FPGA
FPGA
Blog Summer of FPGAs - Building an Embedded System on FPGA
  • Author Author: yesha98
  • Date Created: 16 Aug 2021 4:31 PM Date Created
  • Views 6556 views
  • Likes 11 likes
  • Comments 21 comments
yesha98
yesha98
16 Aug 2021
Introduction:
Back then in February when I roadtested the USB104-A7, I had learned to create block designs using MicroBlaze. I found it very interesting but the available online resources were limited, the tutorials were based on the older versions of Vivado (Uploaded 6 years back or so). So I thought of making a course on using MicroBlaze in block designs and programming it with Xilinx SDK. Finally, after my semester exams were over, I got some free time to record the tutorials and the course material.
The course is designed in such a way that basic knowledge on FPGA programming using Vivado would be sufficient to take up this course. Also, the learner will understand the design of hardware while making the custom Pmod (Pmod Character LCD) and the working of Rotary Encoder.
Also, in this course, the design will be modified as new modules are added according to the requirements. The quadrature decoder module described in Verilog will also be added to the design at a later stage in the course. Thus, the learner will be able to feel the essence of the term "Reconfigurable Hardware".
Course Contents:
Video 1 - Introduction to MicroBlaze and AXI
Video 2 -- Lab 1 - Creating a block design with MicroBlaze and AXI GPIOs
Video 3 -- Lab 2 - Writing code in Xilinx SDK to interface with user LED and Pushbutton
Video 4 - Working of Character LCD and making of the Pmod LCD
Video 5 -- Lab 3 - Modifying the block design to interface Pmod LCD
Video 6 -- Lab 4 - LCD Driver Code to display elapsed seconds in LCD
Video 7 - Working of Rotary Encoder and Quadrature Decoder
VIdeo 8 -- Lab 5 - Adding the Quadrature Decoder Module to the Design
Video 9 -- Lab 6 - Writing code in SDK to display count and direction to the LCD
VIdeo 10 - Final Assessment
About the Course:
All videos are available on YouTube, here's the link to Playlist: https://www.youtube.com/playlist?list=PL6jYIySXv7VhUjg95oP88ubxRrr9MQMfH
Complete the final assessment to earn a certificate!
Course Overview:
Thanks for reading!
    Jan Cumps over 5 years ago +2
    Video 3 also worked perfectly on a Pynq-Z2 board with Zynq IC. www.youtube.com/watch
    Jan Cumps over 5 years ago in reply to yesha98 +2
    yesha98 wrote: ... Btw, I have a doubt, so you added the onboard LEDs and Pushbuttons through AXI GPIO right. After adding the Zynq IP in block design, if we run the block automation, the Fixed IO and…
  • navadeepganeshu
    navadeepganeshu over 5 years ago +2
    Gave a try with ARTY S7 - 50. For this board, I skipped adding NOT logic for reset(lab video1) as it was active low with the onboard switch by default. Used GPIO0 and 1 for 4 x LEDs and 4 x pushbuttons…
    yesha98 , I'm working on a similar exercise. It's a race to keep up with tool version differences.
    Since the 2019 chain that you're using, the SDK seems to be replaced by Vitis (not Vitis HLS).
    The Xilinx solutions and workflows for these "Processor + FPGA" packages does not seem to have settled yet.
    This makes it tricky to work with the application suite by following blogs and videos, if versions don't exactly match what you have installed.
  • yesha98
    yesha98 over 5 years ago in reply to Jan Cumps
    Yeah, Jan Cumps. It's true.
    Only earlier this year I updated from 2017.3 to 2019.1.
    Updating software like Vivado takes a lot of time. The purpose of an online course is different from that of a tutorial.
    So it's up to the learner to decide. Also, just for clarification, the code written in SDK would work in Vitis also, right? Correct me if I'm wrong.
    yesha98  wrote:
    ...just for clarification, the code written in SDK would work in Vitis also, right?
    That's what I'm trying to figure out at the moment. Doc says that the SDK is now integrated in Vitis, and there's no seperate license anymore. I haven't yet checked if there are library, API or other changes.
  • yesha98
    Okay. Let me know once you figure it out.
    I will. Just started:
  • yesha98
    Right, thanks!
