FPGA
FPGA
Forum Suggestions for designing with ZYNQ MPSoC UltraScale+ ZCU104: Using PS side DDR4 memory for storing trained weights and biases of Convolutional Neural Network(CNN) for implementation of CNN inference in real-time.
  • Subscribers 578 subscribers
  • Views 1633 views
  • ddr4
  • cnn
  • fpga
  • zynq mpsoc
  • verilog
  • xili
BinitKP
BinitKP over 2 years ago
I have trained weights and biases from a CNN network for different layers. I have converted those data into fixed point 16-bit binary format and saved them as .txt files for different convolutional layers. Since the data files are too large to accommodate them into BRAM (On-chip memory), I need to use external PS side DDR4 memory to store those.
However, I don't understand how I can store those data in DDR4 memory for simulation purposes as the Verilog function of $readmemb() says out of memory in the Vivado while loading a single file as I think it is taking the BRAM only; which is too small in capacity.
So, please guide me on how to approach the simulation and then real-time inference operation after making the equivalent CNN using Verilog HDL coding, whether my approach is correct or if I need to approach it another way.
Attached are the file organization and sample contents for reference.
  • javagoza
    0 javagoza over 2 years ago
    Can't you split it into several files and upload them to contiguous addresses?
  • BinitKP
    0 BinitKP over 2 years ago in reply to javagoza
    Thank you for your response. The files are separated only, but those are large enough to hold on BRAM. I have edited my question and attached the sample content and its file organization. A single represents a single pixel value. For example, an input image is 128*128*3 (height, width, channel), and each pixel is of 16 bits. In CNN, there are sizes like 128*128*16 (Height, Width, Number of output filters). The CNN network here I am trying is 3D UNET architecture.
  • JB58
    0 JB58 over 2 years ago
    I believe you can mimic the behavior of the data transfer engine from DDR to your internal module inside your testbench! Am I right?
    You can read the .txt file in your testbench, and handle the hand shake required for your data transfer in your simulation bench. I am assuming you are using AXI_DMA, reading the data in AXI_MM world and your module wrapper is AXI_S compatible which makes it easier.
