FPGA
FPGA
Forum I'm looking for solutions for wide band SDR in HF and VHF frequencies bands
  • Subscribers 582 subscribers
  • Views 1780 views
  • fpga
tuancoiz4
tuancoiz4 over 5 years ago
Hi everyone! This is my first question on the forum! Nice to meet you guys!
I am new to FPGA and I would like to start with an SDR project and I would like to start from basics. Could you guys tell me how to start? And what hardware and software should I use?
I already have a Zedboard, DE10 Cyclone 5 SoC, Stratrix 10 Development kit (I never used it before since it required licenses from Intel), I have an AD-DA daughter card from Altera with 70MSPS too.
I intend to buy an SDR kit from Analog Device called AD9361 FMC kit which is compatible with Zedboard.
I want to build a system that receives HF, VHF signals, digitalize the signals and transfer the output I-Q signal through a high-speed Ethernet port to the computer. On the computer, the I-Q signal will be used to FFT calculate and draw the spectrum. If the FFT can be done on FPGA side, it would be great. I intend to build a direct digitalize for the whole bandwidth of interest.
What theory I should start with to do this project?
Should I buy licenses of Vivado for System generate for DSP?
What hardware, kit development should I buy?
T4R!
    shabaz over 5 years ago
    Hi Nguyen,
    I'm not sure this is a suitable 'first FPGA' project, but I'm not knowledgeable in it. You could look at existing SDR projects to explore how you would want to implement it.
    See here for an example open hardware/open source SDR, it contains the HDL too, although they are using USB and not Ethernet: https://github.com/myriadrf
  • tuancoiz4
    tuancoiz4 over 5 years ago in reply to shabaz
    Thank you so much for replying,
    This project in the fact is too ambitious for a beginner like me but I have some experience with FPGA before and I know some fundamentals. I can spend years for this project because I consider it is my future career. Thank you so much for the open-source SDR project.
