Test & Tools
Test & Tools
Blog Sound and Vibration Measurement: Instrument Network Service for LabVIEW Pt7: Service Wrappers - run the instrument services as Linux Daemon
  • Date Created: 20 Apr 2022 12:30 PM Date Created
  • Views 1054 views
  • RoadTest
  • daemon
  • mcc172
  • service
  • linux
20 Apr 2022
For the Sound and Vibration Measurement Hat for Raspberry Pi road test, I'm reviewing Measurement Computing's IEPE Measurement DAQ HAT for Raspberry Pi.
The next series of posts are going to be a subplot. I'll make software to remotely control the DAQ, via LabVIEW. In this post I'm creating a service wrapper and install the Linux service. It will start at Pi startup, and can be stopped / started as you'd expect from a service.
I have done this before a few years ago, for another Pi SCPI instrument: a programmable LAB 8 channel switcher. The screen captures in this post show that the services are executed by root, but if you follow the instructions, it 'll be the pi user that runs them.
Prerequisites
You should have built the two binaries for this project.
  • daqhats_scpi_socket
  • daqhats_service
These binaries should be placed in /home/pi/bin, and made executable (chmod +x <binary_name>). If you place them in another location, amend the scripts below.
Start and Stop Shell Scripts
I've created a startup and a shutdown shell script in that same /home/pi/bin directory, and made them executable (again using chmod +x <shell_script_name>).
daqhats_start.sh
#!/bin/bash
echo "start daqhats instrument service. Wait 5 seconds to complete ..."
/home/pi/bin/daqhats_service 2501 2502 0 &
sleep 5
echo "start daqhats scpi service."
/home/pi/bin/daqhats_scpi_socket 2500 2501 &
echo "start sequence completed"
daqhats_stop.sh
#!/bin/bash
killall -9 "/home/pi/bin/daqhats_scpi_socket"
killall -9 "/home/pi/bin/daqhats_service"
These scripts take care that the right order is used to start and terminate both executables. There's a 5 second sleep to allow the instrument service's binary to start its socket listening thread. Both scripts will be invoked by the service handler to start and stop the daemon.
Service Script
Now the core of this post: creating that Linux service that starts up at boot, and can be restarted by the user. I've used the Raspberry Pi OS' networking.service as inspiration, and this website for the instructions: https://www.dexterindustries.com/howto/run-a-program-on-your-raspberry-pi-at-startup/
Create a new service wrapper daqhats.service in the same directory.
[Unit]
Description=daqhats Service
DefaultDependencies=no
Requires=ifupdown-pre.service
Wants=network.target
After=local-fs.target network-pre.target apparmor.service systemd-sysctl.service systemd-modules-load.service ifupdown-pre.service network.target
Before=shutdown.target
Conflicts=shutdown.target
[Install]
WantedBy=multi-user.target
WantedBy=network-online.target
[Service]
Type=oneshot
#EnvironmentFile=-/etc/default/networking
ExecStart=/home/pi/bin/daqhats_start.sh
ExecStop=/home/pi/bin/daqhats_stop.sh
RemainAfterExit=true
TimeoutStartSec=5min
User=pi
Create a symbolic link for systemd:
sudo chmod  644 ./daqhats.service
sudo ln -s /home/pi/bin/daqhats.service /lib/systemd/system/daqhats.service
Then, tell systemd that there's a new configuration and tell it to enable the service:
sudo systemctl daemon-reload
sudo systemctl enable daqhats.service
If you reboot, the raspberry will start with the daqhats Service running.
Check:
Managing the Service
You can use the usual systemd commands to verify, stop and start the daemon.
sudo systemctl status daqhats.service
sudo systemctl stop daqhats.service
sudo systemctl start daqhats.service
sudo systemctl restart daqhats.service
Link to all posts.
