FPGA
FPGA
Forum Spartan 6 Connectivity issue
  • Replies 16 replies
  • Subscribers 581 subscribers
  • Views 4662 views
Krishnajdl10
Krishnajdl10 over 3 years ago
The spartan 6 board is not getting detected in ISE. The connection is via JTAG. The board is getting powered on but it is not getting recognized when boundary scan is carried out in select target device phase. Kindly help in resolving this issue
    Jan Cumps over 3 years ago in reply to Krishnajdl10 +2
    ISE is not compatible with it.
  • flyingbean
    flyingbean over 3 years ago in reply to Krishnajdl10 +2
    I installed Window 7(64-bit) for ISE14.7. Windows 10 does not work with ISE any more. You might try to use Linux/Ubuntu for ISE14.7.
  • flyingbean
    flyingbean over 3 years ago in reply to Krishnajdl10 +1
    I used this Spartan6 EVB a few years ago. I used ISE 14.7 with Xilinx JTAG debugger without any issues.
  • Krishnajdl10
    0 Krishnajdl10 over 3 years ago
  • Krishnajdl10
  • Krishnajdl10
  • Krishnajdl10
  • Krishnajdl10
  • flyingbean
    0 flyingbean over 3 years ago in reply to Krishnajdl10
    0 Jan Cumps over 3 years ago in reply to Krishnajdl10
    What is your Windows version (and is it 32/64)?
    Are you using ISE in the VM that Xilinx distributes for it? Or installed on a windows proper?
  • Krishnajdl10
    0 Krishnajdl10 over 3 years ago in reply to Jan Cumps
    It is installed in Windows 10 (64 bit) properly
  • Krishnajdl10
    Any solution available?
