This is a link Back to the Main 33622A Review http://www.element14.com/community/roadTestReviews/1744
Welcome to Radio E14 for a one time show and a one time great English Classic tune and cant believe I actually recorded the whole thing and posted it either (The worlds all going MAD MAD MAD)
Settings for Channel 1:- , pick a channel that is not used in my area (Important not to inadvertently annoy the locals even though I thought this was un-lightly... boy was I wrong
90.5Mhz
1.414 VRMS output
Frequency Modulation
240Khz frequency deviation
External Modulation
1 Volt Modulation input
setting for channel 2:- pick a channel that is not used in my area (Important not to inadvertently annoy the locals even though I thought this was un-lightly)
740Khz frequency,
Amplitude Modulation ,
100% depth of modulation,
External Modulation
1V modulation input...
Easy
Finally a catchy well know opening song for this one and only show... Of course, a British fav... CRAZY FROG, yes I really did
so here is the show
Problemchild
0
Problemchild
in reply to Problemchild
0
Problemchild
0
Robert Peter Oakes
0
Problemchild
in reply to Robert Peter Oakes
0
Problemchild
0
