Internet of Things
Internet of Things
Forum Design advice on a newbie project!
  • Replies 7 replies
  • Subscribers 523 subscribers
  • Views 1078 views
brand new to this site and was looking for advise on starting a home project that:
- controls a gearmotor (or 2 if needed) that moves a flat object weighing <13ounces.
- controllable bi-directional motors (speed/duration)
- ability to control via internet
Looking for some direction/recommendations on what boards/controllers/gearmotors/gear size I should start looking at.
  • oksbwn
    oksbwn over 10 years ago +1
    For Internet Connectivity you can 1. Use Ethernet Shields like WZ500 or ENC28J60 with Microcontroller OR you can use GSM modules to use GPRS like SIM900. 2. For driving Motors from the microcontrollers…
  • Robert Peter Oakes
    Robert Peter Oakes over 10 years ago +1
    Timing is everything... I just finished an IoT week project with Texas Instruments and I think covered off several of your requirements and can also suggest a few extras. The nice thing is this continues…
    jw0752 over 10 years ago
    Hi Patrick,
    Welcome to E-14. It sounds like you have an interesting project in mind. What is your background in electronics at this time? Are you looking to design something or are you looking for more of a snap together project. One thing that might be of interest would be to look at some of the design challenges that have been featured on the Forum to see if you can find some applicable technology for your project. If you want to get more specifics from the forum you will probably have to provide more details of what you are looking to do. In any case it is nice to have you on the forum and I will be watching this thread to see if I can be of any help.
    e14 Contributor over 10 years ago in reply to jw0752
    Hi John,
    thanks for the response!
    Since my background is mainly software, I've been experimenting of late with some of the launchpads/boosterpacks that are available. I figured that there were enough tools available that I could something plug together for what I am wanting to do, but getting started in the right direction with the right hardware would probably save me a lot of headache!
    thanks
    Patrick
  • oksbwn
    2. For driving Motors from the microcontrollers you can use Motor drivers. Speed Can be controlled by using Voltage control or any other methods.
    Timing is everything... image
    I just finished an IoT week project with Texas Instruments and I think covered off several of your requirements and can also suggest a few extras. The nice thing is this continues with your experience with TI Launchpads.
    Here is the play list https://www.youtube.com/playlist?list=PL_atu5RtEPi5I5YWx_wb_j9erZGCvnpvW
    I have not posted the accompanying blog posts yet but the videos will help I think
    • Using a CC3200 (Arm Cortex so loads of power and built in WIFI for connectivity)
    • Sharp96 Display for local view of Parameters
    • Controlling a Fan via a relay using GPIO
    • SMART GUI interface using a SMART device that can be available from anywhere
    • Using MQTT for central monitoring of Data (On the Cloud image )
    • Measuring Temperature as an example of environmental sensing.
    I will be adding to the TI Tuesday series each week and will be including Motor Control in one of the early ones.
    In the meantime you can look at the various TI motor control Booster packs available for Steppers as well as DC motors
    go here TI LaunchPad - BoosterPacks  and Filter BoosterPacks on "Motor Control"
    e14 Contributor over 10 years ago in reply to oksbwn
    Thanks for the input and the suggestions! great to find a forum with people willing to share knowledge! image
    e14 Contributor over 10 years ago in reply to Robert Peter Oakes
    Thanks Peter. Great links and videos. Started watching them and my shopping carts are getting progressively heavier! image Hope to see more of your videos soon.
    Patrick
  • oksbwn
    oksbwn over 10 years ago in reply to e14 Contributor
    That's what community does..
