Power & Energy
Power & Energy
Blog GaN Point of Load converter 48V to 1V 50A - part 1: Design Overview
Toptech-Voices
  • Date Created: 10 Feb 2017 10:02 AM Date Created
  • Views 7972 views
  • Likes 9 likes
  • Comments 24 comments
  • gallium_nitride
  • step_down
  • dc_dc_converter
  • lmg5200
  • experimenting_with_magnetic_components
  • gan
  • energy_power
10 Feb 2017
I'm reviewing a Gallium Nitrate step-down converter for Point of Load (PoL) high power conversion
This design is intended to deliver low voltage (0.5 - 1.5V) at a power hungry point of load. It can source 50A. With a switching frequency of 600 kHz, the footprint can stay small.
A 48V DC power bus is common in industrial environments. That voltage often needs to be converted to other levels.
For high-performance processors, FPGAs and application specific ICs, this can be as low as 0.5V or 1V,  with a current draw of many amps.
The evaluation kit here (LMG5200POLEVM-10), that I got for review from TI almost a year ago, is intended for such applications - located close to the low voltage load.
GaN Power Stages
This isn't the simplest circuit. It consists of a half-bridge Buck converter, a transormer (a funny one) an output rectifier with filtering.
Primary Side
source: Using the LMG5200POLEVM-10 48V to Point of Load EVM
The half-bridge on the primary side is a GAN device that I've extensively reviewed in previous blogs: LMG5200. Check the blogs for details.
For this design, it's essential to understand that it is used as a typical Buck and that it switches at high frequencies.
We'll visit this component again when we check the PWM controller (it's a smart one with i2c interface) that is the brain of the converter.
Transformer
It's built from PCB traces, with a ferrite core over it. SO no wires in this transformer , just a single PCB trace on each side of the board.
edit: This is a 10 layer board. The Transformer has a 5:1 ratio. Check the comments below.
Planar transformer surrounded by a ferrite core
(two half cores that connect trough rectangular openings in the PCB)
10 layer board with 5 primary windings and 1 secondary winding
Layers 1,4,5,7,10 dedicated to the secondary side (each one turn in parallel) and the other to the primary side (one turn each in series).
The stacking goes S PP SS P S PP S (S=secondary P= primary).
It's crazy that you can transfer 75 Watt with this construct, isn't it?
Secondary side
This is a GaN transistor based rectifier and an LC filter to smoothen the output.
The gates of these transistors (in reality Q3 and Q4 in Figure 1 each are constructed with two discrete GaN FETs) are driven with the same signal that drives Q1 and Q2 on the primary side.
Core of the power circuit. Additional decoupling and filter caps not shown here.
There's no heat sink required. When the output current exceeds 20A, active cooling (a fan) is needed.
In the next blogs, I'll check out additional circuits on the development kit: the step-down controller and the on-board 10A pulsing(!) test load.
I hope that someone with sound electromagnetic knowledge chimes in to discuss the PCB transfo (the core is ER18-3.2-10-3F45-S from Ferroxcube).
Blog Posts
part 2: Current Doubler
part 3: Dynamic Test Load
Related Blog
Checking Out GaN Half-Bridge Power Stage: Texas Instruments LMG5200 - Part 1: Preview
    Jan Cumps over 9 years ago in reply to jc2048 +5
    Jon Clift wrote: ... Can't quite get my head around the control side for the moment - does the input have to operate at the point between continuous and discontinous operation? Perhaps I should read the…
  • alberto@ti
    alberto@ti over 9 years ago in reply to Jan Cumps +5
    Hi Jan, since I have some data at temperature, I would like to share it with you so that you can have a reference point. The thermal images below have been taken running at 75V input, 50A output current…
    Jan Cumps over 9 years ago in reply to jc2048 +4
    These are posts that I fitted on the board, Jon. There's loads of copper going to that point. I just mounted the ones from my breadboard for convenience. What the connections really look like: With copper…
    DAB over 9 years ago
    Very interesting board.
    I am curious, do they have a specific load type?
    I wonder if it could drive either a laser diode or a inductive load at those current levels.
    Jan Cumps over 9 years ago in reply to DAB
    For capacitive and inductive loads, the rules and constraints are the same as for other switched PSUs. Current surge or inductive build-up have to stay within the margins of the components - both for the primary and secondary side in this design. For capacitive loads you have some control because the current ramp-up  behaviour is configurable - and there's over-current protection. Inductive kick-back is out of our hands because it's the inductive load that causes it. It's going to be the duty of the human being to not attach a load that generates voltages that damage the circuit.
    Jon's relais switching analysis with transistors is an interesting blog on that subject - it takes a step further than the mythical killer voltage talk and actually shows what voltages are at play in a real situation.
    I have no experience with laser diodes - I don't know what their specific power profile is or if a 1.5V supply is useful in a scenario with these diodes.
