FPGA
FPGA
Forum PYNQ Now Available for the Kria KV260 Vision AI Starter Kit
  • Replies 23 replies
  • Subscribers 579 subscribers
  • Views 10609 views
  • kria
  • xilinx
  • kv260
  • pynq
javagoza
javagoza over 4 years ago
Great news! PYNQ is now supported on the Xilinx Kria SOM
https://github.com/Xilinx/Kria-PYNQ
  • javagoza
    javagoza over 4 years ago +3
    Really excited. Everything working.
  • kevinkeryk
    kevinkeryk over 4 years ago +3
    I was able to get PYNQ up and running on KV260 following the tips from ralphjy , thanks everyone! -Kevin
  • javagoza
    javagoza over 4 years ago in reply to albertabeef +3
    I have tried with an rpi camera v2 and it does not recognize it. I also don't see support in the repository. https://github.com/Xilinx/PYNQ/tree/master/pynq/lib/_pynq/_pcam5c
  • javagoza
    Also DPU on PYNQ upgrades to support the KV260
    https://github.com/Xilinx/DPU-PYNQ
    Vitis AI DPU is included with example training and inference notebooks ready to run on PYNQ enabled platforms.
    Supports Vitis AI 1.4.0
  • ralphjy
    ralphjy over 4 years ago
    If you have used Ubuntu with the Kria - if you installed the Xilinx specific gstreamer libraries - these will cause the PYNQ installation to fail.
    I would recommend starting with a new image.
  • javagoza
    javagoza over 4 years ago in reply to ralphjy
    Thanks, I'm starting with a fresh image but I'm having problems with the sd card, I think I'll have to buy a new one tomorrow.
  • javagoza
    javagoza over 4 years ago in reply to javagoza
    Definitely don't use this type of card, Kingstom 32 GB microSD HC. I have changed to a Sandisk brand card and problem solved, it is already installing PYNQ with all its dependencies without writing problems as it happened with the Kingstom.
  • javagoza
  • javagoza
    Using this old Logitech c170 webcam
    Logitech-Webcam-C170-Technical-Specifications
  • kevinkeryk
    I was able to get PYNQ up and running on KV260 following the tips from ralphjy, thanks everyone!
    -Kevin
  • ralphjy
    ralphjy over 4 years ago in reply to javagoza
    I have had bad experiences with Samsung cards.  I've never had issues with Sandisk or Delkin cards.  There is a writeup on SD cards somewhere on E14 that I used to have a link to...
  • bhfletcher
    bhfletcher over 4 years ago in reply to ralphjy
    This one?
    /technologies/embedded/b/blog/posts/storage-insights-1---why-not-all-sd-cards-are-created-equal
    We have had very good luck with the Delkin MLC Utility cards and highly recommend them. Newark/Farnell typically keep decent stock of them. The locked BOM eliminates the risk that one generation will pass and then the next generation fail.
    Bryan
  • ralphjy
    Webcam works for me too - I am using a Brio.
    Does the MIPI cam work for you?  That notebook is using the setup for the Pcam 5C - not sure if that's compatible with the AR1335.  In any case it fails to initialize.  Looks like it's compatible with an RPi Cam.  So probably using the other connector.
