FPGA
FPGA
Forum What FPGA content would you like to see?
  • Replies 28 replies
  • Subscribers 586 subscribers
  • Views 5441 views
  • fpgafeatured
  • fpga
e14phil
e14phil over 9 years ago
FPGA and element14
I am very happy to say we have lots of big, exciting things in the pipeline for FPGA and the extended element14 family, but I want to take this time to ask the community what FPGA content interests you?
Do you want some reviews of FPGA kit?
Do you want Tutorials, if so on what?
What would help you to work with FPGA?
We have some things in the works but we always want to add quality content to our community.
If you have something you want to share in the FPGA space but want help, kit or just to run it past us, we will always try help!
- Your Friendly Neighborhood e14phil
  • pettitda
    pettitda over 9 years ago +7
    1) tutorials on VHDL and/or Verilog 2) tutorials on vendor tools (i.e. Xilinx, Altera, Modelsim?) 3) information on where FPGAs have advantage over microcontrollers/processors (i.e. parallel versus serial…
  • rscasny
    rscasny over 9 years ago in reply to pettitda +5
    David, Thanks for the feedback. You pretty much read my mind and my plan. I have been looking at tutorial content to see what's viable. I have been thinking about bringing in tutorials on the Vivado Design…
    e14 Contributor over 9 years ago +5
    Im enthusiastic to work more with fpga's, after my current project I intend to make a multi protocol analyzer, Jan Cumps mentioned he's made one using an fpga so I might follow suit here. Also I want to…
  • pettitda
    3) information on where FPGAs have advantage over microcontrollers/processors (i.e. parallel versus serial logic)
    • Vote Up +7 Vote Down
  • rscasny
    David,
    Thanks for the feedback. You pretty much read my mind and my plan. I have been looking at tutorial content to see what's viable. I have been thinking about bringing in tutorials on the Vivado Design Suite (Xilinx). Point 3 is good. But also was thinking about FPGA vs FPGA Soc's (programmable SoCs). A number of dev boards exist that use this architecture for their purported advantages.
    • Vote Up +5 Vote Down
    Also I want to add a graphical interface of some sort (lcd) so I'll likely use a small board computer for that part as I feel that would be easier and an fpga for the bus reading and decoding and make a standalone piece of test equipment so expect some more content from me image
    Jan Cumps over 9 years ago in reply to e14 Contributor
    lucie tozer wrote:
    ... after my current project I intend to make a multi protocol analyzer, Jan Cumps mentioned he's made one using an fpga so I might follow suit here.
    I blatantly stole someone's design image
    The Papilio boards and Dangerous Prototypes LogicSniffer are virtually the same hardware - except input protection and level shifting.
    So the only thing I did is to make input protection board and load the LogicSniffer bitstream (I just changed some pull-up settings in the constraint file - the standard ones loaded some circuits a bit too hard).
    I've got a blog on that here on e14. I'll search it ...
    Jan Cumps over 9 years ago in reply to Jan Cumps
    Here is the explanation:
    Make a Logic Analyzer from your Dev Kit Part 2: Papilio FPGA
    DAB over 9 years ago in reply to rscasny
    There is an upcoming CEC training session on programming FPGA devices at Digikey.
    You might want to check out what they have available.
  • 14rhb
    14rhb over 9 years ago
    Phil,
    I did some FPGA programming a long time ago and would love to get back into it. I'd be really interested to know what the absolute lowest budget ways would be of getting started again - e.g. the cheaper parts, which vendors supply free software tools and where possible if a homemade programmer can be made up.
    Whatever you decide to write about though I'm sure will be of interest.
    Mike Field , who is a (very inactive image ) member here, has written an excellent tutorial on getting started with FPGA and VHDL. Maybe we can lure him into giving a workshop?
    https://github.com/hamsternz/IntroToSpartanFPGABook/raw/master/IntroToSpartanFPGABook.pdf
  • jc2048
    jc2048 over 9 years ago in reply to e14 Contributor
    Once you had that going, it might be interesting to see if you could move the processor to the FPGA. A custom processor, designed to be good at the kind of tasks you'd want in such an embedded type application, might look quite different to the kind of thing we're all used to which has to be a 'Jack of all trades'.
    e14 Contributor over 9 years ago in reply to jc2048
    That would be awesome but thats probably out of my depth, and probably more than just 1 person can manage. My first thoughts are a custom processor needs a custom command set and then a custom compiler for a higher level language to make it functional for things like graphical work.
    Maybe its not as complicated as that though, I might look into it as a potential option. Right now Im not proficient enough with FPGA's to develop a processor inside one!
