FPGA
FPGA
Forum Recommend a beginners FPGA development kit
  • Replies 30 replies
  • Answers 2 answers
  • Subscribers 586 subscribers
  • Views 5557 views
  • fpga
  • learning
  • dev_kit
Catwell over 15 years ago
An engineering friend of mine could really benefit from learning more about FPGAs. I suggested getting a simple devkit to get some hands on experience programming and designing with them. When he asked what to get, I will admit, I was at a loss.
So, if anyone can recommend something that would be great.
Thanks ahead of time.
Cabe
    e14 Contributor over 15 years ago +1 suggested
    There are virtually tons of inexpensive development boards out there. Xilinx has a $49 Spartan 3 board, for example. Development software is free, and the boards come with demo programs. If you just go…
    e14 Contributor over 15 years ago in reply to Catwell +1
    Personally, I'd go for an FPGA vs. a CPLD. The CPLD just doesn't have a lot of resources-256 macrocells(registers) as compared to the XC3S250 in the Butterfly which has THOUSANDS of registers, multipliers…
  • gbulmeruk
    gbulmeruk over 15 years ago in reply to Catwell +1
    Cabe - as I wrote, CPLD and FPGA are rather different animals. If your friend sees increasing numbers of FPGA-based products, and not CPLD, get FPGA. FPGA provides for MUCH more complex projects than a…
    0 michaelkellett over 15 years ago in reply to gbulmeruk
    I use Lattice tools on a daily basis - I don't consider them to be ruined.
    For projects that will only use a ready made development board it probably does not matter much where you start between A, L and X. (The A stands for Altera not Actel)
    If there is any prospect of production on a custom board then it matters a lot. Flash based parts are easier to use.
    I've found Lattice much easier to deal with for small (< 10,000) projects.(They may be better with bigger numbers too but I don't have experience in that area.)
  • gbulmeruk
    0 gbulmeruk over 15 years ago in reply to michaelkellett
    michaelkellett - my friend uses Lattice for his work.
    He was using "ispLEVER" which he liked a lot, but now the IDE has changed and become "Diamond".
    He was particularly unhappy about the changes to the simulation workflow.
    I am learning about FPGA's (and so in the same market as Cabe's friend), and the toolchain matters to me a lot. I am primarily a 'software person'.
    I don't use Windows so that makes it harder too; though it is encouraging to see more manufacturer's (of MCU's and FPGA's) making their tools available on Linux.
    0 e14 Contributor over 15 years ago in reply to gbulmeruk
    My two cents: I also use ispLEVER, haven't made the switch to Diamond yet.  I also use Xilinx and Altera tools.  They ALL have problems.  Xilinx Webpack(free) is available for Linux, I don't know about the rest.  If I might editorialize: I have migrated away from Altera because their support SUUUUUUCKS. If you're just starting out vendor support is particularly important. (I hope somebody from Altera is reading this.)  Altera's tools and devices are fine, but that's only part of the equation.
    Barry
    I Agree with ezekiel the bemicro devboard is good starter option and very inexpensive. Look at the altera website for training through distributors. Programming is simple as everything is done over USB. Also you can get a breakout board from Hitex that the bemicro plugs into giving you some prototyping i/o from the fpga.
  • Catwell
    0 Catwell over 15 years ago in reply to gbulmeruk
    Gbulmeruk,
    An FPGA capable of emulating an entire processor is under $20
    Point me in the right direction.
    C
  • Catwell
    0 Catwell over 15 years ago in reply to e14 Contributor
    Barry,
    Your claims on Altera have me thinking twice about their boards. Can you post some links with info pertaining to ispLEVER?
    Cabe
  • ezekiel
    0 ezekiel over 15 years ago in reply to Catwell
    The Altera Cyclone III can use the NIOS2 softcore which is an ARM core that can run Linux.
    Again, check out the BeMicro $49 USB dev stick.
    As far as support goes, you have to remember that those who spend the most $$'s will get the most attention from the chip vendor.  It's the Golden Goose analogy. The company I worked for used a lot of Altera parts and they got good support because they bought tens of thousands of $$'s worth of parts a year from Altera.
    Us little guys have to stick together and help each other out. OpenCores.org is a perfect example of this mentality. Check them out for support too.
    In the end, you have to choose yourself which FPGA vendor to go with. They are all competitive. It's just like Ford vs. Chrysler vs. Chevrolet. Or, for others, it's just like Soda vs. Beer vs. Whiskey. Pick your own poison.
    No matter what choice is made, you *will* have to invest time and effort to learn how to program VHDL. That should be your bigger concern at this time.
    0 michaelkellett over 15 years ago in reply to ezekiel
    @ezekiel,
    The NIOS2 is not an ARM - it is Altera's own processor architcture.
    If you want to use ARM + FPGA on one chip then look to Xilinx (big chips, big ARMs, very expensive) or Actel (much lower down the price range, Cortex M3 ARM - but now under new and uncertain ownership).
    IMO beginners with FPGA should steer well clear of embedded processors (soft or hard) .
  • gbulmeruk
    0 gbulmeruk over 15 years ago in reply to Catwell
    Cabe - Lattice have a soft 8-bit and 32-bit processor
    The 8-bit is at http://www.latticesemi.com/products/intellectualproperty/referencedesigns/8bitmicrocontrollermico8.cfm
    They say "The core consumes minimal device resources, less than 200 Look Up Tables  (LUTs) in the smallest configuration, while maintaining a broad feature  set."
    I checked their 32-bit soft core recently, and it would easily fit on something like a low-end, 5,000 LUT, XP2, e.g.
    http://uk.farnell.com/lattice-semiconductor/lfxp2-5e-5tn144c/fpga-5k-luts-100-i-o-dsp-144tqfp/dp/1571999
    which is in a DIY-able QFP (not BGA) package.
  • gbulmeruk
    0 gbulmeruk over 15 years ago in reply to ezekiel
    I think a key point is the toolchain.
    Fortunately, you can download the tools for free and try them.
    They should all come with a simulator. If it doesn't don't bother with it (my chums recommend beginners to debug designs using simulators, especially when on a low budget, i.e. few pieces of gtest equipment)
    So your friend could futz around with the toolchain, without any hadware, and see what they like.
