Internet of Things
Internet of Things
Blog Set up Elecrow TTN LoRaWAN gateway on Raspberry Pi - Pt. 1: build and test
  • Date Created: 28 Dec 2023 9:20 PM Date Created
  • Views 8061 views
  • Likes 8 likes
  • Comments 37 comments
  • raspberry
  • the things network
  • lorawan
  • ttn
  • gateway
  • iot
28 Dec 2023
I installed the software for the Elecrow LoRaWAN gateway (see  Low-Cost LoRaWAN Gateways! ), and enabled the gateway on The Things Network (TTN). I used Raspberry OS bullseye 32-bit lite on a Raspberry Pi  A+. I tested this on a B+ with the same OS too.
epic
Instructions from Elecrow: https://www.elecrow.com/wiki/index.php?title=LR1302_LoRaWAN_Gateway_Module
Preparation
sudo apt-get update
sudo apt install -y git
cd ~
run sudo raspi-config to enable
  • i2c,
  • SPI and
  • Serial Port. For Serial Port, do not allow console (question 1: no), but allow enabling of the port (question 2: yes).
Build the software
The following section is different than the vendor's instructions:
clone https://github.com/Elecrow-RD/LR1302_loraWAN.git
cd LR1302_loraWAN
cd LR1302_HAL
cd sx1302_hal
back to the existing instruction
make
Create new TTN Gateway
If you don't have an account yet, create one. Select the suggested settings for your location. Once logged in, navigate to the console. Select Gateways
Register your new Gateway. Accept the suggested frequency and setup. I used https://descartes.co.uk/CreateEUIKey.html to generate an ID
Then download the json file that's created for you. It holds some of the settings you 'll need to update in the gateway's config file later.
Configure the packet_forwarder
cd packet_forwarder
nano global_conf.json.sx1250.EU868
I had to change this line extra, not in instructions:
"gps_tty_path": "/dev/ttyS0",
change the EUI in the config file, and check the TTN server URL. Save
chmod +x reset_lgw.sh
Test
./lora_pkt_fwd -c global_conf.json.sx1250.EU868
You will get a log of what's happening:
The TTN console confirms it found you:
And after some time, you will appear on the maps: https://ttnmapper.org/heatmap/
I've tested with an Arduino MKR 1310, and all worked fine:
Proper install of all software (covered fully in the next blog)
There's more than this. To install all software in a location of your choice, check the instructions on git: https://github.com/Elecrow-RD/LR1302_loraWAN/blob/master/LR1302_HAL/sx1302_hal/readme.md
first edit target.cfg, and set your user name and location where to install (must exist)
Then
make install
make install_conf
Full install post:  Set up Elecrow TTN LoRaWAN gateway on Raspberry Pi - Pt. 2: full install and run as service
Enjoy
    Jan Cumps over 1 year ago in reply to DaniLecx +1
    In the github issue you are referring to, there is a replacement reset script attached ( here ). If you overwrite sx1302_hal/bin/reset_lgw.sh with those contents, it should work with a sysfs-less linux…
    Jan Cumps over 1 year ago in reply to Jan Cumps +1
    the USE_LIBGPIOD setting in docker does the same : (see start file ) if [[ ${USE_LIBGPIOD} -eq 0 ]]; then cp /app/reset.sh.legacy ${RESET_FILE} else cp /app/reset.sh.gpiod ${RESET_FILE} fi /app…
  • kpin404
    kpin404 over 2 years ago
    Hello Jan Cumps ,
    I have received an Elecrow LR1302 (868) LoRaWAN gateway module included with Pi HAT from Elecrow. After hardware assembling with Raspberry- Pi board I have tried to setup as per the vendor's instructions, but afraid to say that I am unable to make a setup configuration for this. Could you please help me to assist further with its complete step-by-step setup configuration instructions to make it work for me. Thanks.
    Jan Cumps over 2 years ago in reply to kpin404
    This series of blog posts is my step by step document. I have nothing more detailed.
  • kpin404
    kpin404 over 2 years ago in reply to Jan Cumps
    Hello Jan, thanks for your prompt feedback reply. I really appreciated. Well! I have followed your setup instruction details and run it successfully. Thanks for this. But I don't know how to get this gateway's ID/EUI details to enter at network server. Could you please assist me with the instruction command details on this? Actually, I am using a local machine hosted Chirpstack network server. Thanks again for your help on this.
    are you using The Things Network? And if yes, do you have an account?
    At what point (in my blog or in the official instructions) are you stuck?
  • kpin404
    Sorry not using Things Network. I am using Chirpstack LoRaWAN Network Server on locally hosted machine and it requires Gateway ID to be connected with the gateway. Thanks.
  • kpin404
  • kpin404
    kpin404 over 2 years ago in reply to kpin404
    Everything works fine with testing successfully after following your and official instructions, but i am a bit stuck at how to get or know this gateway's ID to enter at my LoRaWAN Network Server.
    I have no experience with it.
  • kpin404
    Its okay! no problem at all. Thanks for your cooperation. Have a great time.
  • kpin404
    Hello Jan, I have noticed that after running the status for lora_pkt_fwd its still showing lora_pkt_fwd service ; disabled. Do you have any idea how to make it enabled as in your case its showing enabled.
    this is a series of several posts. One of them explains how to install the service, and enable it by default.
    I just checked, and it's indeed showing as enabled on my OS.
    I have no idea what the difference is.
