Power & Energy
Power & Energy
Blog Leaking Alkaline Cells
Toptech-Voices
  • Author Author: shabaz
  • Date Created: 9 Jul 2015 3:14 PM Date Created
  • Views 2760 views
  • Comments 17 comments
  • duracell
  • alkaline
  • battery
  • cell
shabaz
shabaz
9 Jul 2015
I just opened up a (semi) expensive bit of equipment and discovered the Duracells inside had leaked with the typical
white powder (potassium hydroxide) : (  and corroded contacts in the battery compartment as the result.
These ones were dated 'best before' March 2024, and had been inserted for less than a couple of months (and had just average use
during this time).
I was wondering what experiences others have had, and if they have successfully brought product liability charges against the manufacturer.
In the UK, a manufacturer can be held responsible for their faulty product, and any damage to property or to people (pure economic loss is not covered -
i.e. down time, loss of earnings, etc). However I expect in most cases the manufacturer just settles before a claim is raised in court.
I believe it is well known that Duracell batteries leak (something they don't mention in their bunny commercials) - so I always try to purchase Energizer or
other brands, but sometimes stores only have the Duracell option for alkaline cells : (
  • michaelkellett
    michaelkellett over 11 years ago +2
    Are you sure that they are genuine Duracells - I've always found them to be the best primary cells for performance and reliability. I've just done some tests running down more than 15 pairs of AA cells…
    jw0752 over 11 years ago in reply to shabaz +2
    Hi Shabaz, I like your idea to check one out internally. I am going to dissect one here in my shop and I will post the autopsy pictures. You can do the same and we will see how consistently they are manufactured…
    jw0752 over 11 years ago in reply to mcb1 +2
    Good to see you're back. John
    shabaz over 11 years ago in reply to jw0752
    Hi John,
    I'm wondering if I should try to examine one of the cells in more detail (perhaps destructively) to see if I can come any closer to determining if it is genuine or not.
    The Duracell customer support person didn't say I needed to keep hold of the cells, but since I have two I don't see why I shouldn't take one apart if needed.
    The trouble is, I do not know what to look out for to identify a genuine or a fake Duracell : (
    Duracell do not seem in any way inclined to want to run any analysis on the cell.
    There is the possibility that more fake Duracells are out there than fake Energizers I suppose. But in that case if it is so hard to spot the difference
    between fake and genuine, perhaps Energizer is the safer choice : ( I don't know.
    For the nephews motorized toys, I use very cheap store-brand alkaline cells from the local Maplin store (it is like a Radio Shack) - they appear to last a very reasonable time.
    Hi Shabaz,
    I just had to come to the defense of the "Energizer" Bunny. As far as cleaning the crusty areas by the springs I usually use a wire brush to get in and breakup the crystals. In my more important equipment I use the Duracell but I have no real justification for this. I am interested if there is truth to your supposition that they are prone to leak more than the Energizers. I could change brands without a glance back. For my less critical equipment I usually buy 2 alkaline for a dollar from the Dollar Store.
  • johnbeetem
    johnbeetem over 11 years ago
    I've found Duracell to be more reliable than most.  OTOH, counterfeiters keep getting better and it's hard for even the best suppliers to know if they're getting cheated themselves.  You can't count on counterfeiters stamping "Made in British" any more image
  • michaelwylie
    michaelwylie over 11 years ago
    I've got an older TI-83+ that never fails to make a battery leak.
  • michaelkellett
    michaelkellett over 11 years ago in reply to shabaz
    I have a few more to test  - including some real cheapos from Aldi.
    The only ones I would definitely avoid are the Duracell Ultra and Energizer Ultra Lithium, because although they do give  a little more life than the next level down Duracell and Energizer batteries they offer much worse value for money.
    Of course my tests don't tell me about shelf life or leakage (although I have several coffee jars full of about the last three years worth of dead batteries ready for re-cycling so I could look at them).
    You would have hoped that Duracell would do a bit more than just replace the duff battery.
    MK
