Internet of Things
Internet of Things
Blog Set up Elecrow TTN LoRaWAN gateway on Raspberry Pi - Pt. 1: build and test
  • Date Created: 28 Dec 2023 9:20 PM Date Created
  • Views 8049 views
  • Likes 8 likes
  • Comments 37 comments
  • raspberry
  • the things network
  • lorawan
  • ttn
  • gateway
  • iot
28 Dec 2023
I installed the software for the Elecrow LoRaWAN gateway (see  Low-Cost LoRaWAN Gateways! ), and enabled the gateway on The Things Network (TTN). I used Raspberry OS bullseye 32-bit lite on a Raspberry Pi  A+. I tested this on a B+ with the same OS too.
epic
Instructions from Elecrow: https://www.elecrow.com/wiki/index.php?title=LR1302_LoRaWAN_Gateway_Module
Preparation
sudo apt-get update
sudo apt install -y git
cd ~
run sudo raspi-config to enable
  • i2c,
  • SPI and
  • Serial Port. For Serial Port, do not allow console (question 1: no), but allow enabling of the port (question 2: yes).
Build the software
The following section is different than the vendor's instructions:
clone https://github.com/Elecrow-RD/LR1302_loraWAN.git
cd LR1302_loraWAN
cd LR1302_HAL
cd sx1302_hal
back to the existing instruction
make
Create new TTN Gateway
If you don't have an account yet, create one. Select the suggested settings for your location. Once logged in, navigate to the console. Select Gateways
Register your new Gateway. Accept the suggested frequency and setup. I used https://descartes.co.uk/CreateEUIKey.html to generate an ID
Then download the json file that's created for you. It holds some of the settings you 'll need to update in the gateway's config file later.
Configure the packet_forwarder
cd packet_forwarder
nano global_conf.json.sx1250.EU868
I had to change this line extra, not in instructions:
"gps_tty_path": "/dev/ttyS0",
change the EUI in the config file, and check the TTN server URL. Save
chmod +x reset_lgw.sh
Test
./lora_pkt_fwd -c global_conf.json.sx1250.EU868
You will get a log of what's happening:
The TTN console confirms it found you:
And after some time, you will appear on the maps: https://ttnmapper.org/heatmap/
I've tested with an Arduino MKR 1310, and all worked fine:
Proper install of all software (covered fully in the next blog)
There's more than this. To install all software in a location of your choice, check the instructions on git: https://github.com/Elecrow-RD/LR1302_loraWAN/blob/master/LR1302_HAL/sx1302_hal/readme.md
first edit target.cfg, and set your user name and location where to install (must exist)
Then
make install
make install_conf
Full install post:  Set up Elecrow TTN LoRaWAN gateway on Raspberry Pi - Pt. 2: full install and run as service
Enjoy
    Jan Cumps over 1 year ago in reply to DaniLecx +1
    In the github issue you are referring to, there is a replacement reset script attached ( here ). If you overwrite sx1302_hal/bin/reset_lgw.sh with those contents, it should work with a sysfs-less linux…
    Jan Cumps over 1 year ago in reply to Jan Cumps +1
    the USE_LIBGPIOD setting in docker does the same : (see start file ) if [[ ${USE_LIBGPIOD} -eq 0 ]]; then cp /app/reset.sh.legacy ${RESET_FILE} else cp /app/reset.sh.gpiod ${RESET_FILE} fi /app…
  • kpin404
    kpin404 over 2 years ago
    Hello Jan Cumps ,
    I have received an Elecrow LR1302 (868) LoRaWAN gateway module included with Pi HAT from Elecrow. After hardware assembling with Raspberry- Pi board I have tried to setup as per the vendor's instructions, but afraid to say that I am unable to make a setup configuration for this. Could you please help me to assist further with its complete step-by-step setup configuration instructions to make it work for me. Thanks.
    Jan Cumps over 2 years ago in reply to kpin404
    This series of blog posts is my step by step document. I have nothing more detailed.
    this is a series of several posts. One of them explains how to install the service, and enable it by default.
    I just checked, and it's indeed showing as enabled on my OS.
    I have no idea what the difference is.
  • kpin404
    kpin404 over 2 years ago in reply to Jan Cumps
    Okay! Thanks for clearing on it.
    shabaz over 2 years ago in reply to kpin404
    Might be worth just configuring and using The Things Network first, so that at least you have a known working setup. That at least eliminates a load of things once you decide to run your own LoRaWAN network server.
  • kpin404
    kpin404 over 2 years ago in reply to shabaz
    Hello shabaz , Okay! got it. Thanks.
    If you do that correctly, you should have a specific .json file in your service status:
    in my case, the sevice shows this info:
    615 /home/jancumps/sx1302_hal/bin/lora_pkt_fwd -c /home/jancumps/sx1302_hal/bin/global_conf.json.sx1250.EU868
    I see that you have  ....   ./global_config.json.
    This is the file where I had to configure gateway ID and lorawan network url . Did you do all steps from start to end?
  • kpin404
    Yes! i done all the procedure step-by-step and configured everything including network server access url, gps tty path, but i didn't change the gateway id as its already showing in the configuration file. Do i must have to change it also?image
    In my case, the gateway_ID is identical (without the blank spaces) to Gateway EUI on the gateway general information page on TTN
    Same in my case as Jan. It's critical that the value entered on the LoRaWAN provider site config item Gateway EUI  matches the Gateway ID value (which is also known as Gateway EUI) that is in your LoRaWAN gateway. You don't need to change the value that is in your gateway. You simply copy it, and paste it into the Gateway EUI config box on the LoRaWAN provider site.
  • kpin404
    Hello there, thanks all for your support. I have configured and tested to setup with TTN server and it did connected successfully. Now this confirms that there is an issue with my local network server to be to check with. Thanks.image
