnopencv.com/camera-calibration-using-opencv/
  • https://learnopencv.com/introduction-to-epipolar-geometry-and-stereo-vision/
  • https://learnopencv.com/making-a-low-cost-stereo-camera-using-opencv/
In summary, the goal of the calibration process is to understand the mathematical model between 3D coordinates in the real-world, and 2D coordinates in captured images.
Camera calibration allows removal of undesirable effects such as lens distortion:
For stereo calibration, the two cameras are further calibrated in order to achieve epipolar geometry.
This means that each point in one image will appear on the same horizontal line in the other image, and makes the depth estimation problem mathematically feasible.
Most calibration algorithms make use of a chessboard image, since it has known geometry which can be detected in the 3D real-world.
My favorite calibration procedure is the one presented by Luxonis for their stereo OAK-D camera.
  • https://docs.luxonis.com/en/latest/pages/calibration/
Luxonis make use of a chessboard, augmented with AruCo markers, which makes the calibration chart detection faster and more efficient.
They also provide a guided sequence of 13 poses, that make the entire calibration more user friendly.
This tutorial is inspired by the above existing calibration techniques.
Printing the Calibration Chart
As mentioned before, we will be using a chessboard image augmented with ArUco markers, also called the ChArUco chart.
Print the following chart on a sheet of paper:
  • https://github.com/luxonis/depthai/blob/main/charuco_11x8.pdf
Next, fix the chart on a rigid surface in order to eliminate all warps in the chart.  This important as imperfections will affect the calibration accuracy.
Measure the real size of the chessboard squares, and ArUco markers.
As an example, for the example images captured in the repo, this was:
  • square size = 21mm
  • marker size = 16.5mm
Performing Stereo Calibration
The stereo calibration procedure is performed by the following script:
  • https://github.com/AlbertaBeef/avnet_dualcam_python_examples/blob/2021.2/avnet_dualcam_ar0144_stereo_calibrate.py
The calibration script guides the user to capture 13 pairs of images (called left_p[0-12].png and right_p[0-12].png, respectfully), which have the calibration chart placed in the following general orientation:
For each capture, it is important to have the calibration chart facing the dual camera mezzanine, in the approximate position illustrated, and visible in both left and right images.
An example of the capture pairs of images can be viewed in the following directories:
  • https://github.com/AlbertaBeef/avnet_dualcam_python_examples/tree/2021.2/stereo_data/left
  • https://github.com/AlbertaBeef/avnet_dualcam_python_examples/tree/2021.2/stereo_data/right
The calibration output corresponding to these images is provided in the following file:
  • https://github.com/AlbertaBeef/avnet_dualcam_python_examples/blob/2021.2/stereo_data/calib/dualcam_stereo.yml
This file contains the following calibrated data:
  • Camera Calibration data (for each camera)
    • Lens Distortion Coefficients
      • D1/D2 (radial and tangential distortion)
      Intrinsic Matrices (camera to image)
      • K1/K2 (focal length fx&fy, optical center)
    • Extrinsic Matrices (real world to camera)
      • R1/R2 (rotation&translation matrix)
    • Projection Matrices
      • P1/P2
  • Stereo Calibration data
    • Rotation Matrix
      • R
    • Translation Matrix
      • T
    • Essential Matrix
      • E = T × R
    • Fundamental Matrix
      • F = inv(K2)T × E × inv(K1)
To run the calibration procedure, invoke the script as follows:
$ python3 avnet_dualcam_ar0144_stereo_calibrate.py --squareSizeCm 2.15 --markerSizeCm 1.65 --invertHorizontal
The provided arguments are defined as follows:
  • squareSizeCm : chessboard square size (defined previously as 21.5mm, provided in cm)
  • markerSizeCm : marker size (defined previously as 16.5mm, provided in cm)
  • invertHorizontal : invert images horizontally to facilitate placement of calibration chart
The calibration procedure consists of two modes, which are both executed by default:
  • capture, where 13 pairs of images of size 1280x800 will be captured and saved in the following directories:
    • ./stereo_data/left
    • ./stereo_data/right
  • process, where the stereo calibration will be performed, and results saved in the following file:
    • ./stereo_data/calib/dualcam_stereo.yml
The first image displayed will be an informative message indicating which keys to press during the capture mode.
Next, the capture process will query for 13 poses, as illustrated in this video:
https://youtu.be/E9cSIWInueE
For each capture, it is important to have the calibration chart facing the dual camera mezzanine, in the approximate position illustrated, and entirely visible in both left and right images.
