FPGA
FPGA
Forum Arty S7-50 & Raspberry Pi through SPI
  • Subscribers 583 subscribers
  • Views 2596 views
  • fpga
rzf786
rzf786 over 5 years ago
I am trying to interface a Raspberry Pi and the Arty S7-50 through the SPI bus. The SPI communications on the Raspberry Pi is written using Python and tested to be working by using scopes traces.
The Raspberry Pi is configured as Master and Arty-S7 need to be configured as slave.
I need help configuring the Arty S7 to listen to the SPI communication as a Slave Device. Are there any example Verilog codes for this ?
Thanks in advance.
  • bhfletcher
    0 bhfletcher over 5 years ago
    I have not used it myself, but you could take a look here:
    https://opencores.org/projects/spi_verilog_master_slave
    Looks like something similar was done here:
    https://www.fpga4fun.com/SPI2.html
    Bryan
  • rzf786
    0 rzf786 over 5 years ago in reply to bhfletcher
    Thank you. I will try to follow the suggested examples.
    0 michaelkellett over 5 years ago
    What else is going on in your ARTY - this will make a big difference to the best choce of SPI approach.
  • tcmichals
    0 tcmichals over 4 years ago
    Looking at this entry, this might help:  https://www.hackster.io/MichalsTC/how-communicate-to-a-fpga-using-a-raspberry-pi-zero-via-spi-453651  It also works for S7 Arty.
