FPGA
FPGA
Forum PALs and 2023
  • Replies 14 replies
  • Subscribers 578 subscribers
  • Views 3732 views
  • fpga
PALs and 2023
SGarciaV
SGarciaV over 3 years ago
Hello all!
My first post in this forum. I haven't been to E14 in a while; now everything is different!
I may start a project in the near future that involves TTL 74LS logic. Currently, I will be using one 74LS00, but the chip count may rise depending on design decisions. A priority is keeping the chip count down, so I may want to integrate some of the glue logic. Way back - in the 80s -  I used PALs for this purpose. Doing some research, I see that this option is still available. Since we have fast-forward a few decades since the 80s, I am wondering if there is a more modern, mainstream option, other than PALs (or GALs).
This forum was the closest I could find to programmable logic, I hope it is the correct place to ask. I should mention that if my needs are simple enough a 16L8 PAL might do the trick (sorry, trying to remember this from back then). I have a TL866 II Plus, so if the device can be programmed with this programmer, it would be a plus. Thanks for any orientation or feedback. Salvador
  • johnbeetem
    johnbeetem over 3 years ago +3
    Howdy! I used to do a lot of design with CPLDs and FPGAs. From a quick search today, I'd take a look at Microchip. https://www.microchip.com/en-us/products/fpgas-and-plds/spld-cplds# They have some…
    shabaz over 3 years ago +2
    Hi, 74LS is obsolete, there are other logic families that might suit you more. In any case, the (slightly more) modern replacement for typical PAL chips were CPLDs. They are also now not as common…
  • flyingbean
    flyingbean over 3 years ago +2
    CPLD might be a good candidate if you prefer to implement gate/register circuits rather than modern DSP slice/LUTs for your projects. Please check Microchip website, since it is the major manufacturer…
  • charlieo21
    charlieo21 over 3 years ago
    The first things that come to mind is SPLD/CPLD and FPGAs. Tha latter will be hard to find a part with a DIP package.
  • SGarciaV
    SGarciaV over 3 years ago in reply to charlieo21
    Thanks! I looked up SPLD and found this:
    www.electronics-tutorial.net/.../
    Looks like I am back to PALs! :-D Salvador
  • dang74
    dang74 over 3 years ago
    As charlieo21 mentioned  both CPLDs and FPGAs are the next step on the ladder and what programmable logic has ultimately evolved to.  With that said I study the schematics of old arcade boards and noticed that GALs were commonly used back in the 80s for some of the glue logic.  So as of late I've been intrigued with the idea of using a GAL as a way of doing something retro without using dozens 7400 series parts.
    In any case, the (slightly more) modern replacement for typical PAL chips were CPLDs. They are also now not as common, but there are plenty for sale on Farnell/Newark, so if this is a hobby project, then CPLD could still be a suitable option. They are easy to use (either by using a more normal HDL (Hardware description language; like VHDL) than early programmable logic used (which were more like a text description of table entries), or by directly entering in logic gates into a schematic).
    A nice CPLD family is Xilinx Coolrunner, e.g. XC2C64A, there are hundreds of them in stock according to the Farnell site, and they cost about £10 each (not cheap, but for a hobby project there's often not a requirement for least cost). The required software is Xilinx WebPACK, which is still available from the manufacturer website. The chip comes in TQFP package, but some are very large (0.8mm pin spacing) and easy to solder onto a breakout board using a normal soldering iron. They can be programmed using (say) a raspberry pi, hooked up to the programming pins (called JTAG).
    However, the next step up from CPLD is to use an FPGA. The easiest way to get going with them is to first buy a dev board since that may contain a programmer built-in, and easy to use connectors (most FPGAs are finer pitch parts than the old CPLDs), and then when you're happy, you could move to the individual IC. A lowish-cost dev board is ICE40HX1K-STICK-EVN (£49 GBP, currently 99 in stock on the Farnell website). The basic FPGAs such as that are not much harder to use than the CPLDs, but depending on the manufacturer free supplied software they might not come with a schematic entry method, you may have to use a HDL. There is also open source software but that's another topic altogether, and is not applicable for all HDLs. FPGAs take their configuration from external memory by the way, unlike CPLDs.
    Yet another approach could be to consider something like Infineon/Cypress PSoC chips or dev boards, they are a microcontroller with a (very tiny) bit of programmable logic attached. However I know nothing about those, and cannot comment.
  • flyingbean
    CPLD might be a good candidate if you prefer to implement gate/register circuits rather than modern DSP slice/LUTs for your projects. Please check Microchip website, since it is the major manufacturer for CPLD parts now.
    dougw over 3 years ago in reply to shabaz
    Infineon PSoCs can be used strictly as programmable logic gates and "TTL" style logic functions without dealing with the MCU at all. They even have comparators and opamps. They can also operate from below 2V to over 5V.
    I did an example of PSOC programmable logic without MCU here:
     The Logical Project
  • johnbeetem
    Howdy!
    They have some low-density CPLDs, and even have DIPs as well as PLCCs which you can use with sockets that have pins with 100 mil centers.  "Microchip is the sole manufacturer of SPLD products that replaced PLA- and PAL-type devices in the mid-1990s."  For example, they have a 22V10 part which is a superset of the MMI PALs.
    I think these parts were originally Atmel, which Microchip acquired.  I've never used these specific parts.
  • SGarciaV
    SGarciaV over 3 years ago in reply to johnbeetem
    I will look into the Microchip products, thanks! Salvador
  • SGarciaV
    SGarciaV over 3 years ago in reply to flyingbean
    Thanks. Yes, I will check Microchip. Although too far in the future to tell, but I will probably need something simple. BTW, way cool avatar!
  • SGarciaV
    SGarciaV over 3 years ago in reply to dougw
    Nice! I'll have to have closer look at your project and associated videos.