Once the capture mode is finished, the process mode will automatically start.
Note that it is possible to execute the capture and process modes seperately using the following argument:
  • --mode capture : only execute capture (image capture)
  • --mode process : only execute process (calibration)
Here is an example output of a complete capture + process session.
[DualCam] Looking for devices corresponding to AP1302
/dev/video2
/dev/media1
ap1302.0-003c
[DualCam] Detected SYZYGY dualcam (sensors placed left-right on board)
[DualCam] Initializing capture pipeline for ar0144_dual 1280 800
media-ctl -d /dev/media1 -V "'ap1302.0-003c':2 [fmt:UYVY8_1X16/2560x800 field:none]"
media-ctl -d /dev/media1 -V "'b0000000.mipi_csi2_rx_subsystem':0 [fmt:UYVY8_1X16/2560x800 field:none]"
media-ctl -d /dev/media1 -V "'b0000000.mipi_csi2_rx_subsystem':1 [fmt:UYVY8_1X16/2560x800 field:none]"
media-ctl -d /dev/media1 -V "'b0010000.v_proc_ss':0 [fmt:UYVY8_1X16/2560x800 field:none]"
media-ctl -d /dev/media1 -V "'b0010000.v_proc_ss':1 [fmt:RBG24/2560x800 field:none]"
media-ctl -d /dev/media1 -V "'b0040000.v_proc_ss':0 [fmt:RBG24/2560x800 field:none]"
media-ctl -d /dev/media1 -V "'b0040000.v_proc_ss':1 [fmt:RBG24/2560x800 field:none]"
[DualCam] Disabling Auto White Balance
v4l2-ctl --set-ctrl white_balance_auto_preset=0 -d /dev/video2
[DualCam] Opening cv2.VideoCapture for 2560 800
Starting image capture. Press the [ESC] key to abort.
Will take 13 total images, 1 per each polygon.
800 1280
Capturing ------------------------
Markers count ... 44
py: Saved image as: left_p0_0.png
py: Saved image as: right_p0_0.png
Images captured --> 0
Markers count ... 34
py: Saved image as: left_p1_1.png
Markers count ... 39
py: Saved image as: right_p1_1.png
Images captured --> 1
Markers count ... 42
py: Saved image as: left_p2_2.png
py: Saved image as: right_p2_2.png
Images captured --> 2
Markers count ... 43
py: Saved image as: left_p3_3.png
Markers count ... 40
py: Saved image as: right_p3_3.png
Images captured --> 3
py: Saved image as: left_p4_4.png
Markers count ... 37
py: Saved image as: right_p4_4.png
Images captured --> 4
py: Saved image as: left_p5_5.png
py: Saved image as: right_p5_5.png
Images captured --> 5
Markers count ... 26
py: Saved image as: left_p6_6.png
Markers count ... 38
py: Saved image as: right_p6_6.png
Images captured --> 6
py: Saved image as: left_p7_7.png
py: Saved image as: right_p7_7.png
Images captured --> 7
py: Saved image as: left_p8_8.png
py: Saved image as: right_p8_8.png
Images captured --> 8
py: Saved image as: left_p9_9.png
py: Saved image as: right_p9_9.png
Images captured --> 9
py: Saved image as: left_p10_10.png
Markers count ... 41
py: Saved image as: right_p10_10.png
Images captured --> 10
py: Saved image as: left_p11_11.png
Markers count ... 31
py: Saved image as: right_p11_11.png
Images captured --> 11
Markers count ... 35
py: Saved image as: left_p12_12.png
py: Saved image as: right_p12_12.png
Images captured --> 12
Starting image processing
~~~~~~~~~~~ POSE ESTIMATION LEFT CAMERA ~~~~~~~~~~~~~
=> Processing image /home/root/avnet_dualcam_python_examples/stereo_data/left/left_p0_0.png
44 number of Markers corners detected in the above image
=> Processing image /home/root/avnet_dualcam_python_examples/stereo_data/left/left_p10_10.png
=> Processing image /home/root/avnet_dualcam_python_examples/stereo_data/left/left_p11_11.png
=> Processing image /home/root/avnet_dualcam_python_examples/stereo_data/left/left_p12_12.png
=> Processing image /home/root/avnet_dualcam_python_examples/stereo_data/left/left_p1_1.png
