FPGA
FPGA
Forum Linux or windows to develop on FPGA ?
  • Replies 7 replies
  • Answers 4 answers
  • Subscribers 583 subscribers
  • Views 2380 views
saffaa
saffaa over 6 years ago
Is there any FPGA evaluations boards compatible with windows and others with linux, or all FPGA cards are compatible with the two environment.
Best regards,
    dougw over 6 years ago +1 suggested
    Xilinx, Intel (Altera), Lattice and Microsemi (Actel) all have FPGA design suites that work on either Windows or Linux. Some eval boards are intended to run Linux.
    michaelkellett over 6 years ago +1 suggested
    What kind of FPGA work do you want to do ? The price of eval boards ranges from about £10 to >>£10k MK
  • Fred27
    Fred27 over 6 years ago +1 suggested
    The only restriction I've seen is building PetaLinux for Xilinx parts which requires Linux - although a VM will do the job. I'd go for whatever OS you feel more comfortable with.
    0 dougw over 6 years ago
    0 michaelkellett over 6 years ago
  • Fred27
    0 Fred27 over 6 years ago
  • saffaa
    0 saffaa over 6 years ago in reply to dougw
    Hi Douglas,
    Thanks for your reply.
    What do you mean by "Some eval boards are intended to run Linux" => are there any cards that are not intended to run Linux ? and how can I know this information ?
    Best regards,
  • saffaa
    0 saffaa over 6 years ago in reply to michaelkellett
    Hi Michael,
    I have not yet chosen my FPGA, I am looking for an eval board which contains 20 pins LVDS accessible and not too expensive.
    do you have any recommendation ?
    Best regards
  • saffaa
    0 saffaa over 6 years ago in reply to Fred27
    Hi Fred,
    So using Linux, can I build Petalinux for all Xilinx parts ?
    Best regards,
    0 michaelkellett over 6 years ago in reply to saffaa
    You need to define your project in a bit more detail for me to make a good recommendation of FPGA.
    A block diagram would help.
    It's also helpful to know if you have any experience with FPGA development and if it is a commercial, academic or home project.
    If you are staring out I would advise you to avoid FPGAs with embedded processors (soft or hard) running Linux or any other operating system because you will very little about FPGA and a lot about the OS.
    There are very cheap dev boards for all the major FPGA types and manufacturers.