=> Processing image /home/root/avnet_dualcam_python_examples/stereo_data/left/left_p2_2.png
=> Processing image /home/root/avnet_dualcam_python_examples/stereo_data/left/left_p3_3.png
=> Processing image /home/root/avnet_dualcam_python_examples/stereo_data/left/left_p4_4.png
=> Processing image /home/root/avnet_dualcam_python_examples/stereo_data/left/left_p5_5.png
=> Processing image /home/root/avnet_dualcam_python_examples/stereo_data/left/left_p6_6.png
=> Processing image /home/root/avnet_dualcam_python_examples/stereo_data/left/left_p7_7.png
=> Processing image /home/root/avnet_dualcam_python_examples/stereo_data/left/left_p8_8.png
=> Processing image /home/root/avnet_dualcam_python_examples/stereo_data/left/left_p9_9.png
=> Processing image /home/root/avnet_dualcam_python_examples/stereo_data/right/right_p0_0.png
=> Processing image /home/root/avnet_dualcam_python_examples/stereo_data/right/right_p10_10.png
=> Processing image /home/root/avnet_dualcam_python_examples/stereo_data/right/right_p11_11.png
=> Processing image /home/root/avnet_dualcam_python_examples/stereo_data/right/right_p12_12.png
43 number of Markers corners detected in the above image
=> Processing image /home/root/avnet_dualcam_python_examples/stereo_data/right/right_p1_1.png
=> Processing image /home/root/avnet_dualcam_python_examples/stereo_data/right/right_p2_2.png
=> Processing image /home/root/avnet_dualcam_python_examples/stereo_data/right/right_p3_3.png
=> Processing image /home/root/avnet_dualcam_python_examples/stereo_data/right/right_p4_4.png
=> Processing image /home/root/avnet_dualcam_python_examples/stereo_data/right/right_p5_5.png
=> Processing image /home/root/avnet_dualcam_python_examples/stereo_data/right/right_p6_6.png
=> Processing image /home/root/avnet_dualcam_python_examples/stereo_data/right/right_p7_7.png
=> Processing image /home/root/avnet_dualcam_python_examples/stereo_data/right/right_p8_8.png
=> Processing image /home/root/avnet_dualcam_python_examples/stereo_data/right/right_p9_9.png
CAMERA CALIBRATION
(1280, 800)
Camera Matrix initialization.............
[[857.1668 0. 643.9126 ]
[ 0. 856.0823 387.56018]
[ 0. 0. 1. ]]
CAMERA CALIBRATION
(1280, 800)
[ 0. 0. 1. ]]
~~~~~~~~~~~~~RMS error of left~~~~~~~~~~~~~~
0.27127840713819595
0.2636582695039592
[[863.66644698 0. 644.45998875]
[ 0. 862.57372353 398.32571049]
[ 0. 0. 1. ]]
[[862.49062625 0. 651.33360285]
[ 0. 861.39939047 398.1687972 ]
[ 0. 0. 1. ]]
[[1.78593490e+01]
[6.22164495e+01]
[1.55524760e-04]
[1.48234433e-03]
[4.77799154e+01]
[1.80181985e+01]
[6.11228981e+01]
[4.99820866e+01]
[0.00000000e+00]
[0.00000000e+00]
[0.00000000e+00]
[0.00000000e+00]
[0.00000000e+00]
[0.00000000e+00]]
[[ 1.34431671e+01]
[-6.64473329e+00]
[ 4.67727647e-04]
[ 2.80569675e-03]
[ 6.94820433e+02]
[ 1.36278105e+01]
[-7.97379100e+00]
[ 6.98101470e+02]
[ 0.00000000e+00]
[ 0.00000000e+00]
[ 0.00000000e+00]
[ 0.00000000e+00]
[ 0.00000000e+00]
[ 0.00000000e+00]]
allIds_l
13
13
allIds_l
allIds_r
~~~~~~~~~~~~~RMS error of L-R~~~~~~~~~~~~~~
0.2567820984546291
~~~~~ Starting Stereo Calibration ~~~~~
R1 (left)
[[ 0.999984 0.000614 -0.005638]
[-0.000585 0.999987 0.005064]
[ 0.005641 -0.005061 0.999971]]
R2 (right)
[[ 0.999911 0.00126 -0.013316]
[-0.001327 0.999986 -0.005054]
[ 0.01331 0.005071 0.999899]]
M1 (left)
[[863.30426 0. 645.5743 ]
[ 0. 863.8515 399.63293]
[ 0. 0. 1. ]]
M2 (right)
[[862.2782 0. 649.1176 ]
[ 0. 862.3503 398.21323]
[ 0. 0. 1. ]]
R
[[ 0.99997 -0.000781 0.007665]
[ 0.000703 0.999948 0.010127]
[-0.007672 -0.010122 0.999919]]
T
[[-4.934046]
[-0.006215]
[ 0.06571 ]]
M3 (rgb)
[[0. 0. 0.]
[0. 0. 0.]
[0. 0. 0.]]
\R (rgb)
[[0. 0. 0.]
[0. 0. 0.]
[0. 0. 0.]]
T (rgb)
[0. 0. 0.]
Took 17 seconds to run image processing.
Mesh path
/home/root/avnet_dualcam_python_examples/depthai_helpers
shape of maps
(800, 1280)
(800, 1280)
(800, 1280)
(800, 1280)
<-----------------Epipolar error of LEFT-right camera---------------->
HU IHER
Printing p1 and p2
[[863.100906 0. 663.396759 0. ]
[ 0. 863.100906 399.381893 0. ]
[ 0. 0. 1. 0. ]]
[[ 863.100906 0. 663.396759 -4258.960496]
[ 0. 0. 1. 0. ]]
Average Epipolar Error per image on host in right_p0_0.png : 0.07706821986607143
Average Epipolar Error per image on host in right_p10_10.png : 0.05926799774169922
Average Epipolar Error per image on host in right_p11_11.png : 0.05467376708984375
Average Epipolar Error per image on host in right_p12_12.png : 0.08408007902257583
Average Epipolar Error per image on host in right_p1_1.png : 0.07137843540736608
Average Epipolar Error per image on host in right_p2_2.png : 0.06840798514229911
Average Epipolar Error per image on host in right_p3_3.png : 0.0678647722516741
Average Epipolar Error per image on host in right_p4_4.png : 0.06874891008649553
Average Epipolar Error per image on host in right_p5_5.png : 0.05979178292410714
Average Epipolar Error per image on host in right_p6_6.png : 0.07102007184709822
Average Epipolar Error per image on host in right_p7_7.png : 0.10439994118430397
Average Epipolar Error per image on host in right_p8_8.png : 0.06121695382254464
Average Epipolar Error per image on host in right_p9_9.png : 0.08073861258370536
Average Epipolar Error: 0.07134149122344359
Displaying Stereo Pair for visual inspection. Press the [ESC] key to exit.
py: DONE.
After calibration, the epipolar error between left/right image pairs will be reported, along with supporting images for visualization:
NOTE : a large screen is required to view the full image (2x1280 x 800)
If successful, the calibration process will display a green window:
Otherwise, a red windows with error message will be displayed.
Performing Stereo Depth Estimation
Once calibrated, the results can be tested with the following software based depth estimation:
$ python3 avnet_dualcam_ar0144_stereo_depth.py --calibration_file ./stereo_data/calib/dualcam_stereo.yml
This will display a collage of [left + depth + right] images:
Since the depth estimation is performed in software, it will be slow.
To speed things up, specify a smaller input image size
$ python3 avnet_dualcam_ar0144_stereo_depth.py --calibration_file ./stereo_data/calib/dualcam_stereo.yml --width 640 --height 480
Where to Buy the Hardware
The following links describe the hardware requirements needed to run this tutorial.
Ultra96-V2
Buy Ultra96-V2
or Ultra96-V2 I-grade
Buy Ultra96-V2 I-grade
Ultra96-V2 4A Power Supply
Buy Ultra96-V2 4A Power Supply
Ultra96-V2 JTAG/UART Adapter
Buy Ultra96-V2 JTAG/UART Adapter
96Boards onsemi Dual Camera Mezzanine
Buy 96Boards onsemi Dual Camera Mezzanine
Going Further
A Vitis-AI 2.0 design has been built on top of this 2021.2 design, and is documented as a hackster.io project.
http://avnet.me/vitis-ai-2.0-dualcam
This hackster.io project includes the following additional content:
  • instructions for building Vitis platform and Vitis-AI design
  • pre-built SD card image for Vitis-AI enabled design
  • python scripts for stereo processing (anaglyph, stereo neural inference)
Conclusion
I hope this tutorial will help you get started quickly with the Ultra96-V2 and Dual-Camera Mezzanine, and inspire you to create innovative stereo applications.
    DAB over 4 years ago
    Very good overview of stereo camera calibration.
